    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 608.6k Views 92 Watching
      I'm able to reproduce. I think I have a fix, but I need to test if it breaks other stuff.
        Version 1.2.12
        Fixes
        • Fixes VCB adjustments for Gizmo Ctrl+Move.
        • O Offline
          optimaforever
          Cool. that was fast.
          • O Offline
            optimaforever
            About the hanging issue, it's very strange.
            It takes around 5-10 min after launching SU to be actually available (move in the viewport).
            Where can I check the launching log of SU?
              There is none...
              The lag goes away if you disable or remove VT?
              • O Offline
                optimaforever
                I've tried this, but that doesn't change anything.
                I'm busy trying to reinstall SU 2017.
                  Have you tried removing all files related to Vertex Tools? After using uninstall from Extension Manager there might be files left. Could you check your Plugins folder?
                    sofie9536
                    works fine,thanks
                      jzar_kobi
                      I can't seem to connect to the license server, yes I have unblocked with my firewall still no luck
                        What version of SketchUp are you using? What OS and OS version? (If Windows, what version of Internet Explorer is installed?)
                        Is there any output in the Ruby Console if you open it before trying to activate?
                        • E Offline
                          Einstein
                          Hi!
                          Got a question.
                          If I select some vertices using soft selection, it will also affect geometry that's not connected to selected vertices (see screenshot). Can I change this behavior so that soft selection will only affect connected vertices?
                          You'd say "do grouping your geometry" but that's not the solution in my case.
                          • E Offline
                            Einstein
                            Hi!
                            I'd have a suggestion for a small feature development.
                            When doing soft selection we have two options of falloff - linear and cosine. What if we had more options, e.g. "pinchy" fallof shape, as illustrated below, on the left?
                            I can see such idea was already posted years ago but I dared to bring it anyways, cuz it would be a fantastic improvement of already very good tool!
                              @einstein said:
                              Hi!
                              Got a question.
                              Currently soft selection is computed by spatial distance only. I have it on my list to add a "by connected distance" option.
                                @einstein said:
                                Hi!
                                Yes, that is also on the list. something like a pinch and bubble parameter like 3dsmax offer.
                                  rv1974
                                  I hope target weld is in that list as well
                                    This ol' thing? πŸ˜›
                                      rv1974
                                      Oops.. I meant welding based distance threshhold
                                        Like this?
                                          rv1974
                                          Wow morning full of surprises.
                                          Many thanks!
                                          The only thing left to be clarified is when v2019 will be out πŸ˜„
                                            Good question. I'll make a post when I know myself. πŸ˜‰
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 33
                                            • 34
                                            • 27 / 34
