    Transfer 'color by layer' to 'color by material'
    6 Posts 2 Posters 1.3k Views 2 Watching
      rv1974
      Have you seen the plugin that does the subject?
      Thanks in advance
        To clarify...
        Do you mean, to take each layer's color, and use that color for a [new] material [probably named based on the parent-layer's name?], then apply that material to all entities which are assigned that layer.
        If so try this... copy+paste+enter in the Ruby Console.
        mo=Sketchup.active_model
        cs={}
        ns=[]
        ls=mo.layers
        p ls[0].name
        ls.to_a[1..-1].each{|e| #skip Layer0
          cs[e.name]=e.color
          ns<<e.name
        mo.start_operation('lcol>>mcol',true)
        ms=mo.materials
        ns.each{|k|
          m=ms.add(k) unless m=ms[k]
          m.color=cs[k]
        mo.entities.each{|e|
          e.material=ms[e.layer.name] unless e.layer==ls[0] #Layer0
        mo.definitions.each{|d|
          next if d.image?
          if d.group?
            d.entities.each{|e|
          else #compo
            d.entities.each{|e|
            d.instances.each{|e|
        mo.commit_operation
        puts
        It's one step undoable.
        It currently skips processing 'Layer0' - but to include it change:
        ls.to_a[1..-1].each to read ls.each
        and add a new # in front of the 4 lines **#** unless e.layer==ls[0] #Layer0
        Toggle between Material and Layer view settings to see the effect...
          rv1974
          Works almost perfect. Please check PM.
          Many thanks!
            Transparency [alpha] in colors used 'by layer' is not detectable - I think?
            It always returns 255, even when it displays as less !
            Neither is a layer's 'texture'.
            This version also processes 'back-face color'.
            cs={}
            ns=[]
            ls=mo.layers
            p ls[0].name
              cs[e.name]=e.color
              ns<<e.name
            ms=mo.materials
            ns.each{|k|
              m.color=cs[k]
              e.back_material=ms[e.layer.name] if e.is_a?(Sketchup;;Face) && e.layer!=ls[0] #Layer0
              next if d.image?
              if d.group?
                d.entities.each{|e|
              else #compo
                d.entities.each{|e|
            mo.commit_operation
            puts
              rv1974
              Amazing! Many thanks.
              P.S. Please publish it it Store so it won't get buried in forum.
                Let's wait a day or two until it gets fine tuned...
