    MagicaVoxel as render for SU!
    70 Posts 4 Posters 39.7k Views 4 Watching
      Not sure about the product but, you certainly make great use of it. Nicely done, Sir.
        Selection stay of course valid for any other function! πŸ˜‰
        Here like Repeat z 6 (by button or by console)
        https://i.postimg.cc/7YP95B55/GIF-move1.gif
        Matrix will be modified to maxi 126 * 126 * 126
        Theorical number of Matrix: 16 * 16 * 16 = 4096 !
        Only with these little 3 videos we have to the end of Univers for explore possibilities! πŸ˜„
        https://i.postimg.cc/pLpBZpYx/GIF-totem.gif
        Some speedy πŸ˜„
        The trimming can be made between each function by a simple clic on the red form!
        (not made here except at the end)
        https://i.postimg.cc/R0QFjTvB/GIF-monstre.gif
        Intersection
        http://moiscript.weebly.com/uploads/3/9/3/8/3938813/gif-intersection_orig.gif
        • M (All mode Region All Voxel)
        • Selection green object
        • Ctrl (Move green object)
        • Shift + Click on blue object
        • Ctrl + X or Delete
        Union
        http://moiscript.weebly.com/uploads/3/9/3/8/3938813/gif-union_orig.gif
        • Ctrl + Move (blue, green)
        • Click on blue light object
        • I Color as you want!
        Cylinder
        • primitive Circle ...extruded (aTtach Face)
        https://i.postimg.cc/XYDcgfDN/GIF-tube-magica.gif
        For a tube: can be a boolean Diff between 2 cylinders but this is more funny! πŸ˜„
        • Selection top M
        • function on console "ero xy" (like internal offset)
        • aTtach Face with Shift or not following you want erase or create to the deepth wished
        https://i.postimg.cc/PqpbVCBW/GIF-tub-magica.gif
        For the training in less one minute! β˜€
        https://i.postimg.cc/qqXxcWWW/matinale.jpg
        The original start model! So less 30 seconds and 30 seconds free for rendering parameters if not yet existing! πŸ˜„
        Repeat xy 4 button was used and rectangle selection for erase roof volumes or span not wanted πŸ€“
        https://i.postimg.cc/pdKrdj4X/bloc9.jpg
          SUnrizing! πŸ˜„
          https://i.postimg.cc/htDz5W8s/sunrizing.jpg
          The render engine is a great magician! πŸ˜‰
          Here the model of the image above!
          https://i.postimg.cc/g2tJtw2c/sunrize.jpg
            THx πŸ˜‰
            https://i.postimg.cc/gjnn7gd0/val01.jpg
            https://i.postimg.cc/zXLkH16V/cargo1.jpg
            Process
            Cylindre - Repeat xy 4 - Erase Voxel Sphere 20 - Scale 0.2 - Repeat 5 - Rendu
            http://moiscript.weebly.com/uploads/3/9/3/8/3938813/gif-vid01_orig.gif
            https://i.postimg.cc/RVmWm8yJ/trivial.png
            https://i.postimg.cc/x8fqvNKy/triviale3.jpg
              How to ? πŸ˜„
              https://i.postimg.cc/nV9hM14v/GIF-forme-bleue.gif
              Matrix by default 40 40 40 - Cube - 2 Lines (straight) - eRase - Face - X(Ctrl+1) - Circle under the base - eRase - Face - Z (Ctrl + 3)
              Circle on lateral face -eRase - Face - X(Ctrl+1) - repeat 5 - Ctrl on the object for glide on Z for move the circle hat!
              (all by buttons and/ shortcuts)
              and all we have to do is play with the rendering parameters!
              For the rendering and position of the camera it's up to you! πŸ˜„
              Colours/thickness of edges, grids, transparent materials, lighting, elongations on x,y,z, Stereographic projection!
              120 above or 220 as follow for example for Stereographic projection
              In one minute it's settled!
              Only with this kind of shape it is the infinite possibilities!)
              The longest one is actually the rendering time: 20 seconds depending on the machines and the size of the image!
              https://i.postimg.cc/HsGsM7zF/sunrizing1.jpg
                Lights!
                https://i.postimg.cc/y8FrYWYm/lights1.jpg
                Circles from a cube! πŸ˜„
                https://i.postimg.cc/N0y2mHTr/rondoo.jpg
                https://i.postimg.cc/HxDnMPdf/little-cube.jpg
                  2 variants added at the Pseudofractal by Kchapelier
                  https://i.postimg.cc/wM2d8Lcf/Pseudo-fractal-variant.jpg
                  Of course you can make pseudofractal of pseudofractal! πŸ˜„
                    https://i.postimg.cc/4xYSMX9R/violet.jpg
                    https://i.postimg.cc/DzmZNjrM/blueship.jpg
                    https://i.postimg.cc/zXSmPVCb/eyes.jpg
                      ...and following apply many time the crazy shader Pseudofractal on any start volume by kchapelier
                      xs pseudofractal-sub 1.0 1.0 1.0 1.06 26. 0.4 0 (only change 1.06 to 1.07 to 1.08)
                      A Veira da Silva inspiration! πŸ˜‰
                      https://i.postimg.cc/Hk3wjFKx/dasilva.png
                        Happy new year! β˜€
                        https://i.postimg.cc/7Yy84G3N/new-year.jpg
                          A little piece of cake...
                          https://i.postimg.cc/qMxfhRS2/large-view.jpg
                          ...but if you zoom...
