    FlexTools Updates
    Scheduled Pinned Locked Moved FlexTools
    renderpluginsextensions
    168 Posts 17 Posters 342.8k Views 17 Watching
    • halroachH
      halroach
      https://flextools.cc/wp-content/uploads/2019/04/fixed-window_01_01e.gif
      A Fixed Flex Window
      It's similar to the original FlexWindow, but it is a lot simpler.
      Read more details in the FlexBlog: https://flextools.cc/blog/3-new-flex-windows/
      FlexTools - Super Quick Windows, Doors, Slats...
      • halroachH
        halroach
        We started working on FlexStairs!
        Here is a work-in-progress video:
        • The stairs are recalculated while scaling according to the restrictions you enter (based on Blondel's Rule).
        • The top step can be hidden.
        • You can set a minimum riser height.
        • You can also set a fixed tread length.
        To be continued... 😄
        • jujuJ
          juju
          Personally I’d say that if the tool does the various possibilities structurally it should be fine as longs as components are used. The range of possibilities for balustrades and handrails together with inlays, finishes, nosings, etc. is so wide that I’d rather take the time to customize the components particular to the application than try to fiddle with numerous settings to see what it comes out like only to end up doing a partial custom job anyway. Remember to work in landings and being able to set governing parameters for that.
          • Epix3DE
            Epix3D
            Where can I find wooden double doors like in gif?
            https://sjc1.discourse-cdn.com/sketchup/uploads/default/original/3X/8/1/810cb8d05dc3dff79482b6b160b78fed6d186963.gif
            Also in my(Activated)ComponentFinder text is red when searching and doesn´t work.?
            • halroachH
              halroach
              Hi Epix,
              The components in that animation were all components I created with the Flex components as a base.
              1. Pull in a FlexDoor component.
              2. Change the door to a double door in the component options window - double click into the component and then select it to reach the correct options window and change number of doors to 2.
              3. Change the handles with handles from the 3DWarehouse and then recalibrate their location with the interact tool.
              4. Add which ever wood material to the sub-components you want.
              1. You can then save the component with component finder for later use:
              The red text appears if nothing comes up when searching. Since it appears you have no folders open it won't find anything for sure. Add a few folders and then search through them and it should work as expected.
              Please let me know how it works out.
              • halroachH
                halroach
                https://flextools.cc/wp-content/uploads/2019/06/FlexSlope_02-785.gif
                FlexSlope
                New FlexSlope Component easily calculates ramps, car parks, roofs etc.
                The original, simpler beta version is available for free download at the FlexLabs.
                See more details at the FlexBlog.
                • halroachH
                  halroach
                  https://flextools.cc/wp-content/uploads/2019/06/colonial-divisions_02_05.gif
                  You can now also specify the number of divisions in Colonial Style Distributions.
                  More updates in our Blog: https://flextools.cc/blog
                  • jujuJ
                    juju
                    I tried once last night and twice today, this update is not installing via the FlexTools Manager. It keeps on showing the update is available, even after restarting SU and after restarting the machine.
                    • halroachH
                      halroach
                      Hi Juju,
                      1. Hmmm, what happens when you update? Does it show it downloading and installing or nothing happens?
                      2. Are you getting any error messages?
                      3. Anything in the console? Window > Ruby Console
                      4. Please send any log files you find to yoni@flextools.cc:
                        C:\ProgramData\F3d_FlexTools\logs
                      I'm available on the flextools.cc chat now if you have the time and we'll figure out what's going on.
                      • jujuJ
                        juju
                        I've sent an e-mail to the address provided in the post above.
                        • halroachH
                          halroach
                          Got it! we're looking into it.
                          • halroachH
                            halroach
                            It seems like it's a permissions issue. We saw this a couple times before. We sent you the step by step solution by email.
                            Let us know how it works out.
                            • jujuJ
                              juju
                              Problem solved, thanks for the rapid feedback on a solution!
                              • halroachH
                                halroach
                                FlexStairs released! 🎉 🎉 🎉
                                We’re proud to present you with FlexStairs v1 - the fastest stairs ever!
                                Scale the stairs from floor to floor and they automatically adjust according to your requirements.
                                https://flextools.cc/wp-content/uploads/2019/07/FlexStairs-Blog-post-cover-gif-e.gif
                                Learn more at the FlexBlog
                                • pbacotP
                                  That looks awesome!
                                  • halroachH
                                    halroach
                                    Have to figure out some steps? - No worries.
                                    FlexStairs will do the math for you! 😄
                                    See how FlexStairs work in this short introduction video:
                                    Learn more at https://flextools.cc/learn/flexstairs
                                    • halroachH
                                      halroach
                                      One click landing! Coming soon.
                                      https://app.getbeamer.com/pictures?id=40690-77-9FGVpA--_vVVW77-9U056EHoD77-977-977-977-9VUpkSX3vv71qQ1V3zq7vv70.
                                      • halroachH
                                        halroach
                                        FlexStairs in 2 minutes:
                                        • halroachH
                                          halroach
                                          https://flextools.cc/wp-content/uploads/2019/08/flex_components_04_09-faster-750-e.gif
                                          Quick demonstration of FlexTools in action
                                          • halroachH
                                            halroach
                                            See how you can create different types of dynamic windows and doors by combining a few flex components in our latest blogpost.
                                            • 5 / 9
