    Foundation Plugin
    451 Posts 15 Posters 580.3k Views 15 Watching
    • medeekM Offline
      medeek
      A website typo, please check it now...
      Thank-you for promptly bringing this to my attention.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Tutorial 3 - Interior Footings for Slab-on-Grade Foundations (16:33 min.)
        Interior footings for rectangular slab-on-grade foundations is identical to working with polygon shaped foundations.
        design.medeek.com
        • medeekM Offline
          medeek
          First look at the slab depression toolbar:
          http://design.medeek.com/resources/images/foundation_dep_su_menu_active.jpg
          This toolbar will allow the user to add, delete, edit or modify slab depressions within slab-on-grade or slab foundations.
          design.medeek.com
          • medeekM Offline
            medeek
            BUG REPORT: I'm missing a transform in the "Add Interior Footing" tool, so if a foundation is created in a location other than the origin, it may produce an unexpected result (ie. shifted footing location). I am working on the fix currently. Funny that I never exposed this error in my testing or even in the tutorial video, it does take a special set of circumstances.
            I've also identified another issue where two footings might be coincident at their ends (start or end) at a non-orthogonal angle, see image below:
            http://design.medeek.com/resources/trussplugin/images/truss_su459_800.jpg
            In such a situation rather than sloping the ends of the footing towards each other I need to miter the ends so that they meet cleanly. Just some additional code in the block of code that applies the slope to the footings.
            If three footings or more footings were to meet at a single point then the boolean union of them would work out without a hitch, it is only when you join two footings at their ends that this scenario becomes an issue.
            design.medeek.com
            • medeekM Offline
              medeek
              Version 1.3.0b - 07.16.2019
              • Added the Slab Depression toolbar and icons.
              • Enabled a 45 deg. miter option for the ends of interior footings.
              • Fixed a bug with the initial positioning transforms for the interior footing draw tool.
              The option for mitering is tucked into the start and end slope option. Now in addition to the Yes/No options you also can have it miter left or right (45 deg only).
              http://design.medeek.com/resources/trussplugin/images/truss_su460_800.jpg
              This is a critical update since the transform bug was a significant issue with Version 1.3.0.
              The slab depression functions/tools are still under construction and currently not functional.
              design.medeek.com
              • medeekM Offline
                medeek
                Hmmm, you might be on to something with this.
                I agree that the amount of toolbars has multiplied quite rapidly as I keep adding more features to each plugin, it does take up quite a bit of screen real estate now.
                design.medeek.com
                • jujuJ Offline
                  juju
                  thanks for the efforts!
                  the toolbars for your extensions are becoming rather elaborate and taking up a bit of toolbar / screen space, any chance you could implement a single initiation button/icon instead and have a secondary open when the primary has been triggered, much like Fredo does some of his extensions?
                  • medeekM Offline
                    medeek
                    Version 1.3.1 - 07.19.2019
                    • Added slab depressions for rectangular and polygon slab-on-grade foundations.
                    • Enabled editing, moving and deleting of slab depressions for all slab-on-grade foundations.
                    • When construction callouts and subbase material is enabled, the volume of the subbase material is displayed beneath the foundation label (currently only slab-on-grade foundation assemblies have this feature available).
                    http://design.medeek.com/resources/trussplugin/images/truss_su461_800.jpg
                    The slab depression tool can also be used to cut thru holes into the slab, as shown.
                    Note that additional work still needs to be done to properly modify rebar and mesh for slab depressions. Currently there is no logic in place to modify the perimeter or slab rebar when a slab depression is utilized within a slab-on-grade foundation.
                    View model here:
                    3D Warehouse
                    (3dwarehouse.sketchup.com)
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Tutorial 4 - Slab Depressions for Slab-on-Grade Foundations (9:35 min.):
                      View model here:
                      3D Warehouse
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Trying to take a day off from the programming but my mind keeps coming back to it and the brick ledge module (for slab-on-grade foundations) I have left unfinished.
                        Giving it a bit of thought this afternoon and I've come up with the following parameters:
                        • Ledge Width
                        • Ledge Height
                        • Start Ext.: Defaults to zero
                        • End Ext.: Defaults to zero
                        Really not much to it, or so it would seem.
                        The idea is to be able to create a brick ledge on any specified edge (perimeter) of the foundation rather than around the entire foundation. A lot of modern designs only utilize a brick facade on the front of the house and not on the rear so this ability to be selective with each wall is critical.
