    [Plugin] Toggle Units
    159 Posts 47 Posters 144.8k Views 47 Watching
      jimmylomax
      First, this extension is incredibly valuable for me. So many thanks for it! When I find things like this I feel stupid [face palm], I didn't seek it earlier... so much time wasted!
      2nd on feature request for presets. For example, it would be amazing if I could have/make three:
      1. decimal, mm, 0mm precision (sometimes I do my detailed work or reference other models)
      2. decimal, in, 0.000" precision (most of the time when I'm doing detail work, this is my preference)
      3. architectural, 0" precision (my output presentations are almost always feet and whole inches)
      • atelierpaarA Offline
        atelierpaar
        Hello
        I just installed SU 2019
        Unfortunately i get the following errocode :
        Fehler beim Laden der Datei C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Matt_Toggle_Units/Toggle_Units.rb
        Error: #<SyntaxError: C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Matt_Toggle_Units/Toggle_Units.rb:205: Invalid return in class/module body
        return if not settings.include?("tr...
        C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in load'
        C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Matt_Toggle_Units.rb:62:in register_extension' C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Matt_Toggle_Units.rb:62:in <top (required)>'
        anyone any idee how to fix this problem ?
        thanks for looking into the this
        Uli
          The newer Ruby version is unsympathetic to coding errors !
          Using a plain-text editor, like Notepad++, edit the file:
          Find line #205
          return if not settings.include?("true")
          Add an initial #
          #return if not settings.include?("true")
          Save the file and restart SketchUp, to test it...
          Other 'returns' in the code seem OK...
            atelierpaar
            Hello and good morning,
            thanks TIG, that was it. What a difference a # makes !!
            Toggle_Units works fine again.
            thanks again for your quick reponse
            Uli
            • W Offline
              wrc86
              Find line #205
              Add an initial #
              Perfect TIG thanks! it worked perfect on mac SKP2019
                sherman23
                Isit possible to show a tutorial process on doing the changes for Skp 2019. in a Picture format. Thanks
                  samyell77
                  Find line #205
                  Add an initial #
                  Amazing - thanks TIG!!! (and Matt666 for the original). Was really panicking as I couldn't find an alternative to this, really great to get it working on 2019!
                  SU Pro 2016
                  Dell Precision M4800
                  PC Windows 10
                  Intel Core i7-4900MQ @ 2.80ghz
                  Nvidia Quadro K2100M
                  16gb RAM
                    @sherman23 said:
                    Is it possible to show a tutorial process on doing the changes for Skp 2019. in a Picture format. Thanks
                    It really is a very simple editing process.
                    On a PC:
                    C:/Users/YOUR_USER_NAME/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Matt_Toggle_Units/Toggle_Units.rb
                    Note that folders in the user's AppData tree are hidden by default, but you can use the full-path text to the Plugins folder, pasted into a Windows Explorer window to open that location, then find the Matt_Toggle_Units subfolder, and RB file in there to edit.
                    Find line #205
                    Add an initial #
                    On a MAC:
                    Using a plain-text editor, like TextWrangler, edit the file:
                    The RB file's location is different on a MAC - it's actually easier to find the RB file in the SketchUp/Plugins Matt_Toggle_Units subfolder...
                    The subsequent editing & saving etc is the same...
                    Both of the text-editors are free and easy to install...
                    Tip: To open your Plugins folder directly - in SketchUp open the Ruby Console and paste this text:
                    UI.openURL("file:///#{Sketchup.find_support_file('Plugins')}")
                    • <enter>...
                      Makki
                      Hello Matt666
                      Love this extension very handy for changing digits from meter to millimeter
                      and visa versa. To see cubic meters in meters and not in millimeters in
                      ,,Entity Info,, and so on.
                      I'm now using Pro 2019 and it doesn't seem to be compatibel.
                      Any chance for an updated version soon 😄
                      Greetings Makki
                      • E Offline
                        erom
                        Hello, I encounter several problème and I can not run properly this plugin on SU 2019 on my mac: it lacks the unit mm! And that's the unit I use the most.
                        No mm icon
                        Here are the different ways I tried:
                        • I downloaded the version of Blajnov. But I have an error message when I install it.
                          error message
                        -I installed the original version with the sketchucation plugin and tried to edit the toggleunits.rb. But I can not find the line "return if not settings.include? (" True ")" with TextEdit
                        • I tried installing TextWrangler to edit the file. But this software no longer works with Mojave.
                        Can you help me? Or send me a rbz file that works?
                        Thank you so much.
                        Gildas
                        c'est pas un truc juste, c'est juste un truc!
                          Sorry for the confusion !
                          My mistake - I thought the recent ZIP file's author had packaged all of the files properly !
                          It will mess things up if it's made into an RBZ and installed !
                          If you have done so, then please open your Plugins folder and delete the following things - if they are incorrectly added into there - toggle_units_icons [folder], toggle_units.rb [file] and toggle_units.strings [file]...
                          • <enter>...
                          I've deleted the post with that problem ZIP, simply to avoid any future confusion...
                          I've now personally updated this tool's files to be compatible with all SketchUp verisons !
                          I've also signed its RBZ for all Loading Policies compatibility...
                          Please install the latest RBZ, which is now available from the PluginStore - v3.002:
                          it should now be compatible with ALL current SketchUp versions...
                          https://sketchucation.com/pluginstore?pln=Matt_Toggle_Units
                          • E Offline
                            erom
                            TIG, Thank you very much for your effort.
                            But I still can not install the plugin.
                            I uninstalled it from Extention Manager.
                            And I went to the library folder to check if the 3 files indicated were deleted.
                            Then installed v 3.002 from Sketchucation store
                            Then leave and relaunch sketchup.
                            And I have this message at the opening of sketchup:
                            Sorry for my incompetence. Thank you very much for yours.
                            Gildas
                              The incompetence is mine!
                              Somehow that old failing file sneaked into the latest RBZ...
                              I've re-updated the RBZ, so please re-download and reinstall it.
                              Restart SketchUp and it should work properly now !
                              • E Offline
                                erom
                                Great ! thank you very much Tig 😄
                                Now it works perfectly
                                • 8 / 8
