    Foundation Plugin
    450 Posts 15 Posters 496.4k Views 15 Watching
    • medeekM Offline
      medeek
      Version 1.2.7 - 07.05.2019
      • Added the Interior Footings toolbar and icons.
      • Added the Brick Ledges toolbar and icons.
      • Enabled a resync function in the License tab of the Global Settings for license renewals.
      Within the License tab if you click on the license exp. date the plugin will then resync with the server and update your license exp. date accordingly. This is a resolution to the issue some users have recently had when renewing their license.
      Previously the user had to remove their serial number and then re-enter it in order for the plugin to update itself with the new license expiration date.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Looking at adding in an option for a sub-base layer for slabs and slab-on-grade foundations:
        http://design.medeek.com/resources/trussplugin/images/truss_su449_800.jpg
        Let me know if there are any specific requirements that you might have.
        The only two parameters I have for this are the depth and the material.
        design.medeek.com
          gameongrant
          Are you looking to add several other layers such insulation and surface finishes ie. screed in the future?
          • pbacotP Offline
            Moisture barrier?
            • medeekM Offline
              medeek
              Being that it is the weekend of the 4th I was quite surprised at all of the feedback on my previous post, thank-you for taking the time to respond and provide valuable feedback and information.
              It seems that slab insulation is also a feature that I should also add to the mix. Most details I've seen shown it directly below the slab between the subbase and concrete:
              http://design.medeek.com/resources/trussplugin/images/truss_su450_800.jpg
              Note that many details I've seen show the slab insulation wrapping down around the footing or at least dropping down along its vertical side to the bottom of the footing. However, to model the slab insulation in this way would be very computationally expensive (in other words a big pain in the butt) and require some rather elaborate code.
              What I've shown is a slightly simplified version which I can easily achieve using some very simple boolean addition and subtraction.
              The updated list of parameters is now:
              Slab Insulation: Yes/No
              Slab Insul. Thickness: Default to 2"
              Subbase: Yes/No
              Subbase Thickness: Default to 4" or 6"
              Subbase Material: Default "medeek_gravel", user can choose from custom material library
              I've also had quite a few request for poly. I've never been a big fan of modeling non-solid geometry (ie. 2D films, vapor barriers etc...) In my opinion the SQFT callout for the foundation is enough information for the designer to know how much poly is needed for the foundation if they want to apply it below the slab (plus some waste factor). I'll have to give this some more thought.
              design.medeek.com
              • medeekM Offline
                medeek
                First look at a rectangular slab-on-grade with slab insulation and subbase material installed.
                http://design.medeek.com/resources/trussplugin/images/truss_su451_800.jpg
                Now I just need to jump into the polgyon module and enable the same feature for a polygon/face outlined slab-on-grade and then we can roll this new feature out.
                When I get a bit more time I will also add in the volume of the subbase material (CY) into the stats tab (attribute library) which can then be picked up by the estimator module and this information will also be part of the spreadsheet (Excel/CSV) output.
                Note to other developers:
                As I further develop these plugins I am including a stats table in the attribute library of each assembly I create. This information is exposed and can be utilized by anyone, including other plugins. For instance for slab-on-grade foundations I provide the number of anchor bolts, the lineal feet of rebar, the area of the slab, and the volume of the concrete. If there are any questions about any of the entries in this table and what each number means I will be more than happy to dive into the details with you.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 1.2.8 - 07.07.2019
                  • Added slab insulation and subbase options for rectangular slab-on-grade foundations
                  • Added slab insulation and subbase options for polygon slab-on-grade foundations
                  • Added a subbase layer in the Global Settings under the "Layers" tab.
                  http://design.medeek.com/resources/trussplugin/images/truss_su452_800.jpg
                  Please note that the new interior footings module and the brick ledges module are both under construction. The current toolbars and icons for these modules are currently non-functional.
                  Both modules are actually quite complicated so my best calculation is about a week's worth of programming for each in order to complete them.
                  The FPSF option must be toggled on to enable under slab insulation. However, you now have the option to enable or disable perimeter insulation within the FPSF options.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 1.2.9 - 07.08.2019
                    • Added a Custom Material Library/Manager in the Materials tab of the Global Settings.
                    • Enabled custom materials for the subbase material in the HTML edit menus for slab-on-grade foundations.
                    I've had some conversations about providing formwork for the various foundations. This is not a high priority right now but at some point I may decide to add in this advanced option.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      First look at a slab-on-grade (rectangular) foundation with multiple interior footings:
                      http://design.medeek.com/resources/trussplugin/images/truss_su453_800.jpg
                      http://design.medeek.com/resources/trussplugin/images/truss_su454_800.jpg
                      Note that this feature (interior footing module) allows for an unlimited amount of interior footings in any orientation and with each footing being customizable to its own specifications.
                      As shown in the image above this new feature also works with the subbase and slab insulation options.
                      Now I just need to work on the edit, move and delete functions for the interior footings.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        This image demonstrates the vertical drop option/parameter along with various rebar configurations:
                        http://design.medeek.com/resources/trussplugin/images/truss_su455_800.jpg
                        The footing to the far right is a typical 12" deep shallow footing with two bars.
