    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 415.2k Views 92 Watching
      Have you tried removing all files related to Vertex Tools? After using uninstall from Extension Manager there might be files left. Could you check your Plugins folder?
        sofie9536
        works fine,thanks
          jzar_kobi
          I can't seem to connect to the license server, yes I have unblocked with my firewall still no luck
            What version of SketchUp are you using? What OS and OS version? (If Windows, what version of Internet Explorer is installed?)
            Is there any output in the Ruby Console if you open it before trying to activate?
            • E Offline
              Einstein
              Hi!
              Got a question.
              If I select some vertices using soft selection, it will also affect geometry that's not connected to selected vertices (see screenshot). Can I change this behavior so that soft selection will only affect connected vertices?
              You'd say "do grouping your geometry" but that's not the solution in my case.
              • E Offline
                Einstein
                Hi!
                I'd have a suggestion for a small feature development.
                When doing soft selection we have two options of falloff - linear and cosine. What if we had more options, e.g. "pinchy" fallof shape, as illustrated below, on the left?
                I can see such idea was already posted years ago but I dared to bring it anyways, cuz it would be a fantastic improvement of already very good tool!
                  @einstein said:
                  Hi!
                  Got a question.
                  Currently soft selection is computed by spatial distance only. I have it on my list to add a "by connected distance" option.
                    @einstein said:
                    Hi!
                    Yes, that is also on the list. something like a pinch and bubble parameter like 3dsmax offer.
                      rv1974
                      I hope target weld is in that list as well
                        This ol' thing? 😛
                          rv1974
                          Oops.. I meant welding based distance threshhold
                            Like this?
                              rv1974
                              Wow morning full of surprises.
                              Many thanks!
                              The only thing left to be clarified is when v2019 will be out 😄
                                Good question. I'll make a post when I know myself. 😉
                                  Btw, Merge Close Vertices is already included in v1: https://evilsoftwareempire.com/vertex-tools/manual/tools#merge_close_vertices
                                    rv1974
                                    If you sit by the river long enough, you will see ̶t̶h̶e̶ ̶b̶o̶d̶y̶ ̶o̶f̶ ̶y̶o̶u̶r̶ ̶e̶n̶e̶m̶y̶ ̶f̶l̶o̶a̶t̶ ̶b̶y̶ thomthom's post about v2019
                                    • pbacotP Offline
                                      Know thyself.
                                      • E Offline
                                        Einstein
                                        Hi!
                                        I'd have another suggestion of upgrade. "Make Planar" tool would be more useful if we could specify the plane for selected vertices to be flattened to. For example, set the plane with two vectors, like TIG's Mirror does.
                                        • BoxB Offline
                                          @einstein said:
                                          Hi!
                                          Adjust the Gismo to the direction you want then Make Planer.
                                            @einstein said:
                                            Hi!
                                            You can also scale to zero for the same effect in the model axis planes.
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 33
                                            • 34
                                            • 15 / 34
