    Foundation Plugin
    451 Posts 15 Posters 562.3k Views 15 Watching
    • medeekM Offline
      medeek
      Version 1.2.0 - 01.06.2019
      • License expiration date now appears in the License tab of the Global Settings when plugin is registered.
      Estimating data for slab-on-grade foundations is now available with Version 0.9.9w of the Wall plugin.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 1.2.1 - 01.20.2019
        • Fixed a bug in the license and registration module.
        design.medeek.com
        • medeekM Offline
          medeek
          Version 1.2.2 - 02.25.2019
          • Fixed a bug in the display of the toolbars (Mac and Windows).
          design.medeek.com
          • medeekM Offline
            medeek
            Version 1.2.3 - 03.15.2019
            • Updated toolbar icons to be compatible with 4k (UHD) resolution monitors.
            design.medeek.com
            • medeekM Offline
              medeek
              First look at the new edit menu for slab on grade foundations:
              http://design.medeek.com/resources/trussplugin/images/truss_su446_800.jpg
              design.medeek.com
              • medeekM Offline
                medeek
                Version 1.2.4 - 06.26.2019
                • Enabled the "Edit SOG Assembly" function/menu for rectangular slab-on-grade foundations.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 1.2.4b - 06.27.2019
                  • Corrected the code for raising and logging exceptions.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 1.2.5 - 06.29.2019
                    • Enabled the "Edit SOG Assembly" function/menu for polygon slab-on-grade foundations.
                    • Enabled the "Edit SOG Outline" function for polygon slab-on-grade foundations.
                    The ability to edit the outline of polygon shaped foundation is fairly important not only for this plugin but also for the complex roof module of the Truss plugin. I will be moving back to the Truss plugin this next week to continue my work on the complex roof module.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Tutorial 2: Editing Slab-on-Grade Foundations
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 1.2.5b - 07.01.2019
                        • Enabled the "Edit Slab Assembly" function/menu for rectangular slab foundations.
                        • Enabled the "Edit Slab Assembly" function/menu for polygon slab foundations.
                        • Enabled the "Edit Slab Outline" function for polygon slab foundations.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 1.2.6 - 07.03.2019
                          • Enabled the "Edit Stemwall Assembly" function/menu for rectangular stemwall foundations.
                          • Enabled the "Edit Stemwall Assembly" function/menu for polygon stemwall foundations.
                          • Enabled the "Edit Stemwall Outline" function for polygon stemwall foundations.
                          http://design.medeek.com/resources/trussplugin/images/truss_su447_800.jpg
                          All of the current features of the foundation plugin are now fully parametric. However, I do need to introduce a new system for handling stepped foundations and internal strip footings for both slab-on-grade and stemwall foundations.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            The absence of a interior footing module for the slab-on-grade type foundation is very frustrating for me and I am sure for a lot of other users as well.
                            With that being said I've decided to put my thinking cap on again and give this issue some further thought. Based on what I have so far for foundations and looking at some other foundation examples I think the following parameters should be sufficient to fully define an interior (thickened slab footing):
                            Basic Options:
                            Footing Width
                            Footing Depth
                            Slope Angle
                            Slope Start: Yes/No
                            Slope End: Yes/No
                            Vertical Drop: default is zero
                            Reinforcement: Yes/No
                            Anchor Bolts: Yes/No
                            Reinf. Options:
                            Ftg. Bar Dia:
                            Ftg. Bar Qty: 1,2,3,4,6
                            Anchor Bolt Options:
                            Anchor Bolt Length: 10,12,14 (in.)
                            Anchor Bolt Dia.: 1/2 or 5/8"
                            Washer 2X2, 3X3
                            Bolt O/C Spacing
                            Sill Plate Thickness:
                            End Distance:
                            The vertical drop option is the 6" dimension in the image below:
                            http://design.medeek.com/resources/trussplugin/images/truss_su448_800.jpg
                            The interior footing module will be quite similar to the window and door module in the Wall plugin. It will allow the user to add, delete, move or edit any interior footing within the SOG. Unlike the current system (only one interior footing possible), the user will be able to create as many footing as they like, criss-crossing the slab in any direction at any angle. Once this feature is in place the slab-on-grade foundation will be much more versatile and hopefully much more capable of modeling real life (complex) foundations.
