    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.4m Views 329 Watching
    • pbacotP
      I tried the file and it worked. Albeit it worked nice once, and I couldn't repeat, so there was some issue.
      • L
        littleche
        @dave r said:
        So a case where GIGO reared it's ugly head.
        Hi dave
        My English is little poor.I did not notice you.You get guys easier to say? ❓
        hi again
        solved problem and i test it again and again and again ...
        There is not a problem for me anymore .
        Everything was strange!
          Sorry, Nabi. GIGO is computer nerd speak for "Garbage In, Garbage Out"
          In your example, the bad geometry of your curve was creating a bad bent component.
          • L
            littleche
            ok dave ! get it ! thank you . πŸ‘
            I realized that with the offset tool we can test health of workline !
            It is hard for me to explain . In summary I can say Everything depends on a correct offset!
            • eidam655E
              eidam655
              hi πŸ˜„
              i'm using the latest version downloaded from the extension warehouse (0.6.1). However, in combination with SU 2015 Pro I'm getting the following errors:
              Error: #<NoMethodError: undefined method all_connected' for nil:NilClass> C:/Users/eidam/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/clf_shape_bender/clf_shape_bender_data.rb:255:in line_picker'
              C:/Users/eidam/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/clf_shape_bender/clf_shape_bender_data.rb:187:in `onLButtonUp'
              As witnessed on the Extension Warehouse website, there are more users with this issue. Has it been resolved since then? Or is there an alternative plugin that achieves similar results? πŸ˜„
              Thank you for any answer.
              I'm using SketchUp 2017, V-Ray 3.4
              • P
                Pangea
                Fellows,
                I'm in the process of redesigning a concrete structure for the greater good. It's called the Villager model and I intend to mass produce them in impoverished areas of the world, beginning in West Africa along the Congo River.
                The structure is circular, 20 ft across from the outer walls. The base is made up of three arches which elevate it off the ground. I started with a circle made up of 30 segments. Next I broke it into thirds. I then copied the outer arc from one of the thirds. The length of the arc is 20' 11 5/16". Next I drew the shape that I plan to bend the same length as the arc ( 20' 11 5/16"). I go through the CLF Shape bender steps and the result is very close to what I need. The problem I'm having is the faces on the inner wall of the curved arch are all triangulated. I notice when I perform the CLF steps on just a rectangle, the faces on the inner walls are not triangulated. So the problem is being caused by the arch. There are 50 segments in the arch pictured. I tried drawing it with 12 segments and the triangulation on the inner curved faces was less, but still unacceptable. I need these faces to be flat and extrudable so i'll be able to draw the formwork panels that will be used to pour the structure. I've attached a picture of my original Villager model and another sketch showing the problem I'm having with the new one. Any advice would be greatly appreciated.
                Thank you,
                Eric
                  this ?
                  Projection by Didier Bur
                  Joint Push Pull by Fredo6
                  • P
                    Pangea
                    Merci Beaucoup Pilou!
                    I'm going to try this now. I'll let you know how it goes.
                      milenoliegsalz
                      Really nice and helpful extension πŸ‘ πŸ‘ Would be even much nicer if it could bend the groups without exploding the sub-groups. Nevertheless, thanks for sharing it.
                      • C
                        Cynthiat
                        HELLO,
                        I HAVE DOWNLOADED THE SHAPE BENDER PLUGIN BUT WHEN I INSTALLED IT, IT WAS WRITTEN UNDER IT UNSIGNED AND COULDN'T FUNCTION. ANY HELP?
                          Unsigned doesn't mean it doesn't work. Shape Bender works just fine unless you set the loading permission to prevent it from loading.
                          • H
                            hungryhamster
                            the plugin does not work in the Sketchup 2019 when you select a line nothing happens
                              Click on the picture if it doesn't move
                              It works fine for me in SU2019. Have you installed the maintenance release? You should have 19.1.174. There was a problem in 19.0.
                              • K
                                kinhkhaag
                                [attachment=0:p4n8mnom]<!-- ia0 -->sb.gif<!-- ia0 -->[/attachment:p4n8mnom]
                                Please! How to do plusgins Shape Bender Beta v.0.6.1 work. The plugin does not work in the Sketchup 2019 when I select a line, curve nothing happens
                                  Yes. It does work in SketchUp 2019.
                                  Most likely you haven't set up the model correctly to use it. If you share the SKP file, I'm sure we can help you make it work.
                                  • K
                                    kinhkhaag
                                    [attachment=1:f3usmxfu]<!-- ia1 -->SB.gif<!-- ia1 -->[/attachment:f3usmxfu]
                                    I don't can for SU 2019 finish
                                    EX:
                                    Untitled.skp
                                      Your example SKP is very similar to Dave's demonstration.
                                      Your red-axis line is elevated and the curve in vertical - but it will still work.
                                      To reiterate...
                                      Preselect the group.
                                      Activate the ShapeBender tool.
                                      Click on the Line.
                                      Click on the Curve.
                                      Press Enter to accept 'ghost' version of the bent form...
                                        NOTE: there was an issue with a few tools [like ShapeBender] found in the first version of v2019, but that was fixed in the more recent MR version currently available - have you downloaded the latest v2019 version ?
                                        The issue related to the way SketchUp can take either a point or a vertex when setting up geometry.
                                        This well established protocol was unexpectedly broken in v2019 first incarnation, but that problem is now fixed in the current v2019 installer...
                                        To see if that's the case with your set up open the Ruby Console before running the tool.
                                        The error message [if any] should be obvious...
                                        • C
                                          clarinaya
                                          Hello,
                                          actually when i try to use shape bender after completing make group etc, the words β€œstart” and β€œend” should appear at each end of reference line along the red axis, but not.
                                          I use skp pro 2019, what should i do?
                                            As you can see in the GIF in my previous post, Start and End do show up in SU2019. If they don't for you, perhaps it is the way you have your model setup. You could share it so we can check it out. Or it could be an incorrect installation of SketchUp. When you installed SketchUp 2019 did you right click on the downloaded installer and choose Run as administrator?
                                            • 60
                                            • 61
                                            • 62
                                            • 63
                                            • 64
                                            • 62 / 64
