    Need help finding error-SU 2019
    8 Posts 2 Posters 1.1k Views 2 Watching
    • maxhouserocksM Offline
      maxhouserocks
      Hello, i have a plugin error occurring when starting SU 2019. it will close and i can work but i am wondering how i can figure out which script is trying to call the missing file.
      I have loaded all plugins through the Sketchucation extensions manager and the Su extensions manager. so i did not copy any old plugins folder data into the new one.
      Is there a way to use the Ruby Console to track this down?
      Error Loading File 3pt_Rectangle/3pt_Rectangle_main
      Could not find included file '3pt_Rectangle/3pt_Rectangle_main'
      Thanks,
      Bob
      Robert A. Christman
      http://rachristman.blogspot.com/
        I'd start by removing the plugin called 3pt Rectangle and see if the error message quits. You can disable it with the Sketchucation Extension Store tool or just go to the Plugins folder and delete it.
        Or better, remove it and install it fresh with the Extension Store tool. I just installed it in SU2019 and it works fine with no error message on start.
          maxhouserocks
          Thanks. Unfortunately, it seems like there is no plugin by that name installed.
          I am guessing that another plugin may be trying to load it??
          Not sure. Searching plugin folder doesn't bring up any key words.
          Robert A. Christman
            Did you look in the Plugins folder in User/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp? I don't know if the same author's 3pt Window relies on that file but perhaps you have that installed?
            The error message indicates the file I show selected can't be found.
            You could install 3pt Rectangle and see if that takes care of it. If another extension is looking for that file, it might actually work if it can find it.
              maxhouserocks
              yes. very strange. i wondered if it was related to 3d window...but i dont have that installed either.
              i used SU extension manager to load all things i had installed previously with my login account. I wonder if something came through but couldnt fully install?
              i cant find a 3 point rectangle extension, or i would install it to see it makes the error go away.
              Robert A. Christman
                maxhouserocks
                i installed 3 point window plugin just to see. restarted SU, same error.
                https://sketchucation.com/plugin/1341-3pt_window
                Robert A. Christman
                    maxhouserocks
                    oh boy.... i was searching "3 point" NOT "3pt"
                    thanks for taking the time to compensate for my, eh..lack of sleep πŸ˜„
                    I installed Pixero's 3pt rectangle and error is gone.
                    STILL
                    i have to wonder if it wasn't installed, why was i getting the error in the first place?
                    I used LAUNCHER to search installed plugins within sketchup also using all sorts of relevant keywords but nothing had come up. Oh well. Solved for now.
                    Thanks!!
                    Bob
                    Robert A. Christman
