    Medeek Electrical
    206 Posts 6 Posters 278.2k Views 5 Watching
    • medeekM
      medeek
      @pbacot said:
      We are required to use a weather proof outlet that covers the plugs while in use. Perhaps a duplex a simple (minus curves) transparent lid should be provided. There are also gang boxes, some non transparent lids, but the first is most common.
      Maybe you wish to go over the whole GFI thing with an electrician. I have my knowledge, but I'm not an electrician so I'll keep it to myself.
      Does anyone have a model of a weather proof outlet (with transparent lid) that I could use as a starting point.
      The most up-to-date covers (NEC 2014) seems to be the Taymac MM420C and the MM2420C:
      https://www.hubbell.com/taymac/en/Products/Electrical-Electronic/Outdoor/Boxes-Covers-Plates/MM420C/p/1670831
      https://www.hubbell.com/taymac/en/Products/Electrical-Electronic/Outdoor/Boxes-Covers-Plates/MM2420C/p/1670822
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        It looks like I will need to add in one additional option, Weather Proof GFCI. It seems that this combination is fairly popular:
        http://design.medeek.com/resources/images/electrical_su8_800.jpg
        My weatherproof cover is based on the Taymac MM420C, probably a little more detail than it needs but I wanted it to look somewhat recognizable.
        I also have the Decora option and the standard duplex option.
        design.medeek.com
        • pbacotP
          Nice!
          • medeekM
            medeek
            Has anyone ever called out duplex receptacles with the integrated USB chargers?
            https://www.leviton.com/en/images/lc/T5632_W_5.jpg
            301 Moved Permanently
            (www.leviton.com)
            I'm assuming the callout would just be a standard duplex symbol with the annotation "USB" added.
            design.medeek.com
            • medeekM
              medeek
              These type of outlets have a small parasitic load (50 mW), but I think many people are willing to accept that loss for the convenience. My worry would be that the device fails down the road and then I need to replace it. Its one thing tossing an old adapter in the bin, its entirely different when I need to pull out the tool bag and start re-terminating receptacles, or worrying that one of these things is really going to go bad and possibly create a fire hazard.
              It’s not a big deal to provide a USB model of your standard USB Decora duplex receptacle, I’ll just base it on the T5632 (Leviton) and if people want something different they can replace the default model in the library that I provide.
              As I was eating outing this evening with the wife I noticed along the bar a line of outlets (and even a couple switches) that were mounted horizontally rather than vertical. I will need to add in the first of the advanced options which allows the user to toggle between a vertical or horizontal mount, obviously vertical will be the default.
              design.medeek.com
              • medeekM
                medeek
                Added the advanced option which will allow for a horizontal mount of any receptacle:
                http://design.medeek.com/resources/images/electrical_su9_800.jpg
                First look at the the following: GFCI, USB, Simplex, Horizontally mounted Duplex
                http://design.medeek.com/resources/images/electrical_su10_800.jpg
                I will also extend this same functionality to the switch module so that they can be mounted in any orientation.
                design.medeek.com
                • medeekM
                  medeek
                  Option for weatherproof GFCI added:
                  http://design.medeek.com/resources/images/electrical_su11_800.jpg
                  I haven't gotten every combination but I think I now have about 85% of the most commonly used configurations added in for outlets. I will now return to the switch module and work that over for a while until it is also about 85-90% coverage.
                  I also still need to add in a completely new style: 240V
                  This will comprise single gang outlets for clothes dryers, welders, and ranges.
                  design.medeek.com
                  • medeekM
                    medeek
                    I've added in the option for 240V receptacles:
                    http://design.medeek.com/resources/images/electrical_su12_800.jpg
                    These are limited to single gang configurations as shown (2 gang electrical box). They can be mounted either vertical or horizontal. The annotation allows one to specify either a dryer (D) or range (R) outlet.
                    By default the color of the outlets is a dark brown (thermoplastic) but can be modified by the user as well as the wall plate material.
                    I was going to add in an option for a welder outlet but I'm not sure which outlet type is the most common for this application, it appear that the NEMA 6-50 is commonly used for welders but until I get more information or a direct request for this particular NEMA receptacle I will leave this one for now.
                    Dimensions for these outlets types are per Leviton's product lineup, as is the wall plate. For now I've employed the standard 2-gang Carlon PVC box but for a heavier circuit like these I personally would probably go with a metal box and the appropriate mud ring and cable clamps.
                    https://www.hubbell.com/raco/en/Products/Electrical-Electronic/Boxes/4-in-Square-Boxes-Covers/8235/p/1670412#prod-resources-section
                    https://www.hubbell.com/raco/en/Products/Electrical-Electronic/Boxes/4-in-Square-Boxes-Covers/769/p/141876
                    design.medeek.com
                    • medeekM
                      medeek
                      A few more options for the switches module:
                      http://design.medeek.com/resources/images/electrical_su13_800.jpg
                      One of my favorite switches, the Trimatron.
                      Okay, I think I have my bases mostly covered for switches and outlets other than some specific combinations which will require a different icon/tool but I will get to that in the near future. Am I missing anything important here?
                      I currently have 47 pre-configured switch/outlets and combinations, see the model here:
                      3D Warehouse
                      (3dwarehouse.sketchup.com)
                      Besides switches and outlets there are all of the low voltage type components like:
                      Coax, Cat5/6/7, Phone, Speakers etc...
                      Then there are your service panels (breaker boxes)
                      The other elephant in the room is lighting fixtures.
