    Weird mesh
    renderpluginsextensions
    3 Posts 3 Posters 11.2k Views 3 Watching
    • V
      valsenator
      Hi everyone,
      I tried Ixlrlxi aka 600v aka SketchUp god SubD tutorial (https://3dwarehouse.sketchup.com/model/276574de12315fa9174441d8b698e801/tutorial-car-model-before-subdivision-and-after)
      Well, the orange side is the original but when I tried to SubDivide the test part, the mesh looked weird and definitely not as it is supposed to be.
      Any idea why? Can you please help me figure this out.
      • tuna1957T
        tuna1957
        Problem your having is the test model you downloaded was created using the "Artisan" plugin, not SubD plugin.
        You can fix the "proxy" so SubD will work properly. Essentially soft-smooth the diagonals of the roof and body proxies and run the QuadFace Tools "convert sandbox quads to quad face quads" function. SubD will then work properly.
        A warning ..... the proxy wasn't modeled with SubD in mind so you will end up with a few triangles here and there in the body proxy.
        Posting a screen shot of the fix I've described. I copied the proxies and made them unique so you can compare the fix for using SubD to the original.
        • pbacotP
          Can't ask for better help!
