    3ds Max to Sketchup workflow
    7 Posts 4 Posters 2.0k Views 4 Watching
      rezvan23
      Hi. Is there a way to export 3ds Max instances and import them as components in sketchup? I used Simlab Sketchup Exporter, and find out some instances imports as components but most of them not. Can anyone help please?
        Not so loud please.
          rv1974
          simlab is the best.
            rezvan23
            @mike amos said:
            Not so loud please.
            Yeah... πŸ˜†
              rezvan23
              @rv1974 said:
              simlab is the best.
              Yes rv1974. I like simlab too. It's really good at converting models from 3ds Max to Sketchup. But I have problem with instances. For example I want to convert a 3ds max tree model to sketchup model. In 3ds Max all the leaves are instances and editing them are easy. But aftar converting it with simlab to sketchup file, each leaves convert as single group, not component. Now my question is "Is there any way to export 3ds Max instances as Sketchup components?"
              • PixeroP Offline
                Pixero
                In Max I convert all materials to standard materials and export as obj then I use SIM lab to save it as skp. I think I get components through ok that way. At least I havent noticed anything but it was some time since I converted anything so I might be wrong.
                  rezvan23
                  Hi Pixero! Yes I convert all materials to standard materials too. And now I tried converting OBJ format to skp in simlab composer. it did a good job and everything is fine! all instances are components in Sketchup format. Thanks for the pro tips! πŸ‘
