    โš ๏ธ Attention | Having issues with Sketchucation Tools 5? Report Here
    Virtual Wind
    9 Posts 6 Posters 14.7k Views 6 Watching
      steele404
      Im working on designing architectures and interior
      spaces and I need to simulate wind circulations
      through windows or around the building etc.
      VirtualWind is a CFD plugin for Sketchup which
      discontinued a while ago and that looked freaking
      sweet. Anyone still have a working installation
      file of VirtualWind?. What other alternatives
      is there for a good plugin to simulate wind flow,
      circulation (fluid dynamics) etc.
      ========= THREAD EDIT / UPDATED ON 10 SEP 2011 =============
      Okay, I got it to work. Although there are a few exceptions. I managed to
      grab hold of the trial version only, and it expires on 30 FEB 2010. Therefore
      you have to set your windows date before that expiry date. Pain in the ass but
      that's the only choice?
      VIRTUALWIND TRIAL EXE LINK (168MB): http://www.box.net/shared/cavyvg5ibu
      Download additional file fix (courtesy from TIG): http://forums.sketchucation.com/viewtopic.php?p=331981#p331981
      The above fix supposedly correct the ProgressBar class that is used in SketchUp, so it
      would not clash with the ProgressBar that is used in VirtualWind (VW).
      I am using Google Sketchup 8 and so far no errors were found. The plugin
      installed correctly with the available tools in SU.
      TIP / ADVICES:
      • Learn from the tutorial within the help document (3 different sets)
      • The VINE Viewer can only run a max of 1 CPU core. You need the PRO version
        to use more than 1 core to render the CFD faster.
      • It seems VirtualWind works far better with everything exported as "Canopy"
        than "Solids". Even building structures such as frames and pylons are better
        off being as Canopies. Make sure there are no intersecting geometries in
        Sketchup, and no floating points or lines.
      • You may need to use FINE wind quality if your geometry contains small
        openings (window openings in architectures, complex architecture with lots
        of frames, studs, etc) COARSE and MEDIUM quality are fine for simple shapes
        (ie building blocks, cars)
      USEFUL CASE STUDIES:
      • http://virtualwind-trial-unsw.wikispaces.com/
      Sketch up model borrowed from someone else
      My Test rendering using FINE quality with OrthoSolidSurface
      • numbthumbN Offline
        numbthumb
        Does this help?
        Comfortably numb...
        • TIGT Online
          Unfortunately the now discontinued 'Virtual Wind' screwed up several other tools because it ill-advisedly messed with some 'base classes'...
          I made a fix for this - see here... http://forums.sketchucation.com/viewtopic.php?p=331981#p331981 - as far as I know it still works ?
          I know nothing of the other 'recommended' tool...
            steele404
            grab hold of the trial version only, and it expires on 30 March 2010. Therefore
            you have to set your system date before that expiry date. Pain in the ass but
            TIP / ADVICES:
              openings (window openings in architectures)
            • TIGT Online
              steele404
              Please see my recent post about the 'fixed' file that I made because VirtualWind will break several other tools otherwise as it illadvisedly overwrote the progressbar class!
              • H Offline
                haydenr
                The exe file doesn't seem to be a trial version, just keeps asking for a .lic file??
                Any ideas??
                  steele404
                  Like I said in my first post... The setup installation file is a trial and expires on Feb 2010
                  therefore it will constantly asks for the LIC file and exits the program if you dont have one.
                  The solution is to set your windows date / time to anytime in January 2010
                  The program will run fine after you change your Operating system's date.
                  Don't forget to change your date back to the present day once you finish using VW.
                  • Didier BurD Offline
                    Didier Bur
                    Great find numbthumb ! ๐Ÿ‘
                    And as usual, thanks to TIG !
                    DB
                      Berense
                      First of all thanks for this great tool! but unfortunately I haven't got it to work with sketchup 2017 pro.
                      Hey guys has any one tried installing this recently? are there any tricks to it? it just says failed to install virtual wind plugin.
