    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    729 Posts 170 Posters 940.6k Views 171 Watching
    • N
      NguyenKien1411
      thanks a lot 😘
      • StinkieS
        Stinkie
        Finally got around to trying out CW.
        Really cool. Well done! 👍
          Malidus
          Hi All!
          Can anyone help me?
          Always getting an error message when i want to license clothworks..
          Did un- and reinstall clothworks, and also sketchucationtools gut i always get this error message...
          Regards, Mario
          • G
            GĂĄbor
            @malidus said:
            Can anyone help me?
            If you are on a PC you can try to erase the signature file at C:\Users*username\AppData\Local\SCF Licenses\SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt*. Then re-start SketchUp and try to re-activate ClothWorks.
            On MAC the file is named the same but i'm not sure about the folder. So maybe searching for it could help.
              Anton_S
              Mario,
              Accommodating Gabor's suggestion, you can refer to the following guide on resetting your licence, page 4, Known Issue section: ClothWorks Licensing
              I have also sent you an email regarding an alternative solution.
              Anton
              • G
                GadgetB
                @dave r said:
                @trenton.gauthier said:
                ...but I'm missing the right click / aka context menu which is preventing me from using the newly purchased plugin.
                The Context menu is just that. The menu items in it depend upon the context you are clicking on. You are right clicking on loose geometry. To get Clothworks to show, you need to right click on a component or group.
                When all else fails, read the manual.
                [attachment=1:wlkp41pu]<!-- ia1 -->Screenshot - 8_3_2018 , 11_11_52 AM.png<!-- ia1 -->[/attachment:wlkp41pu]
                I had a play with this when I downloaded it and it worked brilliantly... but now I can't find the context menu - any idea how to reinstate it?
                  Anton_S
                  @GadgetB There is only a few aspects that I think could be the cause. If you navigate to your plugins folder, first see that ams_ClothWorks folder and ams_ClothWorks.rb file are in there.
                  You can paste this command to your folder explorer address bar to quickly navigate to plugins folder:
                  %appdata%\SketchUp\SketchUp 2018\SketchUp\Plugins
                  An easy way to fix is by deleting the plugin and installing it again, either via the Extension Warehouse install button command or SketchUcation PluginStore. When you perform this, ensure SketchUp is closed before you do so. To delete the plugin, simply erase ams_ClothWorks folder and ams_ClothWorks.rb file from the plugins folder.
                  • G
                    GadgetB
                    I worked out that you only get the context menu on first-level grouping; it doesn't like groups within groups.
                      stuff4oleg
                      I've just noticed that ClothWorks doesn't work inside Groups: you just can't see it's context menu.
                      I.e. if you have empty scene with your cloth geometry inside the group and this group is on top level inside the Outliner, then you can right-click, make it Cloth (or collider) and so on, like it is shown in all those Youtube videos.
                      But as soon as you put your "Cloth" group inside another group or component, get in this grouping group, you can no longer see context menu.
                      This is very restrictive, most scenes are very complex and have complex hierarchies.
                        rogalxxx
                        any Black Friday deals on clothworks?
                          Anton_S
                          @rogalxxx Good idea. There is a high chance for a cyber Monday deal!
                            Julian_Collinge
                            Brilliant - this was the issue I had after spending much time installing, uninstalling, reinstalling.
                            FIRST LEVEL GROUPS ONLY!
                              Anton_S
                              Announcing version 1.5!
                              Features include reworked physics, redesigned UI, adaptive remeshing, as well as, quadrilateral, equilateral, and adaptive grids.
                              At the moment, I have only made one tutorial featuring Adaptive Remeshing. A tutorial about equilateral and adaptive grids will follow in the future. As for a small intro, adaptive grids are useful for simulating tents and complex cloth structures. Adaptive grid replaces the original Smart Grid and goes much further, allowing for applying grids to 3d shapes. As regards to quadrilateral and equilateral grids, the structure of quadrilateral grid is imbalanced and makes hanging cloth stretch unequally at cross-diagonal directions. Equilateral grid is a useful alternative for simulating curtains or any other hanging cloth. Unlike equilateral grid, quadrilateral grid is compatible with quad modelling.
                              A detailed list of changes can be viewed at ClothWorks PluginStore page: https://sketchucation.com/plugin/2053-clothworks
                              And and here is the Adaptive Remeshing tutorial:
                              Have a great 2018!
                              -- Anton
                              • PixeroP
                                Pixero
                                After installing the latest version I get this:
                                  Anton_S
                                  [attachment=0:28c1uhfa]<!-- ia0 -->screen.JPG<!-- ia0 -->[/attachment:28c1uhfa]
                                  Can you try a fresh install by deleting ClothWorks from plugins forlder and than installing?
                                  • PixeroP
                                    Pixero
                                    Doing a fresh install seem to have fixed the issue. Thanks.
                                    • HornOxxH
                                      HornOxx
                                      Hello All
                                      about 2 weeks ago my old faithful notebook broke down and all attempts to reanimate it failed. Now, finally I sit in front of a new machine and try to reconstruct my entire so far "SkUp world" 😉 .
                                      One component of this world has been Clothworks from which I cannot reconstruct any informations. I can't even figure out how or where I bought the license or how this purchase would work now.
                                      If someone helps me here I might be able to reconstruct the purchase via PayPal at least, hopefully!
                                      I'd be happy if someone could give me some guidance 😄
                                      never trust a skinny cook
                                        Anton_S
                                        @HornOxx I sent you a private message regarding this.
                                          Ahmed0007
                                          unable to active the plugin in sketchup 2018
                                          getting this error
                                          please help.
                                            Do you have the latest version of the SCF Extension Store installed?
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 36
                                            • 37
                                            • 17 / 37
