    3D Truss Models
    1.5k Posts 31 Posters 977.5k Views 30 Watching
    • jujuJ Offline
      juju
      Should anyone be this deep into this thread and not have realized how useful this extension is, take my word for it, it is very useful. If you're sitting on the fence the one-day once-off Christmas discount being offered is plenty of incentive to get it.
      • medeekM Offline
        medeek
        Version 2.2.5 - 12.08.2018
        • Added Trim 2 icon to the Medeek Tools toolbar.
        • Added the trim 2 function for (solid) groups and components. This trim function allows the user to select two trimming planes.
        http://design.medeek.com/resources/images/tools_su_menu_12132018.jpg
        This additional trim function will be helpful in trimming more complicated geometry like hip rafters and triangular pieces of roof sheathing or cladding.
        Similar to the regular trim function this tool can also be utilized on any non-plugin geometry so long as it is a (solid) group or component.
        View video here:
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • medeekM Offline
          medeek
          In order to round out the selection of tools available and also per suggestion from a respected colleague it would seem prudent that I also include a mitering tool in the grab bag that is the Medeek Tools.
          This can take shape in a few forms however the most important configuration in my opinion would be a tool that can take two solids and miter both of their ends at a common plane, while retaining the solid status of the group or component and retaining all of their properties and meta-data.
          This would involve selecting the faces to extend/trim on each solid and then selecting two (non-parallel) edges that intersect at a point, so four pick points in total. The intersecting edges need not be orthogonal (90 degrees) just so long as they intersect at a point, that is enough to define the mitering plane.
          I haven't searched very much yet to see if such a tool/plugin already exists and I don't really want to recreate the wheel on this one. Please let me know if you are aware of such a tool, that can work for any (non-plugin specific) solids.
          Would there be a need/demand for this proposed tool?
          design.medeek.com
            Seems Profile builder has such tool page 28-31...?
            • medeekM Offline
              medeek
              I'm not seeing a miter tool?
              design.medeek.com
                Not specially it's for repare one by one if miter joint of an existing object(page 35) is not as you want...
                • medeekM Offline
                  medeek
                  Version 2.2.6 - 12.16.2018
                  • Added the Miter Cut icon to the Medeek Tools toolbar.
                  • Added the Miter Cut function for (solid) groups and components.
                  • Enabled temporary (construction) dimensions for trusses, roofs and floor assemblies.
                  • Added a section in the General tab of the global settings for configuring construction dimensions.
                  http://design.medeek.com/resources/images/truss_su367_800.jpg
                  http://design.medeek.com/resources/images/tools_su_menu_active.jpg
                  Tutorial 12 - Miter Cut:
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 2.2.5c - 12.13.2018
                    • Added the Trim 3 icon to the Medeek Tools toolbar.
                    • Added the Trim 3 function for (solid) groups and components. This trim function allows the user to select three trimming planes.
                    • Enabled the ability to invert your selection within the Trim 2 and Trim 3 tools using the "CTRL" key in Windows.
                    http://design.medeek.com/resources/images/tools_su_menu_12162018.jpg
                    Tutorial 11:
                    Note that the planes in either advanced trim tool do not need to be orthogonal.
                    When using the Trim 3 tool the suggested order of selecting the cutting planes/faces is:
                    Vertical - Vertical - Horizontal
                    On an outside corner like that I'm not entirely sure how a skilled roof framer would cut that birdsmouth, but at least with the Trim 3 tool you have the option to cut it so it fits tight to the wall as I've shown in the video.
                    I like including this toolset as part of the Truss plugin, but I am also wondering if there might be a potential market for it as a stand alone plugin ($5 - $10). As it stands currently the prospective user is forced to purchase the entire Truss Plugin if they want to use these tools.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      I'm a little burned out right now with the addition of all these extra tools to the Medeek Tools toolbar, but I still feel like I need to add one final addition to the mix.
                      This one will be called the split tool and similar to the trim tool the user will select a single face (or three points, toggle with the control key?) to define a plane which will then be used to cut a solid group or component in two.
                      The slightly tricky part with this is to make sure that the copied group/component is nested in the same overall group(s) as the original and retains all of its properties.
                      This tool would be useful where you've used the followme tool to create some geometry but want to break the resulting solid into separate segments (groups).
                      design.medeek.com
                        Seems a very colol "knife"! 😎
                        • medeekM Offline
                          medeek
                          Version 2.2.6b - 12.18.2018
                          • Added the Split icon to the Medeek Tools toolbar.
                          • Added the Split function for (solid) groups and components: split plane via one face or three points.
                          When you first click on the tool it defaults to the user selecting a face for the cutting plane however if you hit the "CTRL" key in Windows it will toggle to the three point mode.
                          Tutorial 13 - Split Tool:
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 2.2.6c - 12.18.2018
                            • Addressed a bug in the Split function regarding nested groups and components.
                            This is a critical fix for this tool. I strongly suggest that everyone upgrade from 2.2.6b to 2.2.6c.
                            Let me know if there are any other tools that might come in handy with manipulating an architectural model. I think the six tools now available can cover most tasks but I'm sure I'm missing something.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              There has been some call for a tool that is similar to the split tool but rather than selecting just one face you would select two faces and a section could be removed from the solid object (imagine two infinite planes cutting a slice out of your solid object). I'm not exactly sure what to call this possible tool (section cut?).
