    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.4m Views 28 Watching
    • C
      Charlie__V
      @medeek said:
      Can you give me some examples for mulled units.
      Just grabbed a page from Andersen casement catalog.
      And an in plan image....although this unit is fixed glass.....
      • medeekM
        medeek
        For a triple casement window I am thinking a single frame with three sashes, does this seem reasonable?
        Also I was thinking about oval and round windows earlier today and they are really one in the same, the only difference being the aspect ratio (height/width). A round window is an oval window with an AR = 1.0:
        http://design.medeek.com/resources/images/wall_su163_800.jpg
        Hence the window height and width will drive the shape of the oval, really no different than a rectangular window.
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
          πŸ˜‰
          • C
            Charlie__V
            Yes, especially for presentation purposes.
            My current cad software allows for specifying an over all unit size and option to display a user specified number of segments.
            IE: 8’-0”x4’-0” .....Display = 3 segments......... (3) 2’-8”x4’-0”
            • medeekM
              medeek
              Oval / Round windows are certainly something new and a bit more challenging but now that I've got the algorithms worked out the rest is just a matter of generating the code.
              http://design.medeek.com/resources/images/wall_su164_800.jpg
              http://design.medeek.com/resources/images/wall_su165_800.jpg
              design.medeek.com
              • medeekM
                medeek
                http://design.medeek.com/resources/images/wall_su166_800.jpg
                A video showing the Medeek Wall with Woody (French):
                design.medeek.com
                • medeekM
                  medeek
                  Version 0.8.7 - 07.18.2018
                  • Added oval and round windows to the window draw and edit modules.
                  • Enabled trim, casing and window installation for oval and round windows.
                  http://design.medeek.com/resources/images/wall_su167_800.jpg
                  http://design.medeek.com/resources/images/wall_su168_800.jpg
                  I haven't enabled shutters or grilles yet for this window type, it is not high on my todo list unless I receive additional requests for these features.
                  The trim and casing options are also pretty much plain jane for now.
                  Let's see if I can't knock out the Garage Door module this evening.
                  I also thought it might be helpful to reiterate that if you are an educator (teacher, professor, school) or a student I am offering full licenses of all my plugins for educational use. All that I ask is you provide some form of student ID or other proof that you are associated with an educational institution. The educational licenses provided to educators also allow installation on up to 50 seats.
                  design.medeek.com
                  • medeekM
                    medeek
                    I have been primarily focused on the imperial/US units during the development but I also realize that a lot of current users are utilizing the plugin in metric units. I am not at all familiar with construction and construction documents in metric units so I need a little help here.
                    What I am talking about is the callouts for windows and doors. What is the appropriate way to show these callouts in metric units? What is common or accepted practice?
                    I'm looking at an Australian floor plan right now and the first thing that jumps out at me is they call out height x width whereas in the US we call out width x height, now I am curious what other countries that are using metric are doing, specifically the UK, Norway and France.
                    The Australian system seems to be the following: window sizes are rounded to the nearest decimeter and shown in meters: (ie. a 1090mm x 2230mm window is called out as a 1022. Doors on the other hand do not seem to be called out by height but only by their width in millimeters (ie. 820 for an 820mm wide door).
                    If the callout systems differ dramatically between countries I suppose I can add a global setting which allows the users to switch between various callout systems (for metric units).
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 0.8.7b - 07.19.2018
                      • Added a 5-Lite Circular Grille for all window types.
                      • Enabled all standard grille types for oval and round windows.
                      http://design.medeek.com/resources/images/wall_su170_800.jpg
                      View model here:
                      3D Warehouse
                      (3dwarehouse.sketchup.com)
                      This grille pattern was added per customer request, also note that it can be applied to any of the other rectangular window types (picture, single hung, slider).
                      Lately I've been having so many smaller feature requests that it has been hard to focus on some of the big ticket items. I am doing my best not to be side tracked by these minor items and to just add them to the todo list so I can attend to them at a later date.
