    MagicaVoxel as render for SU!
    70 Posts 4 Posters 42.8k Views 4 Watching
      In BinVox
      https://i.postimg.cc/KzcTgdzR/loco.jpg
      In Magica
      https://i.postimg.cc/43gVXKRv/loco-zarbuz.jpg
      https://i.postimg.cc/m2K76Xd5/locotest.jpg
      A little more complex for validate the process πŸ˜„
      With a ZBrush object 1.4 millions cubes
      Thx Patrick Min (Binvox), Zarbuz (SchematicToVox) and of course Ephtracy! πŸ˜„
      https://i.postimg.cc/T185prjk/ZB-object.jpg
      No Problem!
      https://i.postimg.cc/Zq7rKBDg/zbOBJECT.png
      • jujuJ
        juju
        Can you set "pixel" the resolution? It would probably need to be in the region of 25 - 50 microns (real world) to cover most architectural eventualities.
          If you want to say "reduce the cube's size" to a pixel...
          I must investigate for MagicaVoxel!
          (i have seen some parameters in Binvox...so maybe...but not sure... πŸ˜„
          I know that 3DCoat makes that! πŸ˜‰
          (cool videos by this guy! πŸ€“
          For hard surfaces
          and for architecture πŸ˜‰
            @juju
            Alas if theorically Binvox can input 1024 as resolution i can just input 768 (3 * 256) as maxi resolution (maybe i have not enough memory)... so seems the resolution maxi will be this shown above for the ZBrush object!...
              With free SketchUp Make 2017 and Deskbuilder by SdMitch
              https://i.postimg.cc/ryCvVnZ0/rampes02.png
              https://i.postimg.cc/TPD4ZCWP/rampes01.jpg
              And infinite variations of some stereoscopic projection! πŸ˜„
              https://i.postimg.cc/T19XSG4G/rampes03.jpg
                Something very important that I just discover! πŸ˜„
                You can make Boolean Diff without use Patterns!
                Just draw an object in a free space and with a different color of the object to trim!
                And not make like me a selection inside an existing object!
                2 weeks or more for discovered that! I am amazed that nobody tell me that! πŸ˜„
                A boolean union will be jut to colorize the objects with a same color! πŸ˜‰
                This can be enabled!
                https://i.postimg.cc/mgwwZrF9/a-enable.jpg
                https://i.postimg.cc/sfQwPytF/GIF-bingo.gif
                Can be partial!
                https://i.postimg.cc/h4kMp6BX/GIF-partiel.gif
                  https://i.postimg.cc/65LrbmWc/circa.jpg
                  https://i.postimg.cc/CxcjSnff/rondi.jpg
                  https://i.postimg.cc/bvd1JYQV/rondii.jpg
                  Speaking with PaQ on its OOS Drillers! πŸ˜„
                  https://i.postimg.cc/hGYMDptH/boxbuild.jpg
                  https://i.postimg.cc/NMfYtGLN/boxbuild1.jpg
                    And the cool thing is that can be "Multiple" & "Mono" or "Multi-colors"!
                    (M) + Shift for reselect when trimming is done by the first click on the cutting objects!
                    Ctrl on a face for move the selection!
                    https://i.postimg.cc/ZKHzQnkQ/GIF-mult.gif
                      Not sure about the product but, you certainly make great use of it. Nicely done, Sir.
                        Selection stay of course valid for any other function! πŸ˜‰
                        Here like Repeat z 6 (by button or by console)
                        https://i.postimg.cc/7YP95B55/GIF-move1.gif
                        Matrix will be modified to maxi 126 * 126 * 126
                        Theorical number of Matrix: 16 * 16 * 16 = 4096 !
                        Only with these little 3 videos we have to the end of Univers for explore possibilities! πŸ˜„
                        https://i.postimg.cc/pLpBZpYx/GIF-totem.gif
                        Some speedy πŸ˜„
                        The trimming can be made between each function by a simple clic on the red form!
                        (not made here except at the end)
                        https://i.postimg.cc/R0QFjTvB/GIF-monstre.gif
                        Intersection
                        http://moiscript.weebly.com/uploads/3/9/3/8/3938813/gif-intersection_orig.gif
                        • M (All mode Region All Voxel)
                        • Selection green object
                        • Ctrl (Move green object) Β
                        • Shift + Click on blue object
                        • Ctrl + X or Delete
                        Union
                        http://moiscript.weebly.com/uploads/3/9/3/8/3938813/gif-union_orig.gif
                        • Ctrl + Move (blue, green)
                        • Click on blue light object
                        • I Color as you want!
                        Cylinder
                        • primitive Circle ...extruded (aTtach Face)
                        https://i.postimg.cc/XYDcgfDN/GIF-tube-magica.gif
                        For a tube: can be a boolean Diff between 2 cylinders but this is more funny! πŸ˜„
                        • Selection top M
                        • function on console "ero xy" (like internal offset)
                        • aTtach Face with Shift or not following you want erase or create to the deepth wished
                        https://i.postimg.cc/PqpbVCBW/GIF-tub-magica.gif
                        For the training in less one minute! β˜€
                        https://i.postimg.cc/qqXxcWWW/matinale.jpg
                        The original start model! So less 30 seconds and 30 seconds free for rendering parameters if not yet existing! πŸ˜„
                        Repeat xy 4 button was used and rectangle selection for erase roof volumes or span not wanted πŸ€“
                        https://i.postimg.cc/pdKrdj4X/bloc9.jpg
                          SUnrizing! πŸ˜„
                          https://i.postimg.cc/htDz5W8s/sunrizing.jpg
                          The render engine is a great magician! πŸ˜‰
                          Here the model of the image above!
