    3d chamfer: controlling angle of chamfer
    8 Posts 3 Posters 1.9k Views 3 Watching
      renandez22
      Problem: Fredo Corner defaults all chamfers on 3d objects (two surfaces meeting at an edge) to a 45 degree angle. Anyone know how to change this to a 25 degree or what tool can be helpful for 3d objects.
      (1001 bit tools allows for 2d control of lenght but not angle between objects/lines )
      thank you !!!
        This ?
          Hum seems not that you want...
          As you have an infinity of possibilities to have the same angle
          at different place so you must definite a point so...no need to input an angle! πŸ˜„
          You definite 2 Offset Lines
            renandez22
            How are you adjusting the X direction in the second GIF you posted?
              renandez22
              what round corner rbz are you using ? thank you !!
                renandez22
                I tried installing latest fredo round corner with fredo 6 update and I see an error "INVALID - no good edges on face" ? any idea. many thanks
                  Just click on it for input a distance or a % on the numeric key board
                  will be the same for the Z axe
                  (for Fredo : will be fine if we can move it with mouse! πŸ˜‰
                  Version used
                  Last version I suppose πŸ˜„
                  Impossible to answer without an skp file (save as V6)
                  https://i.postimg.cc/FzgQ2pTb/v6.jpg
                  • fredo6F Offline
                    For chamfer to work on corners with 3 edges or more (e.g. a true corner), the profile needs to be symmetrical.
                    If this is just to chamfer borders of a shape, then this is more a kind of followMe, and whether with the native tool or with Profile Builder by Whaat, you should make it with no difficulty.
