    3D Truss Models
    1.5k Posts 31 Posters 977.2k Views 30 Watching
    • medeekM Offline
      medeek
      ***** The Medeek Truss extension will no longer officially support SketchUp 2015 and SketchUp 2016, only SketchUp 2017 and newer will be supported. *****
      I have reluctantly made this decision based on the additional time and effort I am spending trying to put in place additional logic (band aids) within the code base to ensure that the plugin maintains compatibility with these older versions of SketchUp. At some point it is simply no longer worth the effort.
      If you are plugin user currently running one of these older versions of SketchUp, I would strongly suggest that you upgrade to ensure continued operation of the extension. The current version of the extension will probably still work with either SketchUp version however moving forward there will be no guarantee of compatibility.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • pbacotP Offline
        The angled soffit (soffit applied parallel to rafters at both low eaves and gable eaves is a common feature of ca 1900 houses out here in California, farm houses and Victorians.
        • jujuJ Offline
          juju
          It's probably a good idea to keep a downloadable file of the last compatible version available for those that are still running the now unsupported SU versions?
          • medeekM Offline
            medeek
            Looks like Justin has featured the plugin in a demo of Quantifier Pro:
            It would have been better if he had turned on the gable truss option in the global settings but regardless I appreciate the featuring of the plugin.
            Justin does a nice job with those videos.
            design.medeek.com
            • medeekM Offline
              medeek
              Working on the edit menu for the shed rafter roof. If the user enables soffit and fascia for this roof type I will need a small routine that checks the rafter depth and trims the upper rafter tails if the rafters are deeper than the barge rafter (rake board):
              http://design.medeek.com/resources/trussplugin/images/truss_su431_800.jpg
              For the lower end rafter tails the soffit cut parameter takes care of this problem, however with an angled soffit I will need a similar routine for the lower rafter tails as previously discussed in a post a few days back.
              Roof returns (rake, hip and full) have not been enabled for rafter roofs yet, that is something that will need to be setup for this module as the truss module already has this feature.
              A number of other upgrades for this roof type as well: Front and Back gable overhangs, Roof cladding extension.
              design.medeek.com
              • medeekM Offline
                medeek
                Version 2.4.4 - 06.05.2019
                • Enabled soffit and fascia for shed rafter roofs.
                • Enabled a roof cladding extension parameter for shed rafter roofs.
                • Enabled the "Edit Roof Assembly" function for shed rafter roofs (imperial and metric units).
                • Added the option in the shed rafter roof edit menu to specify a separate front and back overhang length.
                • Shed roofs auto-trim upper rafter tails as required when soffit is specified.
                http://design.medeek.com/resources/trussplugin/images/truss_su432_800.jpg
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 2.4.4b- 06.06.2019
                  • Enabled gable and angled soffit & fascia for shed rafter roofs.
                  http://design.medeek.com/resources/trussplugin/images/truss_su433_800.jpg
                  http://design.medeek.com/resources/trussplugin/images/truss_su434_800.jpg
                  http://design.medeek.com/resources/trussplugin/images/truss_su435_800.jpg
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 2.4.5 - 06.07.2019
                    • Fixed a minor bug with the shed rafter roof module.
                    • Enabled gable and angled soffit & fascia for all gable rafter roofs.
                    http://design.medeek.com/resources/trussplugin/images/truss_su436_800.jpg
                    http://design.medeek.com/resources/trussplugin/images/truss_su437_800.jpg
                    View model here:
                    3D Warehouse
                    (3dwarehouse.sketchup.com)
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      I've beaten soffit and fascia to death but there still remains more to be done.
                      The gable and angled option still need to be made available with the truss module. Additionally I have not yet enabled soffit and fascia for hip truss sets as well as other more exotic truss types.
                      Note that soffit and fascia can only be enabled once the roof or truss assembly is created (within the edit menu). This is on purpose. Only those truss or rafter families that have the edit function available can have soffit and fascia enabled.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 2.4.6 - 06.08.2019
                        • Enabled gable and angled soffit & fascia for common, attic, scissor, and cathedral trusses.
                        • Enabled gable and angled soffit & fascia for monopitch trusses.
                        http://design.medeek.com/resources/trussplugin/images/truss_su438_800.jpg
                        http://design.medeek.com/resources/trussplugin/images/truss_su439_800.jpg
                        http://design.medeek.com/resources/trussplugin/images/truss_su440_800.jpg
                        http://design.medeek.com/resources/trussplugin/images/truss_su441_800.jpg
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 2.4.6b - 06.08.2019
                          • Added the ability to import materials directly from the model within the Custom Material Libary/Manager in the global settings.