                      I think for now I will start off with the switches and outlets and see what the response is. If the user base demands all of these other elements then I will take it one step at a time.
                      design.medeek.com
                      • medeekM
                        medeek
                        I will provide the same 14-xx outlet in 30 and 50 amp without the dryer or range designation, for those applications that are something other than those two typical residential usages.
                        I was looking at Square D service panels (load centers) last night and I'm most familiar with their QO product, not a huge fan of the cheaper Homelite product line. I can't seem to find any decent drawings or dimensions for these enclosures other than the overall size. If anyone can direct me to a resource which will allow me to model these up with some accuracy I would like to add in a handful of service panels.
                        I'm probably not going to dive too deeply into the load center module right now, only providing a basic model and label, but eventually it would be nice if one could assign specific outlets, switch and light fixtures to a given circuit/circuit breaker. There is a lot that can be done with this sort of thing.
                        design.medeek.com
                        • medeekM
                          medeek
                          For low voltage I am going to start with only one style for now and that is the Leviton Quickport system:
                          http://design.medeek.com/resources/images/electrical_su14_800.jpg
                          The advantage with this system in my opinion is that there will be less electrical boxes to install since you can get more than one outlet per box (max. is 6 ports for a single gang box).
                          My only problem now is how to show this type of port on the electrical plan. Typically I would have a symbol for TV, Phone and/or Data. However, what does one show when you have a situation like above where all three data types are compressed into one box. Even worse, what if I have the 6 port version and have one phone jack, two CAT6 jacks, two coax jacks and a blank?
                          What is the preferred convention? If there is one.
                          Additionally there is the 2-gang low voltage box (Carlon SC200AR) which can be fitted with a Quickport face plate and have a maximum of 12 separate ports, yikes.
                          design.medeek.com
                          • medeekM
                            medeek
                            The low voltage components that will be utilized in the Medeek Electrical extension:
                            3D Warehouse
                            This collection is only the QuickPort components there is also the QuickPlate and Decora styles that I have not gotten to yet.
                            (www.leviton.com)
                            (www.leviton.com)
                            design.medeek.com
                            • jujuJ
                              juju
                              Would we be able to add/assign our own/custom components?
                              • medeekM
                                medeek
                                Yes, I think I can set that up. You will probably need to take a look at the way I am setting up the .skp files in the low voltage library (placement of origin) and then it shouldn't be too hard to add your own jacks etc...
                                I've also added in the RCA QuickPort by request.
                                http://design.medeek.com/resources/images/electrical_su15_800.jpg
                                You will be able to assign a unique QuickPort outlet to each port of the wall plate and also assign it its own unique color if you choose (this will be important for people who are color coding network jacks).
                                design.medeek.com
                                • medeekM
                                  medeek
                                  The updated toolbar:
                                  http://design.medeek.com/resources/images/electrical_su_menu_active.jpg
                                  I will leave it up to inquiring minds to figure out what all these icons mean. 😄
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    The low voltage module is working pretty good now. I just need to wrap up the 2D symbols and then we will see if I can put together a few typical load centers, and then its out to the public for some BETA testing.
                                    A 2-gang, 12 port low voltage box is probably your worst case scenario:
                                    http://design.medeek.com/resources/images/electrical_su16_800.jpg
                                    Each port can be assigned one of the following:
                                    • CAT6
                                    • CAT5e
                                    • COAX
                                    • PHONE (RJ11)
                                    • RCA (Audio/Video, gold plated)
                                    • BLANK (Plastic Insert)
                                    Additionally each port has its own unique material/color which by default is "White". The faceplate can also be assigned a unique material/color.
                                    Similar to other outlets the advanced options can be enabled which allows for vertical or horizontal mounting.
                                    The number of possible QuickPorts is limited to the following:
                                    1-Gang: 1, 2, 3, 4, 6
                                    2-Gang: 8, 12
                                    There are additional 2-Gang QuickPort wall plates that I have not added. I will only add these if requested, since they are already covered by the 1-Gang option.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Various combinations of QuickPorts yields a number of possible 2D symbols:
                                      http://design.medeek.com/resources/images/electrical_su17_800.jpg
                                      I've tried to stay with conventional symbols as much as possible. Please let me know what you think on this.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Tomorrow I will finish modeling up some typical load centers (breaker boxes) like the one below (200 Amp, 40 Spaces):
                                        http://design.medeek.com/resources/images/electrical_su18_800.jpg
                                        I'm not going to put any special logic into this module yet, just a simply positioning and selection. However at some point it would be really cool to use the plugin to setup the various breakers and identify circuits as well as assign specific elements to a circuit.
                                        For now three sizes of breaker components are provided and it is up to the user to manually configure their panel if they so choose to do so, otherwise is is more representational than anything else.
                                        When it comes to setting the vertical height of the load center what is the method used to measure from the floor? Center, Top or Bottom of the panel?
                                        I will provide some common panel sizes (spaces): 24, 30, 40, 42, 54, and 60.
                                        My breakers are based on the SquareD QO series as are my load centers however they are considerably simplified to maintain a low poly count.
                                        Also for now I am only going to provide flush mount and not surface mount however I will probably enable both in the future.
                                        View model here:
                                        3D Warehouse
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Various load center sizes, view model here:
                                          3D Warehouse
                                          All load centers are 200 Amp except for the 24 space unit which would be rated for 100 or 125 Amp.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            The inside of these boxes and the breakers are very simple and low poly. The idea is mostly to convey the number and location of breakers and overall dimensions:
                                            http://design.medeek.com/resources/images/electrical_su19_800.jpg
                                            design.medeek.com
                                            • 11
                                            • 2 / 11