                          https://i.postimg.cc/bwmKg5zJ/flowers2.jpg
                          .etc...
                          ...that is a marvelous world of infinite fruits, flowers..
                          https://i.postimg.cc/nLMNP1z1/flowers1.jpg
                          Amazing isn't it ? πŸ˜„
                          https://i.postimg.cc/XYq2jYbj/flowers4.jpg
                          If you want play with it... careful zoom is very sensible!
                          Enable Stereoscopic Projection 170Β°, Sun 10Β°/40Β°...Ozone 50%...Voxel .. X/1.10, Y/5, Z/1.5...Shape Sphere...
                          Have fun exploration! β˜€
                          The file.vox
                          THX Ephtracy for this true gem! 😎
                            Mornings
                            https://i.postimg.cc/MHxhCCS0/morn.png
                            Head
                            https://i.postimg.cc/yNjNfgbn/tete.jpg
                            https://i.postimg.cc/mDrgKZx4/tetes.jpg
                            Projections
                            https://i.postimg.cc/3NM4VLp7/GIF-project.gif
                            Crystal
                            https://i.postimg.cc/J40cfhsz/Crystal.jpg
                            Creuse
                            https://i.postimg.cc/hvhFpjqh/creuse.jpg
                            Cry
                            https://i.postimg.cc/fLM5pJSw/cry.jpg
                            Verving Domes
                            https://i.postimg.cc/C5s9SYP0/verving-dome.jpg
                            Domes
                            https://i.postimg.cc/L6z0dHq0/domes.jpg
                            Tutos
                            https://i.postimg.cc/4yDWj3Rw/anis01.jpg
                            https://i.postimg.cc/CLD05B5h/Anis02.jpg
                            Terrasses
                            https://i.postimg.cc/j22X8Kzj/terrasses.jpg
                            Hole
                            https://i.postimg.cc/TYXQhGVM/Hole.jpg
                            Smile
                            https://i.postimg.cc/9fksLz7D/Smile.jpg
                              But if you zoom
                              A new world of fruits, flowers is opening...
                              Amazing is not it ? πŸ˜„
                              If you want play with it ...Careful Zoom is very sensitive!
                              Stereoscopic Projection 170Β°, Sun 10Β°/40Β°...Ozone 50%...Voxel .. X/1.10, Y/5, Z/1.5...Shape Shpere...
                              Have fun exploration! 😎
                              The file.vox
                                We can now import any big image (png 256 colors)! 😎
                                I don't want imagine the possibilitites! πŸ’š
                                With my flower above...
                                https://i.postimg.cc/1XpNTDLt/flows.jpg
                                (56 matrix 126 * 126 * 126 here! )
                                https://i.postimg.cc/1XxqJv72/Flowors0.jpg
                                Thx to Zarbuz for its very cool Schematic to vox! πŸ‘
                                  Little planet...
                                  https://i.postimg.cc/QdQRt2hY/Little-planet.jpg
                                  Splach
                                  https://i.postimg.cc/SxVbdB32/splach.jpg
                                  Image/landscape...
                                  https://i.postimg.cc/yNksVmvf/perfect.jpg
                                  Logo for MagicaVoxel πŸ˜‰
                                  https://i.postimg.cc/9QSQKXhw/Logo_mv1.png
                                  Stadium...
                                  https://i.postimg.cc/YS8Myxfd/Stadium.jpg
                                  How fun...
                                  https://i.postimg.cc/j2jjxFvw/how-fun.jpg
                                  With some stretch...
                                  https://i.postimg.cc/xCff54wx/how-funny.png
                                  in a matrix only that so engine render is more cool πŸ˜‰
                                  https://i.postimg.cc/R0chXfNF/maxx.jpg
                                  So sweet...
                                  https://i.postimg.cc/NMDz8Jtx/so-sweet.jpg
                                    To make something new with old! πŸ’š
                                    This old 2D image for example....
                                    https://i.postimg.cc/XN9P98Ly/voup.png
                                    We take any 2D image (png 256 colors) and hop a little revival (thanks Zarbuz)- Importation 2D inside Magica gives new 3D worlds to explore!
                                    https://i.postimg.cc/fWYc8q6D/oldone.png
                                    https://i.postimg.cc/TYGrFq6m/oldy-new.jpg
                                    Amazing, isn't it? πŸ˜„
                                    https://i.postimg.cc/mgPNyZ46/GIF-oldyy.gif
                                      https://i.postimg.cc/Jz1QRX2B/coq.jpg
                                        All are Mona Lisa! πŸ˜„
                                        https://i.postimg.cc/D0b2ZSHL/GIF-joci.gif
                                        https://i.postimg.cc/65X3306Q/joker.jpg
                                        https://i.postimg.cc/x1QttWfS/inside-mona.jpg
                                        https://i.postimg.cc/y8d4LgYK/mona_for_ever.jpg
                                          Speedy...
                                          https://i.postimg.cc/QNpvF7Vh/speed.jpg
                                          https://i.postimg.cc/tCpwWgVP/speedy1.jpg
                                          https://i.postimg.cc/VLgTRcjh/Speedy2.jpg
                                            From a very famous Frenchy painting! πŸ˜„
                                            Dream island
                                            https://i.postimg.cc/jdt0kkpp/dream_douanier.jpg
                                            from Le rΓͺve du Douanier Rousseau ... 1910...
                                            https://i.postimg.cc/C5Hyxjqr/GIF_dream.gif
                                            • 2 / 4
