    Some tips and tricks from out of the Box
    203 Posts 20 Posters 183.0k Views 20 Watching
    • BoxB Offline
      @ntxdave said:
      I also had some problems getting the delete tool to work out like in your video.
      That is just triple click, shift double click.
      Triple click selects all, shift double click deselects the face and it's edges leaving the faces of the holes selected.
      • bazB Offline
        baz
        I am learning something from every one of these posts.
        SketchUp is a bit like sailing. You know that you will never know it all and that you will never stop learning.
        Cheers Box.
        Baz.
        • BoxB Offline
          Cheers Baz, glad some people are getting something out of them.
          • HornOxxH Offline
            HornOxx
            I don't get tired of repeating me - yes, every time there is something new to learn here and BAZΒ΄s comparison with sailing is great chosen. Especially this obvious concept of putting a model "on the left" like an untidy sock (which annoys my wife so much in real life) is so good and finally has flowed into my active repertoire - I wouldn't have come up with this idea on my own anyway πŸ˜‰ πŸ˜„
            also Cheers Box!
            never trust a skinny cook
            • ntxdaveN Offline
              ntxdave
              Thanks a bunch @Box. It was driving me nuts trying to figure out what I was doing wrong. I deleted each of the faces of the circles independently. Is this stuff documented anywhere, especially the shift double click?
              I also had a problem replicating the first circle the way you did. Wound up with a problem with the orientation of it so I just drew it. A second time.
              I do not use Sketchup very often anymore so replicating your video is both a good learning exercise as well as a good refresher.
              Once again, thanks a ton for this thread. πŸ‘ πŸ‘ πŸ‘
              • BoxB Offline
                Which do you mean by the first circle, the very first is drawn on the blue axis and is orientated that way as the camera is looking more down than horizontal. The second is the beginning of the array and is drawn on the green, once again due to the camera angle.
                Both could be forced on axis by the arrow keys, up for blue, left for green, right for red.
                • ntxdaveN Offline
                  ntxdave
                  OK - I just watched the video again, and I was wrong. For some reason I missed that you drew two circles. DUH.....
                  One other thing though, I see the axis showing up in different places at different times (at least that is what I think I see). Am I delusional? Is that an option to make the axis show oriented to the object you are drawing?
                  Are there other keyboard tricks (like the shift double click) that you can share as well?
                  • BoxB Offline
                    I can only imagine you are seeing the axis for the component and group when they are open for editing. There really is nothing magical going on in the gif, all just straight sketchup.
                    • ntxdaveN Offline
                      ntxdave
                      I went back and watched the first gif again and have made a mess of it. I have not used SU much lately so I need some refreshing. Can someone point me to some documentation or tutorials for using both the radial bend and thrupaint extensions? I tried to find some but have not been successful in finding anything worthwhile yet.
                      This is another case where I wish you could pause a gif. Some of the text in the gif goes by too quickly and I cannot read. It.
                      Once again Box, I think this is a wonderful thread and greatly appreciate it. πŸ‘
                      • BoxB Offline
                        Here's the very basics of Radial bend.
                        You choose the direction, then the extent, then you bend it.
                        So click to set the protractor (click drag release if needed, or arrow keys),
                        Click to set the length of the bend area
                        then click to start the bend and click to finish the bend.
                        • ntxdaveN Offline
                          ntxdave
                          Once again, thanks for the reply.
                          The first 3 are pretty straight forward but I am really doing something wrong on the fourth one (like when you bent the paper page in the original post). I am feeling really stupid here. It is not like I have not been using SU for a good while but I am missing something curtail to the process. In particular, I think I am not getting the reference points and orientation of the bend correct.
                          • BoxB Offline
                            I have to go to bed, but it sounds like this is your issue. All four examples set the axis. The forth is setting the axis Off Axis, Click drag release to set the axis.
                            • ntxdaveN Offline
                              ntxdave
                              I am obviously missing something very key to controlling how to accomplish this (and feeling dumber by the minute).
                              First of all, what keys are you using to set the various points and what do you mean by "Off Axis"? In several of your steps in the four drawings I see some dashed lines. What keys are you hitting to make that show up.
                              My real goal here is, of course, to learn how to use the tool correctly but in particular, I want to be able to reproduce your first video in this thread with some accuracy. 😒
                              • BoxB Offline
                                I'm not hitting any keys, nothing is happening that you can't see.
                                I'm sorry, I'm not sure how to show it more plainly.
                                Off axis means it isn't on the green red or blue axis.
                                Click drag release is how you set the axis of rotation, for both the normal rotation tool and in this case fredo's.
                                The dotted line is a guide that appears as you use the tool, it isn't a magic wand that I'm waving.
                                • ntxdaveN Offline
                                  ntxdave
                                  It is just that fourth method that I am having a problem with. Bending the "page" at an angle with it winding up with one corner bent up at an angle. The other methods are pretty straight forward.
                                  • BoxB Offline
                                    Can you rotate a single face off axis?
                                    It is the same process, set the angle of rotation then bend it along that angle.
                                    But I'm to bed now.
                                    • ntxdaveN Offline
                                      ntxdave
                                      Thanks for your patience Box. I finally got it to work. Yes, I need some additional practice to learn how to control it more accurately but here is a sample I finally created.
                                      Curved Page
                                      • BoxB Offline
                                        Well done, glad to see you got there.
                                        • BoxB Offline
                                          Ok, here's another one to drive you mad.
                                          How do you make a hollow torus from a spiral that is one continuous solid sausage.
                                          Truebend by Thomthom
                                          https://i.imgur.com/Hieau17.gif
                                          • ntxdaveN Offline
                                            ntxdave
                                            All I can say is WOW! πŸ‘ πŸ‘
                                            That one will really take some studying and a WHOLE LOT of practice.
                                            • 11
                                            • 3 / 11
