    20 Reasons for SketchUp artists to consider Blender
    144 Posts 27 Posters 96.9k Views 27 Watching
      Speed Flow + Companion ready for the 2.80 😉
        For the 2.80 the French Touch!
          rv1974
          @pilou said:
          Totally convincing! 😎
          If there's something of bad trip colors- Pilou is sold
          • chippwaltersC Offline
            chippwalters
            A peek into what I'm currently working on for Blender...
            Currently working with Cross-Reality technologies
              db11
              Chipp — does Kit Ops work on MacOS as well, or is it Windows only?
              Also, I've ben trying to find the recommended min. system requirements for EEVEE — do you have any insight from your experience?
              • pbacotP Offline
                Thanks Chipp, very tempting.
                  chippwalters
                  Yes, it works on Mac.
                  I'd look over at Blenderartists.org for info on a min sys config for Mac.
                  It now does support some Mac only configs, I just don't know enough about it.
                    chippwalters
                    Found this link
                    Differences between Blender 2.8 for Windows and macOS?
                    Hi, I haven’t tried Blender 2.8 yet, because of the early alpha stage it is in at the time I write this. But I’m eagerly anticipating switching to 2.8. I’m wondering though: will there be differences between 2.8 for Wi…
                    Blender Artists Community (blenderartists.org)
                      db11
                      OK, thanks Chipp. I'll check it out.
                        chippwalters
                        Hey all! Just launched this product:
                        It's called The Definitely EEVEE Materials System and it's the systematized approach to applying over 100 curated and popular materials to create photorealistic scenes and objects in Blender 2.8.
                        It’s about creating great renders with over 100 customized materials, all based on a simple system-- so you can quickly and easily customize them ad infinitum! Plus it works without having to UV Unwrap meshes (and works doubly good if you have meshes that are already unwrapped).
                        Plus there’s this really amazing DIRT GROUP NODE that allows you to add dirt in controlled ways to any material. And there’s the new Excalibur materials and so much more.
                        Learn more at https://gum.co/EEVEE2
                          db11
                          Looks really cool Chipp. It's a great idea to have such a useful and comprehensive set of render-ready textures without the hassle.
                          I haven't had much of a chance to explore Blender 2.8 yet, but once I've familiarized myself with the UI and basic functions I'm planning on buying your course. I would continue to (mostly) model in SU and then port to Blender for EEVEE rendering as you have advocated. Under that scenario, the need for a decent material set becomes obvious.
                          What do you think would be a reasonable timeframe to allocate for mastering the basics of Blender and your SU to Blender workflow? (from pretty much a standing start)
                          It looks like I'll have some time later this spring to finally dive into Blender and I'm curious as to how much time I'll need to invest to ramp up.
                            chippwalters
                            I'd give myself a few hours to watch the course for a quick grasp of the entire workflow. Do the same with the materials course (7 videos all well under 10 mins).
                            Then take a day and use the course as a guide to get you started. You should be able to have something up and running by the end of a days work.
                            Let me know if that works!
                              db11
                              That's good news and less time than I would have thought. If I can be comfortable and with a functional workflow after a week with Blender, then I would be very happy. If I could actually be producing useful output after a day or two, then hallelujah!
                              Using Bender (at least initially) primarily as a rendering pipeline seems like a relatively painless intro to the program, and once acclimated then I'll likely start playing more with other aspects of the platform. I also see it as a good hedge against SU Pro's increasingly uncertain and opaque future.
                              Looking forward to trying out your course(s) sometime in the next few weeks, and will let you know how it goes. Cheers!
                                rv1974
                                https://scontent.fsdv2-1.fna.fbcdn.net/v/t1.0-0/cp0/e15/q65/p320x320/56702249_2470975702934703_6566330269106700288_n.jpg?_nc_cat=110&efg=eyJpIjoiYiJ9&_nc_ht=scontent.fsdv2-1.fna&oh=708d17bdf8b3a340ad0451e4b5d43749&oe=5D07F0E2
                                nailed!
                                  With 30 minutes more...😉
                                  • jujuJ Offline
                                    juju
                                    @Chipp, aren't they looking for speakers for Basecamp 2020... 😜
                                      Glenn at home
                                      nailed!
                                      Bahahahahahahaha!
                                      • jenujacobJ Offline
                                        jenujacob
                                        Hi Chipp..
                                        Are you planning on releasing a 'Definitely EEVEE: Definitive Exteriors' course? Being an architect (who does not always indulge in interior design) I would like to do some quick exterior renders using blender and eevee (using HDRi etc). Or do you think it will be helpful if i get the 'Definitely EEVEE: Definitive Interiors' and apply the concepts for exteriors? (PS : I am not proficient in using blender and so that is why i am hoping for someone to guide me through the paces)
                                            jenujacob
                                            @pbacot said:
                                            I'm also interested, though my projects get into interior visualization as well. I think though that there were some issues mentioned in the course that indicated Evee is better suited for interiors. I'd like that explained. The course is worthwhile in itself, but I don't see its application to exteriors as yet. It might help you with blender 2.8 in general.
                                            Thanks! This is what i gathered from reading the course outline! Hopefully Chipp would chip in regarding this! 😉
                                            • 5 / 8
