    Divide
    4 Posts 2 Posters 6.1k Views 2 Watching
    • Epix3DE Offline
      Epix3D
      In 2018 when you rightclick to divide a line a yellow box appear telling the measure of each segment..
      This does not work in 2019..?
      I need this function to work
        This works fine for me in v2019, just as it did in earlier versions.
        Do you have any other issues ?
        Could be related to your Graphics Card drivers needing an update, or perhaps v2019 was not installed properly ?
        To do a correct installation [or 'Repair' an existing one], do the following...
        Log into Windows as you usual user-account - as normal.
        Ensure that SketchUp is closed.
        Find the v2019 installer exe file - it's usually in your Downloads folder.
        Select its icon, right-click > context-menu > "Run as administrator"
        When prompted choose "Repair" [for a new/re-installation choose "Install"].
        When it completes restart SketchUp and see if that helped.
        Installing any complex app in any other way will cause unpredictable issues - these often relate to file/folder permissions, extensions and sometimes on-screen graphics.
        Never 'Run' and installer exe file by double-clicking it.
        Having administrator-powers attached to your normal user-account is not a problem, but it is also no substitute for running the installer in the proper manner, as set uput above...
        • Epix3DE Offline
          Epix3D
          Thank you TIG. Just remembered I am part of the Betatester program and it might be related to using a beta.
            You can still install a 'beta' version in the correct way...
            Or get the latest most current version and install that as I said.
            Whenever I might have installed a 'beta' version I've done it as I explained and I've never had such problems...
