    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.2m Views 254 Watching
      What settings do you have - compared to Dave's - which work ?
      Perhaps a screen-shot ?
      If you try it with the Ruby Console open are there any error messages ?
      Please be aware that this toolset is getting somewhat old...
      • E Offline
        Einstein
        I tried to generate fur with SketchUp 8 also but the same problem exists with the same set of non-working params.
        Working parameters: Density, MaxNumber, Stiffness, Divide (Main tab), all Jitters, ValidDistance (Detail tab).
        Non-working parameters: Length, RootWidth (Main tab), directions and forces (Detail tab).
        No matter what values I am using, errors show up. I tried similar values to Dave's but it didn't change anything.
        Example error in Ruby console when adjusting non-working params:
        Error: #<ArgumentError: Cannot convert "0.006" to Length>
        C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/FUR_EN/main.rb:2407:in to_l' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/FUR_EN/main.rb:2407:in s_to_l'
        C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/FUR_EN/main.rb:1398:in start_fur_test' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/FUR_EN/main.rb:1340:in show_webdialog'
        C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/FUR_EN/main.rb:2407:in `call'
        Additionally, when I adjust a non-working param and after that, a working param, also that working param starts to generate Ruby errors. Only when I restart plugin, I can use some of the params again.
          def s_to_l( tstr1 )
            if tstr1
              tstr = tstr1.to_s.gsub(/\~ /,"")
              return tstr.to_l ####### THROWS ERROR
          In the error-message tstr1 is "0.0006" so if you type this in the Ruby Console it should work:
          x="0.0006" x.to_l
          If that works I can't see what's up !
          • E Offline
            Einstein
            I should type in Ruby Console
            x="0.006"
            x.to_l
            where "0.006" is the value I adjusted with the slider; type it right after moving the slider, right? And then Make Fur.
            Sadly this still generates errors 😞
              This was not a FIX.
              I wanted to see what got returned when you set a reference to a string and then used .to_l to change that into a length...
              It should work in SketchUp >= 6 - particularly when tested outside of the main code.
              Fortunately your code in the Ruby Console shows the error.
              This should NEVER happen !
              What are your Model Info > Units set to ?
              A screen-shot might help.
              • E Offline
                Einstein
                My units are set to metres.
                  Try typing in values like 0.250m - rather than the bald 0.250, without a units suffix.
                  See if that helps ?
                  This is a mystery...
                  • E Offline
                    Einstein
                    Yeah! 😎
                    This is the point. Adding "m" suffix recovers the preview and makes creating fur possible. Sometimes the solution is so surprisingly simple and you wonder how you couldn't figure it out by yourself πŸ˜†
                    Thank you so much, TIG!
                    PS I still cannot use these sliders but this it OK. Typing values by hand is also good.
                      malthuviusrex8
                      I have a bit of a problem... The plugin was working perfectly fine for a bit, but then I must've either pressed some quick key accidentally or inadvertently changed an unknown setting, because suddenly now the grass isn't showing up; no preview, no end result, nothing.
                      I've moved a bunch of sliders trying to get it back, to no avail. The 'show preview' option is checked. I'm pretty sure it's not making the grass at all, since, when it does my slow pc will slightly lag, (this is aside from the fact that pressing 'Make Fur' does nothing) and now it shows no difference.
                      What the heck is happening?! πŸ‘Ώ I've tried changing many of the options in the dialog box... but nothing changes.
                      This was working perfectly fine, and is a wonderful plugin. I really could use help. πŸ’š
                      Thank you!
                        jeff1harmed
                        Thanks. I'm mainly using the crowd maker and I have found it very useful.
                        I've used it to make a jungle of kelp. This was straightforward although I had to play around with the parameters to get the correct density. (see https://3dwarehouse.sketchup.com/model/5b40a061-4125-4b12-9e11-f91b9f2dbbcc/salt-water-fish-props) Then I tried it on a shoal of fish and this was slightly different. With face-me components they all swim in the same direction, no problem. However, with 3D models I had to move them forward and behind manually, but the plug-in was still a big time-saver.
                        Then I tried the crowd maker on vegetables packed in crates. Again I had to move components into rough grids but It still saved time. (see https://3dwarehouse.sketchup.com/model/13bc63c0-f52f-4f63-85bc-a359adf7fedc/vegetable-props ). Very interesting plug-in.
                        I would suggest alphabetically ordering components in your drop down list. as in its current (first-in first out) state, it takes some time to find one amongst many.
                          MoonDragon2009
                          Hi, thank you so much for this add-on.
                          Since I saw that there are translations in various languages, I translated the language file into Italian, if you want to include it in the next version.
                          Nice work! πŸ‘Š
                          Italian language
                          • 29
                          • 30
                          • 31
                          • 32
                          • 33
                          • 33 / 33
