    ๐Ÿšจ Skimp | 25% Off until March 30 Buy Now
    Skimp by Mind.Site.Studios - HOW GOOD DOES THIS LOOK!!!!!
    17 Posts 12 Posters 8.2k Views 12 Watching
    • utilerU Offline
      utiler
      Hi guys, I'm sure some of you may have seen the sneak peak YouTube video from Mike @ Mind Sight Studios of their latest plugin called, Skimp'
      Converts OBJ files to low poly model in the blink of an eye!!!! ๐Ÿ˜ฎ ๐Ÿ˜ฎ ๐Ÿ˜ฎ ๐Ÿ˜ฎ ๐Ÿ˜ฎ
      WOW, WOW, WOW!!!! I can;t wait to get my hands on this little beauty!!!
      Thank in advance, guys, have a magical festive season and a prosperous your ahead!
      Just Curious...
      • HornOxxH Offline
        HornOxx
        yes - great, apparently even a texture exchange is possible? I am very curious!!
        thank you for your greetings - also with you ๐Ÿ˜„
        never trust a skinny cook
          samnorth
          Skimp looks awesome but so does Transmutr. Really looking forward to see how they both turn out.
          I hope Skimp proxies can work with Thea, please?!
            A future hit! ๐Ÿ˜Ž
            • StinkieS Offline
              Stinkie
              Looks awesome.
                pipinek
                Hullo,
                Skimp 175$/year!
                Transmutr one-time 69$ plus an integration with the next Skatter.
                Soon a pair of slippers for 39$/year - three washings included.
                • soloS Offline
                  On one project Skimp imports saved me at least 4 hours, I needed to import DAZ characters in different poses for obstacles, normally this is a crap job of decimating mesh in DAZ, hoping geometry stays intact, clothing not intersect bodies etc, now I export full geometry to .obj, import with Skimp, reducing it 90% in a fraction of the time I normally used to do it. That was just one small project, cannot imagine the time saving in one year, well worth the price.
                  • W Offline
                    Whaat
                    Thanks solo!
                    There are some key differences between Skimp and Transmutr, most notably:
                    • Ability to select and simplify any object already in your SketchUp model
                    • Windows and Mac Compatible
                    • Skimp has accurate simplification tolerance setting which is very important for CAD / CAM and 3D Printing
                    • Skimp can import more file formats
                    We will keep adding more features too...this is just the beginning ๐Ÿ˜„
                      rv1974
                      Isn't C4D Polygon Reduction good enough comparing to Skimp? I'm asking myself (since I've got ProOptimizer modifier inside 3ds Max) what extra value will I gain with Skimp?
                      • soloS Offline
                        C4D? I was exporting from DAZ not C4D. Skimp is a lot faster than DAZ's poly reducer, in fact Skimp just as an importer is even faster than Simlab.
                          rv1974
                          @solo said:
                          C4D?...
                          Maybe I'm mistaken but you stated somewhere you swithch(ed) to Cinema, didn't you?
                          • soloS Offline
                            @rv1974 said:
                            @solo said:
                            C4D?...
                            I am in the progress, Not fluent enough to give SU up completely yet and many existing clients are using SU so there is no running away. Currently C4D is adding value by giving new options, but has not replaced SU, and probably will not for a while.
                              dtrarch
                              Great idea and plugin.
                              Subscription-never ๐Ÿ‘Ž ๐Ÿ‘Ž ๐Ÿ‘Ž
                              Cost-disproportional to $ for Sketchup. ๐Ÿ‘Ž ๐Ÿ‘Ž
                              Big office cost for business only.
                              Sorry to say such
                              dtr
                                db11
                                This extension looks amazing, but the cost/subscription model puts it out of consideration for me (given that I would only use it on occasion). I can see where it would have huge value for an office where it's needed in support of an existing workflow across platforms.
                                I would consider it at half the cost for a permanent license.
                                  pipinek
                                  They have offered a launch sale, 99 $.
                                  Perhaps, I hope, they are aware of an exaggerated price and above all a subscription plan
                                  • iichiversiiI Offline
                                    iichiversii
                                    It is an insane price, letโ€™s be honest, how often would you or I use this, yes I would use it but not everyday, I usually make a few LODs of the same mesh for optimising objects with less geometry depending on distance from the camera in unity, but in saying that there is a unity plugin that does the same for as little as โ‚ฌ45, I can then reimport the mesh back into sketchup, ok the workflow maybe not as perfect as Skimp however itโ€™s the same result with out burning a hole in my pocket, Iโ€™m very disappointed in Mind.Sight.Studios, I have purchased some great products from them in the past that were not subscription based and were reasonably priced, there are alternatives to Skimp that do the same thing, I canโ€™t see how they can justify the price let alone the yearly subscription, thatโ€™s just my opinion.
                                    Bring on the Rain...
                                    • W Offline
                                      Whaat
                                      Hi everyone,
                                      I just wanted to provide an update on our pricing. Based on the feedback we have received, we have adjusted our pricing to make it much more affordable. I hope you will give Skimp another look.
                                      Ultimate SketchUp Polygon Reducer and Importer for Professionals
                                      Simplify your SketchUp model using ultra-fast import and polygon simplification tools. Optimize and decimate your model in seconds. Import FBX, OBJ, STL...
                                      Skimp (skimp4sketchup.com)