                        Once I have this feature up and running I think the tools afforded the slab-on-grade type of foundation will allow it to be utilized for most designs however additional work will still need to be done to make the rebar placement correct in a complex design.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          First look at brick ledges combined with a slab depression (garage).
                          http://design.medeek.com/resources/trussplugin/images/truss_su462_800.jpg
                          The trickiest part of the brick ledge module was the tool that selects the foundation edge. I have it working stably now but I need to add some additional logic which prevents the user from duplicating a brick ledge along the same foundation edge.
                          I also need to add in some additional logic which offsets the anchor bolts the appropriate amount given the width of the brick ledge.
                          Similar to the slab depressions the brick ledge module makes no accommodations currently for rebar placement. The logic and algorithms for that will take some considerable effort.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Here is slight modification where the slab depression is lower than the brick ledge:
                            http://design.medeek.com/resources/trussplugin/images/truss_su463_800.jpg
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 1.3.2 - 07.22.2019
                              • Added brick ledges for rectangular and polygon slab-on-grade foundations.
                              • Enabled editing, and deleting of brick ledges for all slab-on-grade foundations.
                              • Added an additional layer for hidden geometry into the Layers tab of the Global Settings.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Tutorial 5 - Brick Ledges for Slab-on-Grade Foundations (14:11 min.):
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  I am seriously considering adding the ability to slope the slab depression and would actually like to work on it before I move back to the complex roof module.
                                  I have a few questions:
                                  1.) With a sloping floor do you typically measure the depression from the high side as your reference and then slope it downward? Or do you measure where you want the doors to end up and then slope upwards?
                                  2.) What is a typical slope in a garage slab depression? Is a 1/4" per foot typical? On a 24' deep garage this would mean a vertical difference of 6 inches from front to back. This seems like a pretty steep slope.
                                  3.) If a depression is sloped then I would assume that the slab thickness in the depressed region would remain a constant thickness and hence the bottom of the slab at this region would also slope?
                                  design.medeek.com
                                    MtnArch
                                    I normally set the top of the depression at 3-1/2" below the main slab (a 2x4 for the form) and 5-1/2" below the main slab at the garage doors (a 2x6 for the form); if the garage is deeper than - say - 24' I would probably slope to a central location and add a drain inlet. Stems higher than 5-1/2" would need to be increased in width for me to be comfortable that they would be stable.
                                    Highest Regards,
                                    Alan T. Hendry, RA
                                    Architect
                                    • medeekM Offline
                                      medeek
                                      Rather than prompt the user for a pitch/percent grade or some other angle I think it would be easier just to have them specify a height differential. So if the primary depth of the depression is 3.5" at the back of the garage and then the user calls out a differential of 2" then the other side of the depression will be 5.5" at the door.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 1.3.3 - 07.24.2019
                                        • Enabled sloping slab depressions for rectangular and polygon slab-on-grade foundations.
                                        • Fixed a bug with the slab depression draw tool.
                                        http://design.medeek.com/resources/trussplugin/images/truss_su464_800.jpg
                                        The sloping of the depression can be either in the X or Y direction, in the future I may allow for other directions. To reverse the slope, the slope differential can be entered in as a negative number in the edit or draw menu.
                                        design.medeek.com
                                          MtnArch
                                          Very cool - great implementation!
                                          Highest Regards,
                                          Alan T. Hendry, RA
                                          Architect
                                          • medeekM Offline
                                            medeek
                                            Giving a little thought on how to created stepped foundation the last couple of days as I wrapped up work on the slab-on-grade foundations.
                                            Creating a single (closed-loop) stemwall foundation assembly with steps is proving to be difficult. After giving this some additional analysis it seems that it would be better to break it down into separate (polyline) assemblies, somewhat similar to the Wall plugin.
                                            If I switch to this type of system then creating steps in a foundation is just a matter of adding step "segments". I've identified three basic type of steps in the detail below:
                                            http://design.medeek.com/resources/trussplugin/step_foundation_800.jpg
                                            Note, that there would also be a right and left hand version of each, this comes into play with non-symmetric features such as foam insulation and anchor bolts.
                                            So essentially I need to create a whole new system for stemwall foundations, the current system is not scalable. The three main tools need to be:
                                            1.) Polyline Tool
                                            2.) Step Tool
                                            3.) Interior Footing Tool
                                            The polyline tool will also allow for a single (linear) stemwall or any number of segments.
                                            I also need a opening tool for creating windows and doors in the stemwall/foundation wall.
                                            4.) Opening Tool
                                            design.medeek.com
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 22
                                            • 23
                                            • 12 / 23