                            Please let me know if there are any other parameters or options that I might be missing from this list.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              First look at the interior footing toolbar:
                              http://design.medeek.com/resources/images/foundation_intftg_su_menu_active.jpg
                              This toolbar will allow the user to add, delete, edit or modify interior footings within stemwall, slab-on-grade or slab foundations.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                I will also be adding in a toolbar for working with brick ledges on slab-on-grade and stemwall foundations.
                                http://design.medeek.com/resources/images/foundation_ledge_su_menu_active.jpg
                                This will enable the user to add a brick ledge to any edge of a foundation, and also edit or delete the brick ledges. Currently brick ledges are only available with stemwall foundations and if enabled applies the brick ledge to the entire foundation outline.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 1.2.7 - 07.05.2019
                                  • Added the Interior Footings toolbar and icons.
                                  • Added the Brick Ledges toolbar and icons.
                                  • Enabled a resync function in the License tab of the Global Settings for license renewals.
                                  Within the License tab if you click on the license exp. date the plugin will then resync with the server and update your license exp. date accordingly. This is a resolution to the issue some users have recently had when renewing their license.
                                  Previously the user had to remove their serial number and then re-enter it in order for the plugin to update itself with the new license expiration date.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Looking at adding in an option for a sub-base layer for slabs and slab-on-grade foundations:
                                    http://design.medeek.com/resources/trussplugin/images/truss_su449_800.jpg
                                    Let me know if there are any specific requirements that you might have.
                                    The only two parameters I have for this are the depth and the material.
                                    design.medeek.com
                                      gameongrant
                                      Are you looking to add several other layers such insulation and surface finishes ie. screed in the future?
                                      • pbacotP Offline
                                        Moisture barrier?
                                        • medeekM Offline
                                          medeek
                                          Being that it is the weekend of the 4th I was quite surprised at all of the feedback on my previous post, thank-you for taking the time to respond and provide valuable feedback and information.
                                          It seems that slab insulation is also a feature that I should also add to the mix. Most details I've seen shown it directly below the slab between the subbase and concrete:
                                          http://design.medeek.com/resources/trussplugin/images/truss_su450_800.jpg
                                          Note that many details I've seen show the slab insulation wrapping down around the footing or at least dropping down along its vertical side to the bottom of the footing. However, to model the slab insulation in this way would be very computationally expensive (in other words a big pain in the butt) and require some rather elaborate code.
                                          What I've shown is a slightly simplified version which I can easily achieve using some very simple boolean addition and subtraction.
                                          The updated list of parameters is now:
                                          Slab Insulation: Yes/No
                                          Slab Insul. Thickness: Default to 2"
                                          Subbase: Yes/No
                                          Subbase Thickness: Default to 4" or 6"
                                          Subbase Material: Default "medeek_gravel", user can choose from custom material library
                                          I've also had quite a few request for poly. I've never been a big fan of modeling non-solid geometry (ie. 2D films, vapor barriers etc...) In my opinion the SQFT callout for the foundation is enough information for the designer to know how much poly is needed for the foundation if they want to apply it below the slab (plus some waste factor). I'll have to give this some more thought.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            First look at a rectangular slab-on-grade with slab insulation and subbase material installed.
                                            http://design.medeek.com/resources/trussplugin/images/truss_su451_800.jpg
                                            Now I just need to jump into the polgyon module and enable the same feature for a polygon/face outlined slab-on-grade and then we can roll this new feature out.
                                            When I get a bit more time I will also add in the volume of the subbase material (CY) into the stats tab (attribute library) which can then be picked up by the estimator module and this information will also be part of the spreadsheet (Excel/CSV) output.
                                            Note to other developers:
                                            As I further develop these plugins I am including a stats table in the attribute library of each assembly I create. This information is exposed and can be utilized by anyone, including other plugins. For instance for slab-on-grade foundations I provide the number of anchor bolts, the lineal feet of rebar, the area of the slab, and the volume of the concrete. If there are any questions about any of the entries in this table and what each number means I will be more than happy to dive into the details with you.
                                            design.medeek.com
                                            • 11
                                            • 12
                                            • 13
                                            • 22
                                            • 23
                                            • 11 / 23
