    [Plugin] SketchyFFD (Classic)
    412 Posts 153 Posters 541.0k Views 153 Watching
    • E
      Einstein
      Closed the mesh, did some cleanup, my group is a solid, but still the same 😞
        As you can see on my last image : after cleanUp seems all works fine on the good way! πŸ˜„
        (and without close sides)
        • T
          thegenius
          plugin not working in sketchup 2018. Dont know where is the problem. Please guide.
            Please give details of your SketchUp version, OS etc.
            Also please explain the steps you are trying to use with this tool...
            Double-check you are following the guidance given in the early posts...
            Also run it with the Ruby Console open and report any error messages...
            Remember that this tool is now five years without any support or updates...
            • majidM
              majid
              Any update or replace for su 2018 please?
                As far as I know, if you install the current RBZ from the PluginStore it should work in v2018.
                You must carefully follow the usage steps.
                Your Extension Manager Loading Policy must be set to 'Unrestricted' to allow older [unsigned] extensions to load and run...
                • P
                  pascalk
                  i am getting an unsigned copy problem any help ?
                  • jujuJ
                    juju
                    set your load policy to unrestricted, will load fine then
                    the extension will work the same whether it is signed or not, it is purely a mechanism to give the end-user some control over extension running on their system, in the end you (as in yourself) must make sure the extensions (and their sources) are trustworthy
                    • E
                      Einstein
                      Hi!
                      I have a problem with this plugin. I'm trying to match an FFD "box" to my group, which local axes are different from global axes of the model. I mean, they are rotated. I created an FFD group and it doesn't match my target group's axes. How can I match FFD group to local axes or my group? Instead, it matches the global axes. I could just reset rotation of my group, I know. But I don't want to do this.
                      Even if I change my model's global axes, FFD box orientation won't change. It will stick to initial orientation.
                        dindoborlaza
                        hi everyone,
                        newbee here, downloaded the .rb and .rbz file, couldn't see the plugin yet...using 2016...help!!!
                        THANKS πŸ˜„
                          It's a context-menu based tool - read the usage guidance...
                            ahmd66
                            This plugin can not work (error load) in sketchup 2019. How I could install this plugin correctly?
                              This is an old script.
                              Somethings have changed in v2019...
                              Please try running it [following the earlier guidance] with the Ruby Console open and post any error messages you might get...
                              If it's a simple issue perhaps we can fix it...
                              • F
                                Fillister
                                This is the message I am seeing in conjunction with 2019
                                Error: #<SyntaxError: C:/.../SketchUp/SketchUp 2019/SketchUp/Plugins/SketchyFFD.rb:32: Invalid return in class/module body
                                return nil
                                And a sincere thank you TIG, as this was not your plugin originally
                                  Try this fix...
                                  Find the file in your user's AppData tree C:/.../SketchUp/SketchUp 2019/SketchUp/Plugins
                                  named SketchyFFD.rb
                                  Edit it using Notepad[++] - a plain-text editor...
                                  Find line#32, and add a # to the start of the line, so that it reads:
                                  #return nil
                                  and is now ignored as it loads...
                                  Save the file, and restart SketchUp to see if that helps...
                                  The latest version of Ruby now shipped with v2019 is more unforgiving of simple syntax errors - previously this was just ignored !
                                    db11
                                    TIG - will this required syntax discipline actually reduce certain types of issues with plugins, or is it simply an added annoyance for extension developers?
                                    • F
                                      Fillister
                                      Thank you for the quick reply TIG.
                                      Your suggestion took care of the error message I was seeing. No error messages at load time now, but does not actually load. I saw your previous post:
                                      Wading through the 13 pages of posts associated with SketchyFFD to try and find the guidance. I will do my best to get you some more clues.
                                      May have to learn Ruby.
                                        You seem to be using v2019?
                                        The Extension Manager should show if its loaded.
                                        It might show it's loaded but blocked because it's unsigned [it is very old after all !]
                                        Try resetting your Extension Loading policy to "Unrestricted".
                                        Restart SketchUp.
                                        See if that helps...
                                        Also be sure you understand how the tool works through menus/context etc...
                                        • P
                                          Puco
                                          File load error (C:/Users/pucon/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/SketchyFFD.rb):
                                          Error: #<SyntaxError: C:/Users/pucon/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/SketchyFFD.rb:32: Invalid return in class/module body
                                          return nil
                                          c:/users/pucon/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/sketchucation/scf-rbztools.rbs:1288:in install_from_archive' c:/users/pucon/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/sketchucation/scf-rbztools.rbs:1288:in rbzInstaller'
                                          c:/users/pucon/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/sketchucation/scf-rbztools.rbs:1503:in rbzDirect' c:/users/pucon/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/sketchucation/scf-rbztools.rbs:1376:in loadHandler'
                                          c:/users/pucon/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/sketchucation/scf-rbztools.rbs:476:in loadFromURL' c:/users/pucon/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/sketchucation/scf-rbztools.rbs:1264:in set_choi'
                                          c:/users/pucon/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/sketchucation/scf_dialog.rbs:535:in chooseplugins' c:/users/pucon/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/sketchucation/scf_dialog.rbs:485:in autoinstall_dlg'
                                          c:/users/pucon/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/sketchucation/scf_dialog.rbs:415:in set_autoinstall_choice' c:/users/pucon/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/sketchucation/scf_dialog.rbs:81:in block in new'
                                          This is what I get in Ruby on fresh install SU 2019! If anyone knows how to fix the code of the SketchyFFD.rb file, it will be nice to get this addon in a working state.
                                          • F
                                            Fillister
                                            Puco, please notice the posts above yours from me Fillister, dated 13 FEB and in particular TIG's reply.
                                            I was receiving the same "return nil" message and TIGs helpful suggestion resolved the error message associated with SketchyFFD.
                                            After the return nil ^-----> . in your post, I am not sure you noticed, the error messages are no longer associated with SketchyFFD.
                                            Six lines refer to scf-rbztools
                                            c:/users/pucon/.../plugins/sketchucation/scf-rbztools.rbs:
                                            Four lines refer to scf_dialog
                                            c:/users/pucon/.../plugins/sketchucation/scf_dialog.rbs:
                                            Sadly I am unable to speak to those issues.
                                            TIG my apologies.
                                            In my excitement at having the return nil error so easily fixed, I rushed in to try SketchyFFD carelessly.
                                            I can now confirm there seems to be nothing wrong as far as I can tell with SketchyFFD running in SketchUp 2019 on Windows 10.
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 19 / 21
