    20 Reasons for SketchUp artists to consider Blender
    144 Posts 27 Posters 86.3k Views 27 Watching
    • PixeroP Offline
      Pixero
      http://nd03.jxs.cz/922/611/579f325281_63036241_o2.gif
        Will become viral! 💚
        Who is the author? (Tarantino disappointed ? 🤢 or...
          rv1974
          UI. The main Reason for SketchUp artists NOT to consider Blender
          https://media.giphy.com/media/3o7qDMBRyiCkVTv0M8/giphy.gif
            Effectively, it's a another world! 😉
            • chippwaltersC Offline
              chippwalters
              @glenn at home said:
              @rv1974 said:
              Sorry but my impression is that this stage architecturalmodelling in Blender is a refined torture. The more Blender promos I see , the more I appreciate SU existance (with all its bottle necks).
              I really have to agree with this statement in regards to architectural modeling. The archimesh tool set video seemed very cumbersome and laborious. Now for general 3d modeling Blender is a GREAT option. Still loving these videos.
              I'd have to say, with emphasis, I agree. Blender 2.79 had this weird right-button mouse click, strange selection methods and overall REQUIRED you to learn literally a hundred keystrokes (no kidding!).
              B-U-T.... Blender 2.8 is really nothing like 2.79. They added professional UI designers, who went against all the Blender die hards and created a very simple- likable interface, that works how you would expect. Left click selects. You can drag select objects and polys and edges and verts. Even the navigation model (orbit, pan, zoom) is EXACTLY like SketchUp!
              After working with Blender, and modeling in SketchUp, it came to me there's a perfect fit here. Continue to model in SketchUp-- export with textures intact to the new Blender and do crazy fast photoreal renders and animations. I needed to create a course which helped SU users to do ONLY that-- and learn it quickly.
              As I said previously, I was BLOWN AWAY by the new Blender 2.8 EEVEE renderer where I can do an 8K render in 15 seconds (yes, you read that right, but it will take about 4 minutes to "bake" the lighting-- but you do that ONLY once). 3 minute animations are done, and color toned, with depth of field, light bloom, full reflections and photoreal in a couple hours. And of course it's all free.
              Not to mention you can export your models directly from SketchUp to Blender with the textures and mapping intact. And in Blender you can ADD new materials and textures WITHOUT having to go through the tedious process of UV mapping.
              And over the years, I've created over 60 free SketchUp tutorials, but I wanted to make sure this course would be special. I invited some top 3D artists, including the best here on Sketchucation to help test and give advice. The goal is to give you just what you need to import your models, texture them, light them, render them and animate them.
              Take this image for example. On the left is the original photo. On the right the one created in Blender (I also used fSpy to match the camera angle-- I have a FREE tutorial on how to do that at https://gumroad.com/chippwalters ).
              https://filedn.com/lLMW4jXsJqxXkRYjd1UCoKL/DefiniteEEVEE/kitchenOrigEEVEElg.jpg
              So, if you're interested, check the course out. I don't think you'll be disappointed.
              Currently working with Cross-Reality technologies
                Glenn at home
                Hey Chipp, I am starting to play a bit with SU2Blender. I brought in a model I did for a builder many years ago and just hit render to see what I get. I am seeing some "artifacts" in the basic render. Any ideas?
                TIA
                Glenn
                  chippwalters
                  Without seeing the .blend file, it's hard to say...
                    That is some amazing! ☀
                      Totally convincing! 😎
                        Speed Flow + Companion ready for the 2.80 😉
                          For the 2.80 the French Touch!
                            rv1974
                            If there's something of bad trip colors- Pilou is sold
                              chippwalters
                              A peek into what I'm currently working on for Blender...
                                db11
                                Chipp — does Kit Ops work on MacOS as well, or is it Windows only?
                                Also, I've ben trying to find the recommended min. system requirements for EEVEE — do you have any insight from your experience?
                                • pbacotP Offline
                                  Thanks Chipp, very tempting.
                                    chippwalters
                                    Yes, it works on Mac.
                                    I'd look over at Blenderartists.org for info on a min sys config for Mac.
                                    It now does support some Mac only configs, I just don't know enough about it.
                                      chippwalters
                                      Found this link
                                      Differences between Blender 2.8 for Windows and macOS?
                                      Hi, I haven’t tried Blender 2.8 yet, because of the early alpha stage it is in at the time I write this. But I’m eagerly anticipating switching to 2.8. I’m wondering though: will there be differences between 2.8 for Wi…
                                      Blender Artists Community (blenderartists.org)
                                        db11
                                        OK, thanks Chipp. I'll check it out.
                                          chippwalters
                                          Hey all! Just launched this product:
                                          It's called The Definitely EEVEE Materials System and it's the systematized approach to applying over 100 curated and popular materials to create photorealistic scenes and objects in Blender 2.8.
                                          It’s about creating great renders with over 100 customized materials, all based on a simple system-- so you can quickly and easily customize them ad infinitum! Plus it works without having to UV Unwrap meshes (and works doubly good if you have meshes that are already unwrapped).
                                          Plus there’s this really amazing DIRT GROUP NODE that allows you to add dirt in controlled ways to any material. And there’s the new Excalibur materials and so much more.
                                          Learn more at https://gum.co/EEVEE2
                                            db11
                                            Looks really cool Chipp. It's a great idea to have such a useful and comprehensive set of render-ready textures without the hassle.
                                            I haven't had much of a chance to explore Blender 2.8 yet, but once I've familiarized myself with the UI and basic functions I'm planning on buying your course. I would continue to (mostly) model in SU and then port to Blender for EEVEE rendering as you have advocated. Under that scenario, the need for a decent material set becomes obvious.
                                            What do you think would be a reasonable timeframe to allocate for mastering the basics of Blender and your SU to Blender workflow? (from pretty much a standing start)
                                            It looks like I'll have some time later this spring to finally dive into Blender and I'm curious as to how much time I'll need to invest to ramp up.
                                            • 5 / 8
