    [Plugin] Work Plane
    183 Posts 32 Posters 148.4k Views 32 Watching
      Works fine in v8 up to v2014 πŸ˜•
      I just reinstalled it in v2014 to be sure, and it worked fine. πŸ˜„
      When loaded [and enabled if you are using the SCF Plugins Manager]...
      It has a submenu named "WorkPlane Tools" under "Tools" menu.
      I trust you have looked there and not under the "Plugins" menu***
      If you select a WorkPlane object, then there are a number of tools enabled in the Context-menu - these differ depending on what you have selected.
      There is a Toolbar named "WorkPlane Tools" too...
      ***Have you actually read the usage instructions ??
      If there's still a problem... do you have the latest version of v2014 - an update came out a few days ago...
      Also are there any accented characters or single-quotes in your Windows User name ?
      These have been reported as issues for many plugins' loading...
      • Bob JamesB Offline
        Bob James
        When I apply the normals tool the normal set is rotated. The primary axes are in the standard directions.
          bdealva
          Does Workplane work in SU 2015?
            Yes. Do you have any reason to think it wouldn't?
            • H Offline
              huajiet
              I seem to have some trouble installing Work Plane on SU2014.
              I get this error message:
              "SketchUp was unable to install the Extension you have chosen for some unknown reason.
              Consult your Extension's documentation for additional help."
              What might be wrong?
                Should work.
                Have you downloaded the latest RBZ from the PluginStore ?
                  brooklyndesigner
                  This is really great. Worked like a charm for me the first time. I was working in "top" "parallel" view on a floor plan (even though the model is 3D). Instead of having to orbit and go into perspective to make changesI was able to draw right onto the floor plane. Then when I tried it again when drawing a line it didn't lock to the work plane. It drew all over. I'm using Sketchup 2016 on a Mac. Any ideas?
                  Thank you.
                  • SiPieFaceS Offline
                    SiPieFace
                    I know this is an old thread but I've been trying to use Work Plane to be more efficient and accurate with my projects. It's a great plugin but I'm having a real issue changing the size of the Work Plane. Right-click into space just doesn't work for me, I get nothing at all. When I start Work Plane it merely allows me to select the 3 points and double-click to accept. I'm using SU2018 so wondered if this might be the issue?
                      Sadly the right-click in empty-space to change settings no longer works.
                      However, if you make a Workplane using the default values, then immediately Select it; its context-submenu then includes lots of extra options - use its 'Adjust' to change the size WH and grid XY...
                        SiPieFace
                        Ahh, that explains it. Thanks for the nod, I'll use that. This is such a useful plugin, is there any chance it'll get updated?
                        • 10 / 10
