    MagicaVoxel as render for SU!
    70 Posts 4 Posters 41.9k Views 4 Watching
      https://i.postimg.cc/65LrbmWc/circa.jpg
      https://i.postimg.cc/CxcjSnff/rondi.jpg
      https://i.postimg.cc/bvd1JYQV/rondii.jpg
      Speaking with PaQ on its OOS Drillers! πŸ˜„
      https://i.postimg.cc/hGYMDptH/boxbuild.jpg
      https://i.postimg.cc/NMfYtGLN/boxbuild1.jpg
        And the cool thing is that can be "Multiple" & "Mono" or "Multi-colors"!
        (M) + Shift for reselect when trimming is done by the first click on the cutting objects!
        Ctrl on a face for move the selection!
        https://i.postimg.cc/ZKHzQnkQ/GIF-mult.gif
          Not sure about the product but, you certainly make great use of it. Nicely done, Sir.
            Selection stay of course valid for any other function! πŸ˜‰
            Here like Repeat z 6 (by button or by console)
            https://i.postimg.cc/7YP95B55/GIF-move1.gif
            Matrix will be modified to maxi 126 * 126 * 126
            Theorical number of Matrix: 16 * 16 * 16 = 4096 !
            Only with these little 3 videos we have to the end of Univers for explore possibilities! πŸ˜„
            https://i.postimg.cc/pLpBZpYx/GIF-totem.gif
            Some speedy πŸ˜„
            The trimming can be made between each function by a simple clic on the red form!
            (not made here except at the end)
            https://i.postimg.cc/R0QFjTvB/GIF-monstre.gif
            Intersection
            http://moiscript.weebly.com/uploads/3/9/3/8/3938813/gif-intersection_orig.gif
            • M (All mode Region All Voxel)
            • Selection green object
            • Ctrl (Move green object)
            • Shift + Click on blue object
            • Ctrl + X or Delete
            Union
            http://moiscript.weebly.com/uploads/3/9/3/8/3938813/gif-union_orig.gif
            • Ctrl + Move (blue, green)
            • Click on blue light object
            • I Color as you want!
            Cylinder
            • primitive Circle ...extruded (aTtach Face)
            https://i.postimg.cc/XYDcgfDN/GIF-tube-magica.gif
            For a tube: can be a boolean Diff between 2 cylinders but this is more funny! πŸ˜„
            • Selection top M
            • function on console "ero xy" (like internal offset)
            • aTtach Face with Shift or not following you want erase or create to the deepth wished
            https://i.postimg.cc/PqpbVCBW/GIF-tub-magica.gif
            For the training in less one minute! β˜€
            https://i.postimg.cc/qqXxcWWW/matinale.jpg
            The original start model! So less 30 seconds and 30 seconds free for rendering parameters if not yet existing! πŸ˜„
            Repeat xy 4 button was used and rectangle selection for erase roof volumes or span not wanted πŸ€“
            https://i.postimg.cc/pdKrdj4X/bloc9.jpg
              SUnrizing! πŸ˜„
              https://i.postimg.cc/htDz5W8s/sunrizing.jpg
              The render engine is a great magician! πŸ˜‰
              Here the model of the image above!
              https://i.postimg.cc/g2tJtw2c/sunrize.jpg
                THx πŸ˜‰
                https://i.postimg.cc/gjnn7gd0/val01.jpg
                https://i.postimg.cc/zXLkH16V/cargo1.jpg
                Process
                Cylindre - Repeat xy 4 - Erase Voxel Sphere 20 - Scale 0.2 - Repeat 5 - Rendu
                http://moiscript.weebly.com/uploads/3/9/3/8/3938813/gif-vid01_orig.gif
                https://i.postimg.cc/RVmWm8yJ/trivial.png
                https://i.postimg.cc/x8fqvNKy/triviale3.jpg
                  How to ? πŸ˜„
                  https://i.postimg.cc/nV9hM14v/GIF-forme-bleue.gif
                  Matrix by default 40 40 40 - Cube - 2 Lines (straight) - eRase - Face - X(Ctrl+1) - Circle under the base - eRase - Face - Z (Ctrl + 3)
                  Circle on lateral face -eRase - Face - X(Ctrl+1) - repeat 5 - Ctrl on the object for glide on Z for move the circle hat!
                  (all by buttons and/ shortcuts)
                  and all we have to do is play with the rendering parameters!
                  For the rendering and position of the camera it's up to you! πŸ˜„
                  Colours/thickness of edges, grids, transparent materials, lighting, elongations on x,y,z, Stereographic projection!
                  120 above or 220 as follow for example for Stereographic projection
                  In one minute it's settled!
                  Only with this kind of shape it is the infinite possibilities!)
                  The longest one is actually the rendering time: 20 seconds depending on the machines and the size of the image!
                  https://i.postimg.cc/HsGsM7zF/sunrizing1.jpg
                    Lights!
                    https://i.postimg.cc/y8FrYWYm/lights1.jpg
                    Circles from a cube! πŸ˜„
                    https://i.postimg.cc/N0y2mHTr/rondoo.jpg
                    https://i.postimg.cc/HxDnMPdf/little-cube.jpg
                      2 variants added at the Pseudofractal by Kchapelier
                      https://i.postimg.cc/wM2d8Lcf/Pseudo-fractal-variant.jpg
                      Of course you can make pseudofractal of pseudofractal! πŸ˜„
                        https://i.postimg.cc/4xYSMX9R/violet.jpg
                        https://i.postimg.cc/DzmZNjrM/blueship.jpg
                        https://i.postimg.cc/zXSmPVCb/eyes.jpg
                          ...and following apply many time the crazy shader Pseudofractal on any start volume by kchapelier
                          xs pseudofractal-sub 1.0 1.0 1.0 1.06 26. 0.4 0 (only change 1.06 to 1.07 to 1.08)
                          A Veira da Silva inspiration! πŸ˜‰
                          https://i.postimg.cc/Hk3wjFKx/dasilva.png
                            Happy new year! β˜€
                            https://i.postimg.cc/7Yy84G3N/new-year.jpg
                              A little piece of cake...