                          This update was per customer request. The direct material import feature previously was added to the Wall plugin but was missing from the Truss plugin.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            This is the first new icon for the main Truss plugin toolbar in quite some time:
                            http://design.medeek.com/resources/images/truss_su_menu_active.jpg
                            The complex roof icon/tool will allow the user to pick between either a truss or rafter complex roof (first HTML menu), then the user will select a horizontal (closed) face which will be used to determine the perimeter of the roof. Before the user selects the outline face they can utilize the complex roof draw menu (HTML menu #2) to adjust settings (ie. overhang, pitch, sheathing, cladding etc...)
                            The draw menu will stay open and the tool active until closed or space bar is pressed. So multiple complex roofs can be created one after another with the given settings. Similar to the wall plugin I will probably implement a system of roof presets so the user can quickly jump to a specific configuration.
                            My latest code for menus in the Electrical plugin is my cleanest and most advanced code for dealing with interactive HTML menus. I will be borrowing heavily from this plugin initially to setup my basic tool and menu systems.
                            I will also at some point allow the user to select the points that define the roof outline rather than selecting a face but for the time being I'm going to keep it simple and just allow the face selection method for now.
                            I am starting with the complex rafter roof first. The truss variant will be even more troublesome and problematic so its best to cut my teeth on the rafter variant and see how far I can take it.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              The first menu will use the following two images to select either a rafter or truss roof:
                              http://design.medeek.com/resources/images/COMPLEX_ROOF_RAFTER_240.png
                              http://design.medeek.com/resources/images/COMPLEX_ROOF_TRUSS_240.png
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                First look at the initial selection menu:
                                http://design.medeek.com/resources/trussplugin/images/truss_su442_800.jpg
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  When you initially create the complex rafter roof all plate heights, rafter depths, pitches and birdsmouth cuts will be the same for each eave/roof plane. Then I would like to have a system whereby the user can potentially edit each and every eave, changing up these parameters as they desire as well as switching certain hip planes to gable or vice versa.
                                  Additionally it will be useful to have a system wherein you can also edit the underlying outline that defines the entire roof. This latest module is not going to come easy but if I can pull it off it will be a very nice tool.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 2.4.7 - 06.13.2019
                                    • Enabled a "No Framing" mode for gable, hip and shed rafter roofs. This feature is also available for asymmetric gable and hip roofs.
                                    • Added the complex roof icon to the main toolbar.
                                    http://design.medeek.com/resources/trussplugin/images/truss_su443_800.jpg
                                    http://design.medeek.com/resources/trussplugin/images/truss_su444_800.jpg
                                    The "no framing" mode is per customer requests. I'm really not sure how much utility this features offers but it certainly will keep your model more lightweight if you choose not to show all of the rafter framing.
                                    I also added this parameter in preparation for the upcoming complex roof module. With complex roofs the ability to eliminate all of the underlying framing will be a much bigger factor in my opinion.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      View comparison models here:
                                      3D Warehouse
                                      versus:
                                      3D Warehouse
                                      After your purge the models there is not really a huge difference in file size between the two.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Just an FYI, some of the recent updates have managed to break a few things in the metric side of the plugin. I will be working on these issues all of today (and tomorrow if necessary) and release the fix later this evening or Saturday morning. I apologize for the inconvenience.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Version 2.4.7b - 06.14.2019
                                          • Addressed a number of critical bug fixes for metric templates.
                                          If you are working with metric units this update will address a number of issues that were not resolved when the edit function was added to various trusses and rafter roofs. This is an essential upgrade.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Still trying to get the complex roof module up and running but every time I try and refocus some other fire comes along and pulls me sideways. The soffit and fascia module introduced another block of parameters which need to be exposed in the global settings so users can set their default behavior, this is a relatively easy addition. I will knock this one out sometime later this evening.
                                            With the Wall plugin I also have a huge list of items but a couple which are actively being requested are stacked windows and a custom offset parameter for the stud spacing. I really should hop back into the Wall plugin and try to address these before I get re-focused on the complex roof module.
                                            The recent metric fix will be a welcome upgrade/resolution for many of you using metric templates. Again, I apologize for not spending as much time as I would like on debugging the metric side of the house. I will try to make a more concerted effort to check the metric side moving forward.
                                            design.medeek.com
                                            • 66
                                            • 67
                                            • 68
                                            • 69
                                            • 70
                                            • 75
                                            • 76
                                            • 68 / 76