                              The other question is whether to have the tool break the solid into two separate groups or components like the split tool or just leave the resulting geometry as one group/component? I suppose I could always enable an option that would allow the user to toggle between these to behaviors offering some flexibility to the user.
                              Similar to the split tool I could allow the user to define the cutting planes but either selecting two faces or selecting six points, or a combination of three points and a face or a face and three points. Lots of permutations here... just makes the code a little more fun.
                              With regards to the cutting planes, they could be parallel or they might not be, it doesn't really matter. Just as I am doing in the split tool I will need to include logic that checks to see that the cutting planes actually do intersect the solids otherwise no action will be performed. The two cutting planes cannot be perpendicular to each otherwise a valid solution cannot be obtained, or at least that is what I initially thought. I will need to give that possible solution some more thought. If a solution can be obtained there is no reason to discard it. There may be some overlap with the Trim 2 function, but that tool does not have the ability to separate the solid into different groups.
                              Any thoughts or suggestions with regard to this potential addition to the tools?
                              Also just a reminder that even though I am including these tools within the Truss plugin they are designed to work with any solid geometry created in SketchUp, it doesn't need to be plugin related geometry.designed to work with any solid geometry created in SketchUp, it doesn't need to be plugin related geometry.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                I've been thinking about labels for truss and rafter roofs and I would like to add in some sort of labeling system like the Wall plugin.
                                With a typical gable roof I will have a label on each side of the roof aligned with the roof plane but offset vertically so it does not Z fight with the sheathing or cladding (shingles). The label will be similar to the Wall plugin where the user can customize the prefix (eg Roof1, Truss1, Rafter1 etc...)
                                Each side will be designated a letter, so Roof1-A and Roof1-B. Hip roofs will have four roof planes so A, B, C and D.
                                If the framing callout is enabled then beneath the label will show the area for that roof plane (sheathing):
                                http://design.medeek.com/resources/images/wall_su322_800.jpg
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 2.2.7 - 12.27.2018
                                  • Roof and Floor labels option added to the General tab of the Global Settings.
                                  • Roof and Floor label prefixes can be customized in the General tab of the Global Settings.
                                  • Roof labels enabled for common trusses.
                                  • When framing callouts are enabled the area of each roof plane will be shown below the roof label (currently only common truss assemblies have this feature available).
                                  • Added a customizable color for roof and floor labels within the Material tab of the Global Settings.
                                  • Added additional layers for dimensions, annotations, 2d geometry, building code and engineering.
                                  http://design.medeek.com/resources/images/truss_su368_800.jpg
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 2.2.7b - 12.29.2018
                                    • Enabled roof labels and framing callouts for monopitch truss assemblies.
                                    • Added stats (roof sheathing) for common and monopitch truss roofs which can be analyzed within the Medeek Estimator (Wall Extension) module.
                                    In order to use this new feature you must also have the Wall plugin installed and upgraded to Version 0.9.9v, See Wall plugin thread for further details.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 2.2.7c - 12.30.2018
                                      • Enabled roof labels and framing callouts for all rafter roof assemblies: Gable, Hip, Dutch Gable, TJI, TJI w/ Glulam, Shed etc...
                                      http://design.medeek.com/resources/images/truss_su369_800.jpg
                                      http://design.medeek.com/resources/images/truss_su370_800.jpg
                                      http://design.medeek.com/resources/images/truss_su371_800.jpg
                                      http://design.medeek.com/resources/images/truss_su372_800.jpg
                                      I've also been thinking about how to best handle holes or cutouts in the roof sheathing and cladding that are not only parametric but can be properly reported by the estimator (ie. net area vs. gross area). I think I have a system worked out, I just need to implement the prototype and test it out.
                                      The cut out or hole tool will have a few options. One of the options will allow the user to specify whether to cut the cladding, sheathing or framing or all of them. If the framing is cut then another option for framing in the opening.
                                      I may also provide another option to provide a skylight to cover an opening or other construction elements (eg. vents, whirlybirds etc...)
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Another basic piece of information of any roof is the pitch or angle in degrees for the metric side of the house. I'm updating the framing callout for roofs to also include this information:
                                        http://design.medeek.com/resources/images/truss_su373_800.jpg
                                        http://design.medeek.com/resources/images/truss_su374_800.jpg
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Version 2.2.7d - 01.04.2019
                                          • All roof framing callouts now include the roof pitch or angle in degrees (metric templates).
                                          • Added additional stats: (ridge cap, drip edge) for common and (drip edge) for monopitch truss roofs which can be analyzed within the Medeek Estimator (Wall Extension) module.
                                          http://design.medeek.com/resources/images/truss_su375_800.jpg
                                          The new stats will become available with the next release of the Wall plugin.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 2.2.8 - 01.06.2019
                                            • License expiration date now appears in the License tab of the Global Settings when plugin is registered.
                                            design.medeek.com
                                            • 61
                                            • 62
                                            • 63
                                            • 64
                                            • 65
                                            • 75
                                            • 76
                                            • 63 / 76