                              https://i.postimg.cc/qMxfhRS2/large-view.jpg
                              ...but if you zoom...
                              https://i.postimg.cc/bwmKg5zJ/flowers2.jpg
                              .etc...
                              ...that is a marvelous world of infinite fruits, flowers..
                              https://i.postimg.cc/nLMNP1z1/flowers1.jpg
                              Amazing isn't it ? πŸ˜„
                              https://i.postimg.cc/XYq2jYbj/flowers4.jpg
                              If you want play with it... careful zoom is very sensible!
                              Enable Stereoscopic Projection 170Β°, Sun 10Β°/40Β°...Ozone 50%...Voxel .. X/1.10, Y/5, Z/1.5...Shape Sphere...
                              Have fun exploration! β˜€
                              The file.vox
                              THX Ephtracy for this true gem! 😎
                                Mornings
                                https://i.postimg.cc/MHxhCCS0/morn.png
                                Head
                                https://i.postimg.cc/yNjNfgbn/tete.jpg
                                https://i.postimg.cc/mDrgKZx4/tetes.jpg
                                Projections
                                https://i.postimg.cc/3NM4VLp7/GIF-project.gif
                                Crystal
                                https://i.postimg.cc/J40cfhsz/Crystal.jpg
                                Creuse
                                https://i.postimg.cc/hvhFpjqh/creuse.jpg
                                Cry
                                https://i.postimg.cc/fLM5pJSw/cry.jpg
                                Verving Domes
                                https://i.postimg.cc/C5s9SYP0/verving-dome.jpg
                                Domes
                                https://i.postimg.cc/L6z0dHq0/domes.jpg
                                Tutos
                                https://i.postimg.cc/4yDWj3Rw/anis01.jpg
                                https://i.postimg.cc/CLD05B5h/Anis02.jpg
                                Terrasses
                                https://i.postimg.cc/j22X8Kzj/terrasses.jpg
                                Hole
                                https://i.postimg.cc/TYXQhGVM/Hole.jpg
                                Smile
                                https://i.postimg.cc/9fksLz7D/Smile.jpg
                                  But if you zoom
                                  A new world of fruits, flowers is opening...
                                  Amazing is not it ? πŸ˜„
                                  If you want play with it ...Careful Zoom is very sensitive!
                                  Stereoscopic Projection 170Β°, Sun 10Β°/40Β°...Ozone 50%...Voxel .. X/1.10, Y/5, Z/1.5...Shape Shpere...
                                  Have fun exploration! 😎
                                  The file.vox
                                    We can now import any big image (png 256 colors)! 😎
                                    I don't want imagine the possibilitites! πŸ’š
                                    With my flower above...
                                    https://i.postimg.cc/1XpNTDLt/flows.jpg
                                    (56 matrix 126 * 126 * 126 here! )
                                    https://i.postimg.cc/1XxqJv72/Flowors0.jpg
                                    Thx to Zarbuz for its very cool Schematic to vox! πŸ‘
                                      Little planet...
                                      https://i.postimg.cc/QdQRt2hY/Little-planet.jpg
                                      Splach
                                      https://i.postimg.cc/SxVbdB32/splach.jpg
                                      Image/landscape...
                                      https://i.postimg.cc/yNksVmvf/perfect.jpg
                                      Logo for MagicaVoxel πŸ˜‰
                                      https://i.postimg.cc/9QSQKXhw/Logo_mv1.png
                                      Stadium...
                                      https://i.postimg.cc/YS8Myxfd/Stadium.jpg
                                      How fun...
                                      https://i.postimg.cc/j2jjxFvw/how-fun.jpg
                                      With some stretch...
                                      https://i.postimg.cc/xCff54wx/how-funny.png
                                      in a matrix only that so engine render is more cool πŸ˜‰
                                      https://i.postimg.cc/R0chXfNF/maxx.jpg
                                      So sweet...
                                      https://i.postimg.cc/NMDz8Jtx/so-sweet.jpg
                                        To make something new with old! πŸ’š
                                        This old 2D image for example....
                                        https://i.postimg.cc/XN9P98Ly/voup.png
                                        We take any 2D image (png 256 colors) and hop a little revival (thanks Zarbuz)- Importation 2D inside Magica gives new 3D worlds to explore!
                                        https://i.postimg.cc/fWYc8q6D/oldone.png
                                        https://i.postimg.cc/TYGrFq6m/oldy-new.jpg
                                        Amazing, isn't it? πŸ˜„
                                        https://i.postimg.cc/mgPNyZ46/GIF-oldyy.gif
                                          https://i.postimg.cc/Jz1QRX2B/coq.jpg
                                            All are Mona Lisa! πŸ˜„
                                            https://i.postimg.cc/D0b2ZSHL/GIF-joci.gif
                                            https://i.postimg.cc/65X3306Q/joker.jpg
                                            https://i.postimg.cc/x1QttWfS/inside-mona.jpg
                                            https://i.postimg.cc/y8d4LgYK/mona_for_ever.jpg
                                            • 2 / 4
