    Automatic walls, doors & windows
    55 Posts 13 Posters 36.3k Views 13 Watching
    • mariochaM Offline
      mariocha
      Better Doors on Rail (suspended) and Multiple Glass now even spaced.
      %(#008000)[Mario C.
      • Bob JamesB Offline
        Bob James
        @__juju__
        I think the awesomely detailed construction extensions being created by Nathaniel Wilkerson (medeek) is what you're looking for.
        • jujuJ Offline
          juju
          @bob james said:
          @__juju__
          Hi Bob, I agree that Nathaniel makes some really great extensions and he's extremely dedicated. I am keeping an eye on his new wall framing extension (in beta 0.74 now I believe), but we don't really use that method of construction where I'm at.
          I'll have to look and see what can be done with it, but I think I'm kinda stuck with what I want / need at the moment. I use Profile Builder 2 (by whaat, another of the many great coders) for walls and such which helps speed things up.
          I'm starting to think one of the solutions would be not to create walls as they're built, thus as a single volume, but this doesn't communicate correctly on the construction documentation. I also use Skalp 3 (by layer method) and am hoping that they will be able to develop their Pattern Designer so I can create a complex pattern to represent a complex / cavity wall when cutting through a single volume wall.
            Bob James
            So do I since I don't need construction details, but I'm looking Forward to Nathaniel's extensions for when/if I do πŸ˜„
            • pbacotP Offline
              Juju,
              I know how you feel I think. Actually the walls we usually use are closer to Medeek walls in construction, but then there's always something different. I have long gone to "outline walls" in building sections and use detail sections of specific parts. I have used SU a little for the empty volume sections. Usually find that the builder doesn't need to know how to build a wall and we have structural plans and details for everything that's not obvious and whatever the code compliance needs. We will sometimes also work out the preliminary sections in CAD for us and the engineer, but not necessarily use them for the final drawings. So I am not sure if I'll ever get to the total BIM model concept or need it.
              • mariochaM Offline
                mariocha
                The download is only from the site http://www.formation-sketchup.quebec. It is kinda quick and discreet. Have you checked your folder ?
                Update: NOT NEEDED ANYMORE, so removed
                %(#008000)[Mario C.
                • mariochaM Offline
                  mariocha
                  Walls as single volume is the first step, for me. Once all windows and doors are in, I use Fredo Joint PushPull to add inner material faces.
                  %(#008000)[Mario C.
                  • mariochaM Offline
                    mariocha
                    UPDATE
                    See V8.4 video at beginning of post.
                    %(#008000)[Mario C.
                    • N Offline
                      neil_M58
                      new user. how do you change units to metric?
                      • mariochaM Offline
                        mariocha
                        Once SketchUp is set to metrics, just enter your metric values in the dialogs, they will replace the default values.
                        %(#008000)[Mario C.
                        • mariochaM Offline
                          mariocha
                          This plugin is now Renamed to Sketch-Int
                          and moved to SketchUp Extension Warehouse.
                          %(#008000)[Mario C.
                            dtrarch
                            Sounds like a good idea for a plugin but a trial is always a good thing to view first.
                            It is installed but???
                            The trial email to validate does not show up in my mailbox after multiple tries to have it sent?
                            I would hate to pay and have the same thing happen again.
                            Is pay to play the only option that works to validate.?
                            OK with me but need to know please.
                            dtrarch
                            • mariochaM Offline
                              mariocha
                              Sketch-Int will be available soon on SketchUp EW, trial also.
                              %(#008000)[Mario C.
                              • pbacotP Offline
                                And on SketchUcation? What's the name about?
                                • mariochaM Offline
                                  mariocha
                                  Well, the licensing will be managed by EW, so it has to be downloaded from there. here there could be a link.
                                  %(#008000)[Mario C.
                                  • N Offline
                                    neil_M58
                                    I am using with Sketchup 2017 on Mac. Worked OK at first, but now crashes or locks up. When trying to create a new door, an INFO window opens with a link to tutorial video, initially when closed this was replaced by the door dimensions etc window but know it just prevents me from selecting anything.
                                    • mariochaM Offline
                                      mariocha
                                      Hum... strange. Is this only with doors, exterior or interior ?
                                      %(#008000)[Mario C.
                                      • N Offline
                                        neil_M58
                                        Happens with all options.
                                        • mariochaM Offline
                                          mariocha
                                          New version !! with EDIT items.
                                          and more.
                                          See first post.
                                          %(#008000)[Mario C.
                                          • mariochaM Offline
                                            mariocha
                                            Brand new version of Sketch-Int available on SketchUcation Store !
                                            New way to edit
                                            %(#008000)[Mario C.
                                            • 2 / 3
