    Automatic walls, doors & windows
    55 Posts 13 Posters 38.1k Views 13 Watching
    • N
      neil_M58
      new user. how do you change units to metric?
      • mariochaM
        mariocha
        Once SketchUp is set to metrics, just enter your metric values in the dialogs, they will replace the default values.
        %(#008000)[Mario C.
        • mariochaM
          mariocha
          This plugin is now Renamed to Sketch-Int
          and moved to SketchUp Extension Warehouse.
          %(#008000)[Mario C.
            dtrarch
            Sounds like a good idea for a plugin but a trial is always a good thing to view first.
            It is installed but???
            The trial email to validate does not show up in my mailbox after multiple tries to have it sent?
            I would hate to pay and have the same thing happen again.
            Is pay to play the only option that works to validate.?
            OK with me but need to know please.
            dtrarch
            • mariochaM
              mariocha
              Sketch-Int will be available soon on SketchUp EW, trial also.
              %(#008000)[Mario C.
              • pbacotP
                And on SketchUcation? What's the name about?
                • mariochaM
                  mariocha
                  Well, the licensing will be managed by EW, so it has to be downloaded from there. here there could be a link.
                  %(#008000)[Mario C.
                  • N
                    neil_M58
                    I am using with Sketchup 2017 on Mac. Worked OK at first, but now crashes or locks up. When trying to create a new door, an INFO window opens with a link to tutorial video, initially when closed this was replaced by the door dimensions etc window but know it just prevents me from selecting anything.
                    • mariochaM
                      mariocha
                      Hum... strange. Is this only with doors, exterior or interior ?
                      %(#008000)[Mario C.
                      • N
                        neil_M58
                        Happens with all options.
                        • mariochaM
                          mariocha
                          New version !! with EDIT items.
                          and more.
                          See first post.
                          %(#008000)[Mario C.
                          • mariochaM
                            mariocha
                            Brand new version of Sketch-Int available on SketchUcation Store !
                            New way to edit
                            %(#008000)[Mario C.
                            • mariochaM
                              mariocha
                              Been a while...
                              Just to inform you people that Sketch_Int has kept evolving.
                              For instance: by version number (date)
                              #22.02.23 Code improvement. Removed wrong use of select_tool.
                              #22.03.29 Added ajustable Stiles width for exterior doors.
                              #22.04.04 Handles in 2017 format
                              #22.04.06 Multiple Open. Louver int. doors. New handles.#22.05.25 Better Undo Edit windo
                              #22.06.30 Added Sliding windos
                              And that the newest version is available right from Sketchucation store in SketchUp.
                              %(#008000)[Mario C.
                              • mariochaM
                                mariocha
                                The new version, Sketch-Int is now live on SketchUp Extension Warehouse.
                                update: Now on SketchUcation.
                                %(#008000)[Mario C.
                                • mariochaM
                                  mariocha
                                  New versions:
                                  22-11-11 Added Trapezoid windows.
                                  22-11-15 Added Circular - Polygonal windows.
                                  %(#008000)[Mario C.
                                  • mariochaM
                                    mariocha
                                    Added Multi-Sash windos.
                                    And better grills for all.
                                    %(#008000)[Mario C.
                                    • mariochaM
                                      mariocha
                                      Updated to version 23-10-31.
                                      See release notes.
                                      %(#008000)[Mario C.
                                      • gullfoG
                                        gullfo
                                        See release notes.
                                        brilliant!
                                        Glenn
                                        http://www.runnel.com
                                        • mariochaM
                                          mariocha
                                          Thanks Glenn.
                                          Have you seen Sketch-Cuisine ? Good for any kink of cabinets.
                                          https://sketchucation.com/forums/viewtopic.php?f=323&t=75048
                                          %(#008000)[Mario C.
                                          • gullfoG
                                            gullfo
                                            i have, and if i did kitchen design it would be in my plugin set, but i do recording studio design so it's only marginally helpful as if i'm doing any "lounging" or snack space, i'm only drawing a small basic setup for the owner to sort out.
                                            Glenn
                                            • 3 / 3
