    SubD shrinks the object
    renderpluginsextensions
    19 Posts 3 Posters 19.7k Views 3 Watching
      How would you apply this to an arbitrary mesh? A cube is quite a simple example. You describe you worked on the loops of the cube - but in an arbitrary mesh it's not going to be as clean and simple as a cube.
      • uwesketchU
        uwesketch
        Do you have an example mesh that you consider complex enough to play with? I wiill take that mesh and subdivide it manually to show / develop the idea.
          I can look for more, but here is one for starters: https://sketchucation.com/forums/viewtopic.php?f=397&t=63826#p584981
          • uwesketchU
            uwesketch
            I only did the Bell for now. But I hope it shows the idea/Concept.
            The task is to keep the dimensions of the objects the same but still making the surface smooth.
            For the bell this means that the sharp edges have to be smoothed and the less curved areas should be become round. As the less curved areas are the top of the bell.
            Bell FreThom subdivided
            • uwesketchU
              uwesketch
              I did some further testing with Catmull Interpolation. I found that in principle it works, but in the area of sharper edges/corners the Catmull Interpolation (by definition) will "inflate" the area on both sides around the edge/corner quite a bit. This could be solved in a similar way as in SubD where one can define a crease value.
              But instead of defining how an edge/corner shall be interpolated, there is another way to obtain smooth edges and corners without shrinking: FredoCorner.
              Combining FredoCorner and SubD in a workflow, will not solve the shrinking issue completely.
              But using FreeoCorner in areas where no shrinking shall apply and use SubD on top to smooth the remaining areas, is a good compromise giving a lot of flexibility in subdividing.
              An open point is, that FredoCorner does not (yet) offer a toggle on/off feature like SubD.
              @Thom: Not sure if there is a collaboration/exchange between you and Fredo, but this would be a perfect combination πŸ˜„
              My last question on this "shrinking" topic: Will or is there an option in SubD to exclude areas from being subdivided in a group/component? Like you can define a crease as infinitely sharp, an area enclosed by sharp edges could be excluded for instance.
                Yea, for cases where you only want bevel/chamfer then other tools like FredoCorner is better - provides a leaner mesh. Hard edge modelling with SUbD will leave you with lots of extra faces that isn't really needed. At least in the form SUbD have to work inside of SU - uniform subdivision.
                OpenSubdiv supports adaptive subdivision, but it's view based. Since SU doesn't have an API to override how an object appear it can't really be used for the purpose of SUbD.
                I know the old RoundCorner didn't. But I thought the new FredoCorner had an edit feature. Pretty sure I at least saw a function to revert bevel/chamfer.
                We talk. πŸ˜„ Some of his recent extensions are starting to have support for QuadFace Tools quads.
                Afraid not. Bridging the subdivided geometry with the not subdivided isn't really doable without artefacts. The shrinking effect of the subdivided mesh is one reason for this.
                Originally I created planar quads as a single face instead of two triangles - in an attempt to optimise the face count. But when you came to perform crease adjustments etc it'd be causing lag when the planar native quad had to be broken into triangles.
                • uwesketchU
                  uwesketch
                  Yes, there is an Undo/Edit function. Which is a great feature and a good starting point for a (global) Toggle On/Off like in SubD.
                  But such a toggle on/off is not there yet.
                  Another issue is, that when using SubD on a group/component where FredoCorner has been applied, the FredoCorner Undo/Edit does not work anymore. Seem like SubD overwrites some information used by FredoCorner.
                  Would be great, if both tools could work together. Kind of a "FreThom tool" πŸ˜„
                  I see. Then I have another idea (since the adaptive Subdivision feature from OpenSubDiv also cannot be applied in SU):
                  As an option selectable by the user in SubD, could you run at the end of the subdivision process the "remove triangulation" from Quadface tool and then the "Merge Faces" Tool from your CleanUp3 (or the "Remove coplanar edges" command from Fredos "EdgeControl" tool)?
                  Like this, the still planar faces after subdivision would not contain so many coplanar edges.
                  • BoxB
                    You mean something like this?
                    • uwesketchU
                      uwesketch
                      Yes, exactly.
                      But in a way, that afterwards you can toggle off the subdivision again.
                      I think when converting to a simple mesh, you cannot un-subd anymore.
                        I've logged that as an enhancement request. Need to investigate a but further regarding some techincal details of applying creasing when the mesh isn't all triangles.
