    Automatic walls, doors & windows
    55 Posts 13 Posters 36.3k Views 13 Watching
    • mariochaM Offline
      mariocha
      Sketch-Int will be available soon on SketchUp EW, trial also.
      %(#008000)[Mario C.
      • pbacotP Offline
        And on SketchUcation? What's the name about?
        • mariochaM Offline
          mariocha
          Well, the licensing will be managed by EW, so it has to be downloaded from there. here there could be a link.
          %(#008000)[Mario C.
          • N Offline
            neil_M58
            I am using with Sketchup 2017 on Mac. Worked OK at first, but now crashes or locks up. When trying to create a new door, an INFO window opens with a link to tutorial video, initially when closed this was replaced by the door dimensions etc window but know it just prevents me from selecting anything.
            • mariochaM Offline
              mariocha
              Hum... strange. Is this only with doors, exterior or interior ?
              %(#008000)[Mario C.
              • N Offline
                neil_M58
                Happens with all options.
                • mariochaM Offline
                  mariocha
                  New version !! with EDIT items.
                  and more.
                  See first post.
                  %(#008000)[Mario C.
                  • mariochaM Offline
                    mariocha
                    Brand new version of Sketch-Int available on SketchUcation Store !
                    New way to edit
                    %(#008000)[Mario C.
                    • mariochaM Offline
                      mariocha
                      Been a while...
                      Just to inform you people that Sketch_Int has kept evolving.
                      For instance: by version number (date)
                      #22.02.23 Code improvement. Removed wrong use of select_tool.
                      #22.03.29 Added ajustable Stiles width for exterior doors.
                      #22.04.04 Handles in 2017 format
                      #22.04.06 Multiple Open. Louver int. doors. New handles.#22.05.25 Better Undo Edit windo
                      #22.06.30 Added Sliding windos
                      And that the newest version is available right from Sketchucation store in SketchUp.
                      %(#008000)[Mario C.
                      • mariochaM Offline
                        mariocha
                        The new version, Sketch-Int is now live on SketchUp Extension Warehouse.
                        update: Now on SketchUcation.
                        %(#008000)[Mario C.
                        • mariochaM Offline
                          mariocha
                          New versions:
                          22-11-11 Added Trapezoid windows.
                          22-11-15 Added Circular - Polygonal windows.
                          %(#008000)[Mario C.
                          • mariochaM Offline
                            mariocha
                            Added Multi-Sash windos.
                            And better grills for all.
                            %(#008000)[Mario C.
                            • mariochaM Offline
                              mariocha
                              Updated to version 23-10-31.
                              See release notes.
                              %(#008000)[Mario C.
                              • gullfoG Offline
                                gullfo
                                See release notes.
                                brilliant!
                                Glenn
                                http://www.runnel.com
                                • mariochaM Offline
                                  mariocha
                                  Thanks Glenn.
                                  Have you seen Sketch-Cuisine ? Good for any kink of cabinets.
                                  https://sketchucation.com/forums/viewtopic.php?f=323&t=75048
                                  %(#008000)[Mario C.
                                  • gullfoG Offline
                                    gullfo
                                    i have, and if i did kitchen design it would be in my plugin set, but i do recording studio design so it's only marginally helpful as if i'm doing any "lounging" or snack space, i'm only drawing a small basic setup for the owner to sort out.
                                    Glenn
                                    • mariochaM Offline
                                      mariocha
                                      Version 24.01.08 Better move: decimal and fractions
                                      24.01.24 Trial bug correction
                                      %(#008000)[Mario C.
                                      • 3 / 3
