    How to switch top to bottom of my model?
    7 Posts 5 Posters 1.4k Views 5 Watching
    • W Offline
      won46925
      Hi community,
      when I use the standard view 'top' I see my model from bottom. Because some objects must rotate by hand, I looking forward for a simple method to correct my foul.
      Has anyone an idea?
        Select all of the model and use the Rotate tool to rotate it 180Β°.
        • pbacotP Offline
          Other than that, turn your monitor upside down?
          • jgbJ Offline
            jgb
            Select whole model, then Right Click and FLIP ALONG. Probably along Blue axis.
            jgb
              That will create a mirror image of the model. Great if the model was drawn as a mirror image of what it was supposed to look like but not so good if it's merely upside down.
              • jgbJ Offline
                jgb
                He wasn't exactly clear on what the final orientation should be, so flipping is just another way to do it.
                jgb
                  Without file it's some hard to say! πŸ˜„
                  Depending of what objects must or must not be changed!
