    Axes and style horizon
    3 Posts 2 Posters 1.1k Views 2 Watching
      Lumelo
      Good morning all:
      I'm sorry of not preparing this question a better way, but… to put it plain:
      The red or green lines of my main axe doesn't match with the horizon (sky-ground) of the Style i always use. Of course i would like to fixe this, but above all, i would like to understand the situation.
      Thanks in advance for your attention/tips/knowledge.
      Luis Melo (Portugal)
        Do you use a Custom Template ?
        It is possible you changed the Template's Axes and saved it, so that now every model starts up, showing the custom Axes, rather than the model's default Axes ?
        To check this, set Axes to be visible, hover over a colored Axis, away from other things, and right-click > context-menu > Reset Axes.
        If that option is available the model's Axes should now display.
        You need to Rest Axes for any affected models using this method...
        If that is the case, then you can open a new 'empty' model using that custom Template, use Reset Axes as explained, and then save the otherwise unchanged model as a custom Template - overwriting the previous named one.
        Now new models will start with the corrected Axes...
          Lumelo
          You couldn't be more right and i couldn't be more proud to have "attention/tips/knowledge" from someone has qualified as you, Tig. Thanks again and best wishes for you and sketchucation.
          Luis Melo
