    U Place Text Tool on a Line And Get the Dreaded 'Enter text'
    15 Posts 4 Posters 3.7k Views 4 Watching
    • BoxB
      The trick is to click on the green endpoint marker. If the tip of the text tool is off that point, even though it is showing, it will say enter text.
      • Joe WoodJ
        Joe Wood
        ah Ha Box, that might be the trick, I'll give it a try tomorrow πŸ™‚
        EDIT
        nope, I put the arrow part right on the green endpoint and no joy. If I zoom in it might work sometimes, other times it seems like if I do a slow click it'll work.
        how are you recording your screen Box?
        Joe Wood
        woodsshop.com/
        • BoxB
          Many people use Licecap, I use gifcam but wouldn't recommend it generally as it is very unstable.
            slbaumgartner
            It's a subtle aspect of the text label tool, arguably a bug. The inference engine detects an endpoint near the cursor and highlights it green with tooltip, telling you that point is being used for inference. But the text label tool doesn't actually anchor to that endpoint unless it is within the invisible "capture aperture" of the cursor! This can indeed be a frustrating and seemingly erratic behavior!
            • Joe WoodJ
              Joe Wood
              Yeah I can't figure it out, I couldn't make that Licecap work so can't show you.
              where is this 'capture aperture', can someone show it to me?
              Joe Wood
              woodsshop.com/
                slbaumgartner
                The display screen is a raster made up of pixels. Likewise, the cursor is displayed as a raster icon made up of pixels. One of the pixels in the cursor (typically lower left) is designated as its "hot spot". You select by placing the cursor over a target in the model and then clicking the mouse.
                But that selection action takes place on the user's display, where the continuous model contents are rendered as finite pixels each of which, depending on zoom, can represent a variable amount of model space. So, SketchUp needs a way to decide whether something in the model was meant to be under the hot-spot when you clicked. To allow for human ability to place the cursor exactly and also for the finite pixels of the display, SketchUp has a small window or aperture around the cursor's hot-spot in which it looks for something you might have meant to select. When it finds such content, the pick "snaps" to its location. There is no way to view or modify this aperture via the GUI.
                In many tools, the green highlight on an inference point means that is where the pick point will snap when you click. On the text tool, this is not the case and since you can't see the aperture you have to be extra careful where you click.
                • Joe WoodJ
                  Joe Wood
                  What a great explanation Slb! But I still don't understand where that point is. Could you draw that little pointer and show where the magic point is?
                  Joe Wood
                  woodsshop.com/
                    slbaumgartner
                    The location of the hot-spot can vary from cursor to cursor, though it is most often at the lower left. In the specific case of the text tool, it is at the tip of the little arrow from the box labelled "A1" in the cursor. You need to place that arrow tip right over the dot in the middle of an endpoint inference marker to be sure that you will get a "leader text" anchored to that point (and automatically filled with its coordinates) rather than a "screen text" anchored to the display (initially saying "user text"). Yes, it can be fussy to hit that spot accurately, and all of us sometimes have to try again to get leader text instead of screen text.
                    • Joe WoodJ
                      Joe Wood
                      yeah I'm really trying to figure it out now, but at least knowing I'm not the only one helps some πŸ™‚
                      Joe Wood
                      woodsshop.com/
                      • Joe WoodJ
                        Joe Wood
                        I figured it out I hope!
                        when I put the little hooked pointer right on the endpoint I get the 'Enter Text',
                        but when I move the little pointer to the right of the endpoit just a bit it works as it should πŸ™‚
                        you can't see the little pointer in this s shot but it's just to the right.
                        Joe Wood
                        woodsshop.com/
