[Plugin] ClothWorks v1.8.0 - 28 Apr 2024
Awsome effects Cheers Anton. (I bought the license today )
Idea: Set viscosity of collider in order to "simulate" drops moving on surface.
Very useful for geological deformations explanations.Pierre
Hi Guys, I was wondering if clothworks would be able to wrap around an object, instead of draping over something. Kinda like the reference image attached. Thanks!
I have tried putting something like this together and it seems like it can be done, well, specifically, with a newer version of ClothWorks, which is still under development.
I have attached an image and a link to SKP file listing and displaying the key steps.
https://drive.google.com/open?id=1X-39luoZWwYqP9O-j6zSt4GrTtC3YVAZAnton
https://sketchucation.com/forums/images/smilies/1f635.png Nice! Very nice! I'm looking forward to the new release. Thank you so much for this plugin! You're a godsend!
Good morning, this is probably not an issue specific to your plugin but I'm missing the right click / aka context menu which is preventing me from using the newly purchased plugin. I've taken the steps of reinstalling the plugin both through the sketchucation store and manually. I'm using a fresh install of Sketchup Pro 2017 ver. 17.2.2555 64 Bit on Windows 10 Pro ver. 1803 with an i7-6700k and GTX 1080 Ti Hybrid. I've also sent you an email.
@trenton.gauthier said:
...but I'm missing the right click / aka context menu which is preventing me from using the newly purchased plugin.
The Context menu is just that. The menu items in it depend upon the context you are clicking on. You are right clicking on loose geometry. To get Clothworks to show, you need to right click on a component or group.
When all else fails, read the manual.
when I click to (Menu) Extensions → ClothWorks → License ...
SFC License dialog box <<<<<< this never show up what to do help i have already paid -
SFC License dialog box <<<<<< this never show up what to do help i have already paidDid you install SketchUcationTools, specifically version 3.1.5? https://sketchucation.com/resources/plugin-store-download
Howdy,
LTNS. Great plugin.
Having problems licensing this. I submitted the license several times now and followed instructions to delete the three files per page 5 of 5.
When I restart Sketchup it's not licensed again.
So I tried again.
I exceeded seats and have requested a restart and will try again.
Had the latest Sketchucation tool installed but installed the latest version just in case. Didn't seem to make a difference.
License is located in C:\Users\Asus P8P67 Deluxe\AppData\Local\SCF Licenses.
Gus,
I reset your licence. Please refer to Licencing Manual, Known Issue section, starting at number 2 for further instructions: https://drive.google.com/open?id=1QLzrBm5Qy7ZQh56HNqRl_LjqxNhgd9dO
Anton
Anton,
Thanks. Looks like it took this time around but I killed one seat after deleting the following:
Those three files returned and I let them remain and it's still licensed after restart.
This is from page 5 of the install instructions.
@anton_s said:
Gus,
Anton
Gus,
I can see the seats went back up to two. If seats fill up again, send me a private message for an alternative solution.
Anton
I'm interested in buying ClothWorks. My modeling and rendering machine isn't connected to the internet, though. Is that a problem?
Anton,
Well, believe it or not it lost the license again. Was practicing with it last night and this morning and I just went back and it's not licensed again. Didn't touch anything so to speak and didn't run anything like CCleaner.
I did however clear my temp directory.
I went back and restored what I deleted from the temp file and the license came back.
License should be reliant on what's in the temp directory. Let me see if I can localize the file in the temp directory.
@anton_s said:
Gus,
Anton
Anton,
It creates a random named directory in the temp directory which rolls over on re-start of Sketchup to a new directory name. Each has a .tmp file.
Sometimes it doesn't roll over and create a new one.
If I completely delete my temp directory contents it loses the license. Returns when I undelete the last .tmp file with random directory name.
Did a clean install of Sketchucation Tools. Didn't work. It's dependent on what's in the temp directory.
Gus,
From what I recall, on Windows, SCFLicensing does indeed relent on temp folder location. Addressing that issue, however, is out of my reach.
I sent you a private message regarding an alternative solution.
Anton
From my understanding, you only need internet to active licence, deactivate licence, and refresh seats. Once activated, you can use ClothWorks without internet.
Thanks Anton.
Not sure if this will help but it looks like "SCFLicense_ClothWorks_this_computer.txt" in the "SCF Licenses" gets re-written at first and then changes every time you check the license status.
The first dozen or so letters inside that file corresponds to a directory created in the Window temp directory which contains a .tmp file with a different name.
If the latest .tmp directory is deleted you will lose the license and have to start all over again after seats are lost.
That would explain the CCleaner problem someone mentioned earlier in this topic since CCleaner will delete all contents of the temp directory. It's also common for a lot of Windows users to clear that directory.
Thanks.