                        The two central footings are 18" deep (4" slab) with a 10" vertical drop. When you specify a qty. of four or six bars the plugin will arrange the bars top and bottom as shown otherwise the bars will be positioned at the bottom of the footing (with a 3" ground clearance).
                        Note that all of the footings shown have a slope of 45 deg. however this can also be customized to any angle.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Working in 3D is a bit different, and poses some additional challenges, when compared with designing in a 2D environment.
                          Slab-on-Grade interior footings are an excellent example of this type of problem. In a 3D environment you are usually wanting to work on your model looking down at it rather than looking up at it. Unless you have modified the transparency of concrete material you are typically unable to view the interior footings you have created.
                          To remedy this problem I have created a hidden layer (normally hidden) that is toggled on when you go to add, edit, delete or move an interior footing. This layer not only contains the outline of each footing but also the label assigned to each by the plugin:
                          http://design.medeek.com/resources/trussplugin/images/truss_su456_800.jpg
                          This layer can always be toggled manually by the user, but I have also setup the various tools to toggle it on and off during appropriate actions.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            As I've been putting the new interior footing module through its paces it occurred to me that the waffle type floor systems seen in large parking structures and in Australian residential construction will now be possible with this new feature.
                            I'm pretty excited to finally see this feature become a reality. I should have made this happen a couple years ago, but in all truthfulness I probably did not possess the programming chops or experience to make it happen at the time.
                            Fast forward a couple years, and I have much better handle of what I can and can't do with SketchUp's API. I've also been able to lean on and gain advice from some of the SketchUp sages along the way. Thank-you for coming to my rescue, and being so generous with your advice and time, it has made all the difference.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 1.3.0 - 07.14.2019
                              • Added interior footings for rectangular slab-on-grade foundations.
                              • Added interior footings for polygon slab-on-grade foundations.
                              • Enabled editing, moving and deleting of interior footings for all slab-on-grade foundations.
                              http://design.medeek.com/resources/trussplugin/images/truss_su457_800.jpg
                              This is a substantial upgrade for slab-on-grade foundations. I've completely removed the old interior footing code and replaced it with the new interior footing module. The ability to add, move, edit and delete each interior footing on an unlimited basis is a breath of fresh air for this plugin.
                              Now I just need to do something similar for stemwall foundations and slabs... there is always more to do.
                              Later today, after a small break, I will put out a tutorial video explaining the features of this new module and demonstrate its use.
                              design.medeek.com
                              • jujuJ Offline
                                juju
                                your download page for this indicates version 1.2.3 released 07/14/2019.
                                • medeekM Offline
                                  medeek
                                  Which page are you referring to? Can you give me the URL. The plugin page on my website is showing version 1.3.0.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    I've been considering the addition of a tool that adds in a depression to the slab-on-grade. The user would create any polygon shape which would then be used to generate this depressed region on the slab.
                                    The actual modifications to the concrete slab would be fairly easy to accomplish with the API however a number of ripple effects would pose other problems. The first problem would be slab reinforcement. The depressed region would need to have its reinforcement translated down with the slab so it remains centered within the slab.
                                    A similar problem exists for slab insulation and subbase material, these items would need to be moved down in the z direction as well. This of course is assuming that the slab in the depressed region remains the same thickness as the rest of the slab, however this might not be the case.
                                    One could assign the a zero thickness to the depressed region slab thickness which essentially cuts a hole in the slab if the depression is equal to the slab thickness.
                                    Or one could specify a thicker slab in this depressed region.
                                    Regardless slab depressions are quite interesting and introduce a number of complex problems when combined with other features like internal footings, slab insulation, subbase and slab reinforcement.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      After mauling this over a bit more I think I can deal with the concrete, slab insulation, interior footings and subbase fairly easily with a slab depression, however the slab reinforcement is a bit more challenging. Even the footing top bars are a bit problematic ( they need to be dropped as well) as one can see in the image below:
                                      http://design.medeek.com/resources/trussplugin/images/truss_su458_800.jpg
                                      At the moment I don't have a good answer for how to deal with slab depressions when combined with slab reinforcement. If anyone has a good idea I'm open to suggestion.
                                      This type of slab depression (4") is fairly typical for a garage that is attached to the main residence.
                                      View model here:
                                      3D Warehouse
                                      (3dwarehouse.sketchup.com)
                                      I'm not saying there are not solutions to this problem but they become very computationally expensive (ie. boolean subtraction) and are not at all optimal.
                                      design.medeek.com
                                      • jujuJ Offline
                                        juju
                                        see attached 👍
                                        • medeekM Offline
                                          medeek
                                          A website typo, please check it now...
                                          Thank-you for promptly bringing this to my attention.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Tutorial 3 - Interior Footings for Slab-on-Grade Foundations (16:33 min.)
                                            Interior footings for rectangular slab-on-grade foundations is identical to working with polygon shaped foundations.
                                            design.medeek.com
                                            • 11
                                            • 12
                                            • 13
                                            • 22
                                            • 23
                                            • 11 / 23
