    Sketchup pro 2017 - crashing with window flashing
    18 Posts 2 Posters 11.9k Views 2 Watching
      Since this only started recently, you need to look at what has changed on your computer. SketchUp 2017 hasn't been changed in a couple of years so what did change? What is the graphics card? Have you checked with the card's manufacturer to see if there's a recent driver update and installed it?
      • T
        tsomek
        Hi and thanks for the feedback.
        I've been trying to switch off any of my plugins (especially the new ones, like you suggested) and see any difference in the behaviour.
        After having gone through all of them, the problem still persists.
        Now, in the meantime I DID notice that while I am working on a file, the program becomes slower and slower over time, until it ends up crashing..
        Does this maybe indicate something to anyone?
        It almost seems as if something "fills" up slowly until it can't take it any more..
        Any clues on what this could be?
        Many thanks for any help
          What graphics card?
          Do you have a 3D Conexxion device connected.
          • T
            tsomek
            GeForce GTX 1060 6GB
            No 3D Conexxion devices..
            • T
              tsomek
              Hi again,
              Quick update. Still facing the same issues.
              Also wanted to describe the symptom a little more: When sketchUP starts slowing down, the actions that visibly slow down are selecting objects, switching tools (from selecting to drawing a line, a circle etc)
              After a little while working under these conditions, it finally crashes..
              Re-opening the same file makes everything normal and snappy again..
              Any ideas?
              Many thanks
                Have you checked to see that SketchUp is actually using the Nvidia graphics card? What you describe sounds like a common issue with integrated graphics cards. Windows updates have been known to change the default graphics to the integrated Intel graphics. Updates also commonly include broken Intel graphics drivers. It would also be a good idea to go to the Nvidia site and update the graphics drivers for that card.
                Do you have Fast Feedback enabled or disabled?
                BTW, your profile indicates you are still using SU2014. Perhaps you could update that, please?
                • T
                  tsomek
                  Hi Dave,
                  Thanks for your reply.
                  Yes, the card does appear like this:
                  http://i63.tinypic.com/1zo947q.jpg
                  Fast Feedback is enabled. Also 4x Antialising.
                  Also, I'm pretty confident I have the latest NVidia drivers installed.
                  Can I maybe add that I have the same issues on a different machine, again running an NVidia card..
                  Many thanks
                  PS. Had just updated my profile, before reading your post πŸ˜‰
                    Interesting. I have SketchUp running on four different machines all with Nvidia graphics but I've never had this happen.
                    You could try running with Fast Feedback disabled and see if there's any change.
                    When you installed SketchUp, did you right click on the installer and choose Run as administrator?
                    What extensions do you have running?
                    • T
                      tsomek
                      Hmm, didn't run as admin I think.. though, is this actually possible, without admin?
                      I think I remember Windows asking for admin rights..
                      Will give Fast Feedback a pause and let you know!
                      Re extensions please screenshots below
                      http://i64.tinypic.com/4uxaw3.jpg
                      http://i67.tinypic.com/35k8iv6.jpg
                        To correctly install Sketchup on Windows you have to sign in to Windows under your normal user but then right click on the installer and select Run as administrator. This is different than your user having Admin rights.
                        At least to make sure, you could reinstall SketchUp using Run as administrator and select the Repair option.
                        Also see what happens if you disable Vray. It's been known to be a bit of a hog.
                        • T
                          tsomek
                          Thanks so much for the advice
                          I will now
                          • test Fast Feedback disabled
                          • reinstall SU as Admin
                          As for disabling Vray, it's not really an option, since it's very much part of my workflow.
                          Any advice on which Vray Version is more resource-friendly and/or more reliable?
                          I'm considering biting the bullet and upgrading, but wanted to check if it's worth the spend.. especially given I'm not missing any functionalities with 2017 and Vray 3.4..
                            I'm only suggesting that you disabled Vray to do some testing. Clearly if it is causing the problem, it shouldn't be a part of your workflow but you should find out. You could leave it disabled throughout most of your modeling and only enable it when you actually need it.
                            As for which version of Vray, I think the best thing there is to check with the folks at Chaos Group. I would expect your best bet would be to upgrade to SketchUp 2019 anyway and then get the latest version of Vray.
                            Personally I've never been a big fan of Vray and I've seen loads of reports of problems related to it. If I was choosing a renderer right now, I guess I'd be looking at others like Thea.
                            • T
                              tsomek
                              Hi again,
                              Quick update and request for help...
                              I uninstalled everything, and tried to reinstall SU as Admin, as per you recommendations.
                              Now for some reason the sketchup file thumbnails are broken.. πŸ˜’
                              Any ideas how to get this to work again? 😳
                              • T
                                tsomek
                                PS. I was able to get the thumbnails to work again just by re-assigning SKP files to be opened by sketchUP 2017..
                                  What about the crashing? And did you try disabling Vray?
                                  • T
                                    tsomek
                                    Basically all previous things haven't changed a thing.. still having the crashes.
                                    Now I reinstalled everything, just added the very bare of extensions necessary, including Vray and will give it a day or two to see how it goes..
                                    Will keep you in the loop!
                                      Good luck.
                                      I think if you are still seeing crashes, Vray is the next suspect. Other people have reported issues with Vray so it's a good one to check.
