    [Plugin] ConsDeleteContext
    8 Posts 4 Posters 10.9k Views 4 Watching
      Author : TIG
      Usage : Deletes or Layers Guide-Lines or Guide-Points or Both:
      accessed through the Context-menu/submenu:
      it either deletes/layers 'All Active' or 'All in Selection/ALL' -
      mining down into any selected groups/components...
      If you pick a 'Selection' option BUT without anything selected then
      ALL 'model entities' are processed! [Note: a context-menu will still
      appear with NO selection, if the cursor is over an axis etc...]
      It's one step un-doable [or two steps if Both Lines/Points option]...
      https://sketchucation.com/pluginstore?pln=ConsDeleteContext
      • CadFatherC Offline
        CadFather
        ..just to say thanks TIG! πŸ˜„
        • JClementsJ Offline
          JClements
          My thanks as well.
            Here's v2.0 http://forums.sketchucation.com/viewtopic.php?p=100581#p100581
            • designerbursaD Offline
              designerbursa
              Moving points to layer did not work. The plugin's code needs to be edited as follows! ..
              old code
              def self.layerAllGpoints()
              model = Sketchup.active_model
              entities = model.active_entities
              model.start_operation("layer active Gpoints")
              model.layers.add("CPOINTS")
              entities.to_a.each{|entity|e.layer="CPOINTS" if e.valid? and e.class==Sketchup::ConstructionPoint}
              model.commit_operation
              new code
              entities.to_a.each{|e|e.layer="CPOINTS" if e.valid? and e.class==Sketchup::ConstructionPoint}
                Thanks, this code is almost 8 years old !
                No one has spotted that typo before - well done...
                A more 'modern' fix for the wayward line might be:
                entities.grep(Sketchup;;ConstructionPoint).each{|e|e.layer=model.layers.add("CPOINTS")}
                Avoiding the need to first make the layer at all !
                  designerbursa
                  I was very happy if I could help. I'm waiting for you to update the plugin πŸ˜„ thanks TIG πŸ‘
                    I've corrected the RB file previously found in the first post - https://sketchucation.com/forums/viewtopic.php?p=100581#p100581
                    I've republished its RBZ in the PluginStore as v2.1