                          https://i.postimg.cc/g2tJtw2c/sunrize.jpg
                            THx πŸ˜‰
                            https://i.postimg.cc/gjnn7gd0/val01.jpg
                            https://i.postimg.cc/zXLkH16V/cargo1.jpg
                            Process
                            Cylindre - Repeat xy 4 - Erase Voxel Sphere 20 - Scale 0.2 - Repeat 5 - Rendu
                            http://moiscript.weebly.com/uploads/3/9/3/8/3938813/gif-vid01_orig.gif
                            https://i.postimg.cc/RVmWm8yJ/trivial.png
                            https://i.postimg.cc/x8fqvNKy/triviale3.jpg
                              How to ? πŸ˜„
                              https://i.postimg.cc/nV9hM14v/GIF-forme-bleue.gif
                              Matrix by default 40 40 40 - Cube - 2 Lines (straight) - eRase - Face - X(Ctrl+1) - Circle under the base - eRase - Face - Z (Ctrl + 3)
                              Circle on lateral face -eRase - Face - X(Ctrl+1) - repeat 5 - Ctrl on the object for glide on Z for move the circle hat!
                              (all by buttons and/ shortcuts)
                              and all we have to do is play with the rendering parameters!
                              For the rendering and position of the camera it's up to you! πŸ˜„
                              Colours/thickness of edges, grids, transparent materials, lighting, elongations on x,y,z, Stereographic projection!
                              120 above or 220 as follow for example for Stereographic projection
                              In one minute it's settled!
                              Only with this kind of shape it is the infinite possibilities!)
                              The longest one is actually the rendering time: 20 seconds depending on the machines and the size of the image!
                              https://i.postimg.cc/HsGsM7zF/sunrizing1.jpg
                                Lights!
                                https://i.postimg.cc/y8FrYWYm/lights1.jpg
                                Circles from a cube! πŸ˜„
                                https://i.postimg.cc/N0y2mHTr/rondoo.jpg
                                https://i.postimg.cc/HxDnMPdf/little-cube.jpg
                                  2 variants added at the Pseudofractal by Kchapelier
                                  https://i.postimg.cc/wM2d8Lcf/Pseudo-fractal-variant.jpg
                                  Of course you can make pseudofractal of pseudofractal! πŸ˜„
                                    https://i.postimg.cc/4xYSMX9R/violet.jpg
                                    https://i.postimg.cc/DzmZNjrM/blueship.jpg
                                    https://i.postimg.cc/zXSmPVCb/eyes.jpg
                                      ...and following apply many time the crazy shader Pseudofractal on any start volume by kchapelier
                                      xs pseudofractal-sub 1.0 1.0 1.0 1.06 26. 0.4 0 (only change 1.06 to 1.07 to 1.08)
                                      A Veira da Silva inspiration! πŸ˜‰
                                      https://i.postimg.cc/Hk3wjFKx/dasilva.png
                                        Happy new year! β˜€
                                        https://i.postimg.cc/7Yy84G3N/new-year.jpg
                                          A little piece of cake...
                                          https://i.postimg.cc/qMxfhRS2/large-view.jpg
                                          ...but if you zoom...
                                          https://i.postimg.cc/bwmKg5zJ/flowers2.jpg
                                          .etc...
                                          ...that is a marvelous world of infinite fruits, flowers..
                                          https://i.postimg.cc/nLMNP1z1/flowers1.jpg
                                          Amazing isn't it ? πŸ˜„
                                          https://i.postimg.cc/XYq2jYbj/flowers4.jpg
                                          If you want play with it... careful zoom is very sensible!
                                          Enable Stereoscopic Projection 170Β°, Sun 10Β°/40Β°...Ozone 50%...Voxel .. X/1.10, Y/5, Z/1.5...Shape Sphere...
                                          Have fun exploration! β˜€
                                          The file.vox
                                          THX Ephtracy for this true gem! 😎
                                            Mornings
                                            https://i.postimg.cc/MHxhCCS0/morn.png
                                            Head
                                            https://i.postimg.cc/yNjNfgbn/tete.jpg
                                            https://i.postimg.cc/mDrgKZx4/tetes.jpg
                                            Projections
                                            https://i.postimg.cc/3NM4VLp7/GIF-project.gif
                                            Crystal
                                            https://i.postimg.cc/J40cfhsz/Crystal.jpg
                                            Creuse
                                            https://i.postimg.cc/hvhFpjqh/creuse.jpg
                                            Cry
                                            https://i.postimg.cc/fLM5pJSw/cry.jpg
                                            Verving Domes
                                            https://i.postimg.cc/C5s9SYP0/verving-dome.jpg
                                            Domes
                                            https://i.postimg.cc/L6z0dHq0/domes.jpg
                                            Tutos
                                            https://i.postimg.cc/4yDWj3Rw/anis01.jpg
                                            https://i.postimg.cc/CLD05B5h/Anis02.jpg
                                            Terrasses
                                            https://i.postimg.cc/j22X8Kzj/terrasses.jpg
                                            Hole
                                            https://i.postimg.cc/TYXQhGVM/Hole.jpg
                                            Smile
                                            https://i.postimg.cc/9fksLz7D/Smile.jpg
                                            • 2 / 4
