    20 Reasons for SketchUp artists to consider Blender
    144 Posts 27 Posters 96.9k Views 27 Watching
    • chippwaltersC Offline
      chippwalters
      Quiet lately as I've taken on an interesting plugin project for Blender.
      As many of you may know, Blender doesn't really have a component system like SketchUp. That said, Blender's booleans are much more robust and combined with it's modifiers, it can create a pretty solid kitbashing system. In fact, boolean modeling which heretofore has only been seen in NURBS, is possible (with caveats) in Blender.
      To that end, I've partnered with some interesting folks and spearheaded a design for a pretty cool kitbashing tool called KIT OPS. KIT OPS could be used to create doors, windows and all sorts of boolean modifier geometry, but right now we're just doing tech INSERTS (KIT OPS INSERTS = SU COMPONENTS).
      One particular neat thing about KIT OPS, is it cuts through an entire object. So, if you're inserting a window or door through a wall, it cuts completely through, unlike SketchUp which only cuts through the first surface, requiring you to manually cut the rest. This also results in KIT OPS having a non-destructive workflow, which makes for a tremendous amount of iterative designs.
      Anyway, if you're interested, here's a video explaining it. BTW, the renders in the video were done at 15 sec/frame in Blender 2.8 EEVEE at 4K resolution! FWIW, KIT OPS works in 2.79 not 2.8, but once the plugin API is locked down, we'll do the port. This product should be out this week. I'll post here when it's released, just in case anyone is interested.
      Currently working with Cross-Reality technologies
        A cool one! Bravo! 😎
          chippwalters
          KIT OPS finally released!
          https://filedn.com/lLMW4jXsJqxXkRYjd1UCoKL/KITOPS/ko-hyper.jpg
          Hey everyone, we just released KIT OPS and if you're interested in non-destructive, hyperdetailed Kitbashing you should check it out at https://kit-ops.com
            rv1974
            What Ops stands for?
              A French challenger to make Blender more easy and friendly (if possible)! πŸ˜‰
              This one is not so bad! πŸ˜„
              Very Speedy indeed! (you can put the speed of vidΓ©o to 2 πŸ˜‰
              • PixeroP Offline
                Pixero
                http://nd03.jxs.cz/922/611/579f325281_63036241_o2.gif
                  Will become viral! πŸ’š
                  Who is the author? (Tarantino disappointed ? 🀒 or...
                    rv1974
                    UI. The main Reason for SketchUp artists NOT to consider Blender
                    https://media.giphy.com/media/3o7qDMBRyiCkVTv0M8/giphy.gif
                      Effectively, it's a another world! πŸ˜‰
                        chippwalters
                        @glenn at home said:
                        @rv1974 said:
                        Sorry but my impression is that this stage architecturalmodelling in Blender is a refined torture. The more Blender promos I see , the more I appreciate SU existance (with all its bottle necks).
                        I really have to agree with this statement in regards to architectural modeling. The archimesh tool set video seemed very cumbersome and laborious. Now for general 3d modeling Blender is a GREAT option. Still loving these videos.
                        I'd have to say, with emphasis, I agree. Blender 2.79 had this weird right-button mouse click, strange selection methods and overall REQUIRED you to learn literally a hundred keystrokes (no kidding!).
                        B-U-T.... Blender 2.8 is really nothing like 2.79. They added professional UI designers, who went against all the Blender die hards and created a very simple- likable interface, that works how you would expect. Left click selects. You can drag select objects and polys and edges and verts. Even the navigation model (orbit, pan, zoom) is EXACTLY like SketchUp!
                        After working with Blender, and modeling in SketchUp, it came to me there's a perfect fit here. Continue to model in SketchUp-- export with textures intact to the new Blender and do crazy fast photoreal renders and animations. I needed to create a course which helped SU users to do ONLY that-- and learn it quickly.
                        As I said previously, I was BLOWN AWAY by the new Blender 2.8 EEVEE renderer where I can do an 8K render in 15 seconds (yes, you read that right, but it will take about 4 minutes to "bake" the lighting-- but you do that ONLY once). 3 minute animations are done, and color toned, with depth of field, light bloom, full reflections and photoreal in a couple hours. And of course it's all free.
                        Not to mention you can export your models directly from SketchUp to Blender with the textures and mapping intact. And in Blender you can ADD new materials and textures WITHOUT having to go through the tedious process of UV mapping.
                        And over the years, I've created over 60 free SketchUp tutorials, but I wanted to make sure this course would be special. I invited some top 3D artists, including the best here on Sketchucation to help test and give advice. The goal is to give you just what you need to import your models, texture them, light them, render them and animate them.
                        Take this image for example. On the left is the original photo. On the right the one created in Blender (I also used fSpy to match the camera angle-- I have a FREE tutorial on how to do that at https://gumroad.com/chippwalters ).
                        https://filedn.com/lLMW4jXsJqxXkRYjd1UCoKL/DefiniteEEVEE/kitchenOrigEEVEElg.jpg
                        So, if you're interested, check the course out. I don't think you'll be disappointed.
                          Glenn at home
                          Hey Chipp, I am starting to play a bit with SU2Blender. I brought in a model I did for a builder many years ago and just hit render to see what I get. I am seeing some "artifacts" in the basic render. Any ideas?
                          TIA
                          Glenn
                            chippwalters
                            Without seeing the .blend file, it's hard to say...
                              That is some amazing! β˜€
                                Totally convincing! 😎
                                  Speed Flow + Companion ready for the 2.80 πŸ˜‰
                                    For the 2.80 the French Touch!
                                      rv1974
                                      If there's something of bad trip colors- Pilou is sold
                                        chippwalters
                                        A peek into what I'm currently working on for Blender...
                                          db11
                                          Chipp β€” does Kit Ops work on MacOS as well, or is it Windows only?
                                          Also, I've ben trying to find the recommended min. system requirements for EEVEE β€” do you have any insight from your experience?
                                          • pbacotP Offline
                                            Thanks Chipp, very tempting.
                                            • 5 / 8
