    Cast Iron and Other Metal
    9 Posts 5 Posters 2.4k Views 5 Watching
      This is a ceiling-hung bearing for an overhead line shaft based on drawings from the 1890s.
      https://live.staticflickr.com/7880/46811624544_668d8a0f40.jpg
      https://live.staticflickr.com/7843/47532806641_20bec11987.jpg
      Machinist's jacks or planer jacks.
      https://live.staticflickr.com/7920/40278668183_ffaa596478.jpg
      Tap wrench
      https://live.staticflickr.com/7927/39712526003_880d7e11c8.jpg
      https://live.staticflickr.com/4828/39712523723_bc9c6b2bfb.jpg
      • ntxdaveN
        ntxdave
        As always.……….good work! 👍
        Press F1...thank me later
          Marvelous, nicely done, Sir.
          • tuna1957T
            tuna1957
            When are you going to model something simple ? 😆 Great stuff as always 👍
            • L
              Yes beutifully done 👍 I wonder what a parellel projection view trying to emulate the original amazing old rendering would look like, acheived in sketchup 😉
                Well, this is simple.
                https://live.staticflickr.com/7908/33666187438_c996c70459.jpg
                https://live.staticflickr.com/7867/46627500785_a06e00dd8e.jpg
                And thank you, gentlemen.
                • L
                  Very nice 👍 👍 How did you achive the vignetting?
                    Thank you. The vignette and the texture were done with a couple of presets from Fotosketcher.
                      Having fun modeling these things from the late 1800s. Here’s a “rope pulley” which is a little over 5 feet in diameter. These were used with cotton rope to drive mills for spinning or fabric production. This one would have had four ropes each of which was spliced end to end to make continuous loops. Very quiet operation.
                      Here are a couple of similar wheels with a single cable wrapped around multiple times and spliced end to end to make one continuous loop. To get the cable from one side of the the large wheel to the opposite side of the smaller wheel, the cable runs up over the upper wheels which are set at angles to provide a good lead.
                      https://live.staticflickr.com/2463/3899589199_f97bcb41ac.jpg
