    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    699 Posts 160 Posters 605.9k Views 159 Watching
      Anton_S
      @stinkie said:
      I'm interested in buying ClothWorks. My modeling and rendering machine isn't connected to the internet, though. Is that a problem?
      From my understanding, you only need internet to active licence, deactivate licence, and refresh seats. Once activated, you can use ClothWorks without internet.
      • Gus RG Offline
        Gus R
        Thanks Anton.
        Not sure if this will help but it looks like "SCFLicense_ClothWorks_this_computer.txt" in the "SCF Licenses" gets re-written at first and then changes every time you check the license status.
        The first dozen or so letters inside that file corresponds to a directory created in the Window temp directory which contains a .tmp file with a different name.
        If the latest .tmp directory is deleted you will lose the license and have to start all over again after seats are lost.
        That would explain the CCleaner problem someone mentioned earlier in this topic since CCleaner will delete all contents of the temp directory. It's also common for a lot of Windows users to clear that directory.
        www.instagram.com/gusrobatto/
        www.facebook.com/gusrobatto
        • StinkieS Offline
          Stinkie
          Thanks.
          • N Offline
            NguyenKien1411
            thanks a lot 😘
            • StinkieS Offline
              Stinkie
              Finally got around to trying out CW.
              Really cool. Well done! 👍
                Malidus
                Hi All!
                Can anyone help me?
                Always getting an error message when i want to license clothworks..
                Did un- and reinstall clothworks, and also sketchucationtools gut i always get this error message...
                Regards, Mario
                  Gábor
                  @malidus said:
                  Can anyone help me?
                  If you are on a PC you can try to erase the signature file at C:\Users*username\AppData\Local\SCF Licenses\SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt*. Then re-start SketchUp and try to re-activate ClothWorks.
                  On MAC the file is named the same but i'm not sure about the folder. So maybe searching for it could help.
                    Anton_S
                    Mario,
                    Accommodating Gabor's suggestion, you can refer to the following guide on resetting your licence, page 4, Known Issue section: ClothWorks Licensing
                    I have also sent you an email regarding an alternative solution.
                    Anton
                      GadgetB
                      @dave r said:
                      @trenton.gauthier said:
                      ...but I'm missing the right click / aka context menu which is preventing me from using the newly purchased plugin.
                      The Context menu is just that. The menu items in it depend upon the context you are clicking on. You are right clicking on loose geometry. To get Clothworks to show, you need to right click on a component or group.
                      When all else fails, read the manual.
                      [attachment=1:wlkp41pu]<!-- ia1 -->Screenshot - 8_3_2018 , 11_11_52 AM.png<!-- ia1 -->[/attachment:wlkp41pu]
                      I had a play with this when I downloaded it and it worked brilliantly... but now I can't find the context menu - any idea how to reinstate it?
                        Anton_S
                        @GadgetB There is only a few aspects that I think could be the cause. If you navigate to your plugins folder, first see that ams_ClothWorks folder and ams_ClothWorks.rb file are in there.
                        You can paste this command to your folder explorer address bar to quickly navigate to plugins folder:
                        %appdata%\SketchUp\SketchUp 2018\SketchUp\Plugins
                        An easy way to fix is by deleting the plugin and installing it again, either via the Extension Warehouse install button command or SketchUcation PluginStore. When you perform this, ensure SketchUp is closed before you do so. To delete the plugin, simply erase ams_ClothWorks folder and ams_ClothWorks.rb file from the plugins folder.
                          GadgetB
                          I worked out that you only get the context menu on first-level grouping; it doesn't like groups within groups.
                            stuff4oleg
                            I've just noticed that ClothWorks doesn't work inside Groups: you just can't see it's context menu.
                            I.e. if you have empty scene with your cloth geometry inside the group and this group is on top level inside the Outliner, then you can right-click, make it Cloth (or collider) and so on, like it is shown in all those Youtube videos.
                            But as soon as you put your "Cloth" group inside another group or component, get in this grouping group, you can no longer see context menu.
                            This is very restrictive, most scenes are very complex and have complex hierarchies.
                              rogalxxx
                              any Black Friday deals on clothworks?
                                Anton_S
                                @rogalxxx Good idea. There is a high chance for a cyber Monday deal!
                                  Julian_Collinge
                                  Brilliant - this was the issue I had after spending much time installing, uninstalling, reinstalling.
                                  FIRST LEVEL GROUPS ONLY!
                                    Anton_S
                                    Announcing version 1.5!
                                    Features include reworked physics, redesigned UI, adaptive remeshing, as well as, quadrilateral, equilateral, and adaptive grids.
                                    At the moment, I have only made one tutorial featuring Adaptive Remeshing. A tutorial about equilateral and adaptive grids will follow in the future. As for a small intro, adaptive grids are useful for simulating tents and complex cloth structures. Adaptive grid replaces the original Smart Grid and goes much further, allowing for applying grids to 3d shapes. As regards to quadrilateral and equilateral grids, the structure of quadrilateral grid is imbalanced and makes hanging cloth stretch unequally at cross-diagonal directions. Equilateral grid is a useful alternative for simulating curtains or any other hanging cloth. Unlike equilateral grid, quadrilateral grid is compatible with quad modelling.
                                    A detailed list of changes can be viewed at ClothWorks PluginStore page: https://sketchucation.com/plugin/2053-clothworks
                                    And and here is the Adaptive Remeshing tutorial:
                                    Have a great 2018!
                                    -- Anton
                                    • PixeroP Offline
                                      Pixero
                                      After installing the latest version I get this:
                                        Anton_S
                                        [attachment=0:28c1uhfa]<!-- ia0 -->screen.JPG<!-- ia0 -->[/attachment:28c1uhfa]
                                        Can you try a fresh install by deleting ClothWorks from plugins forlder and than installing?
                                        • PixeroP Offline
                                          Pixero
                                          Doing a fresh install seem to have fixed the issue. Thanks.
                                          • HornOxxH Offline
                                            HornOxx
                                            Hello All
                                            about 2 weeks ago my old faithful notebook broke down and all attempts to reanimate it failed. Now, finally I sit in front of a new machine and try to reconstruct my entire so far "SkUp world" 😉 .
                                            One component of this world has been Clothworks from which I cannot reconstruct any informations. I can't even figure out how or where I bought the license or how this purchase would work now.
                                            If someone helps me here I might be able to reconstruct the purchase via PayPal at least, hopefully!
                                            I'd be happy if someone could give me some guidance 😄
                                            never trust a skinny cook
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 34
                                            • 35
                                            • 17 / 35