                      The todo list is now over three pages long, so rather than shrink it has continued to grow. Honestly the amount of items I'm currently looking at is really the work of an entire team of programmers, not just a single person. So if my progress seems rather slow at times then it probably is.
                      I've been trying to get some of my kids (teenagers) interested in helping out with some of the coding over their summer break but they seemed to be more inclined to spend their time playing computer/console games. I call them the Angry Birds or Pokemon Go generation. All of this technology is great but unless it is harnessed correctly it seems more detrimental than good.
                      design.medeek.com
                      • medeekM
                        medeek
                        I was using a metric template last night to work on updates to the metric window and door call outs, when it became painfully obvious that the metric side of the house has way more bugs than I care to admit.
                        I am going to spend the rest of the day or whatever it takes to go through the entire extension with a fine tooth comb and clean up some of these (metric only) bugs. I'm finding that most of them are typos or something very simple, however I do need to get this done.
                        My sincere apologies to are international (metric) customers who have had to deal with this and I appreciate your patience with me.
                        design.medeek.com
                          Hope for your customers that you have several children! πŸ˜‰
                          In France an internal door is normally in cm (centimeter) or m (meter with 2 decimals) , thickness in mm (millimeter)
                          Example : 2.04 m * 0.63 m to 0.93 m ( 0.63 - 0.73 - 0.93) by section 29 mm to 40 mm
                          or
                          204 cm * 63 cm to 93 cm (63-73-93) by section 29 mm to 40 mm
                            Maybe you can put all in mm for less problem ?
                            so a standard internal door 2,04 m * 93 cm * 29 mm
                            will be 2040 mm * 930 mm * 29 mm
                            • medeekM
                              medeek
                              Version 0.8.7c - 07.20.2018
                              • Addressed a number of miscellaneous bugs related to metric templates.
                              I've also utilized the Australian standard for window and door call outs when using metric templates. If someone would like to have a different call out system implemented for metric units I can do that as well, I just need specifics and what country or name to associate with that call out system.
                              This is a critical bug fix release and addresses a number of bugs having to do with metric units but also affects some issues that are also with imperial/US units. I would highly recommend updating to this latest version at your earliest convenience.
                              Locating windows and doors along a wall in meters should now work as intended.
                              I'm am reasonably sure there are more bugs with the metric version of the plugin since I have not fully tested it in every possible scenario. If you notice anything please feel free to contact me.
                              design.medeek.com
                              • medeekM
                                medeek
                                One known issue with the latest upgrades applies to users who have previously installed the plugin. Once you upgrade to the latest version, click on the global settings and then the layers tab. This will reinitialize the layers settings for the plugin.
                                This only applies to users that are upgrading and that also have the layers option enabled in the global settings.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  I've introduced a start and end parameter for the wainscoting which allows for partial wainscoting on exterior walls:
                                  http://design.medeek.com/resources/images/wall_su171_800.jpg
                                  View model here:
                                  3D Warehouse
                                  This feature has been requested a number of times in that last month so it managed to float to the top.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 0.8.7d - 07.22.2018
                                    • Added a start and end parameter for exterior wainscoting, which allows for partial wainscoting of a wall panel.
                                    • All window grille types extended to half glass and full glass doors (single/double).
                                    http://design.medeek.com/resources/images/wall_su173_800.jpg
                                    Just an FYI, I am currently working on the garage door module however I've purposely forked the code so that I can keep putting out fires and attending to minor feature requests while I spend the next few days completing this much larger module.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Ext. Wainscoting is complicated. Currently all I have is Mode 1 in the logic:
                                      http://design.medeek.com/resources/wallplugin/WAINSCOTING_MODES_800.jpg
                                      For example in Mode 3 you may start with full height brick then drop down to a half height and then terminate all on one wall panel.
                                      With the start and end offsets set to zero the result for any of the different modes would be exactly the same, they really only come into play when you begin offsetting the wainscoting from the right and/or left.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Version 0.8.8 - 07.24.2018
                                        • Added an additional "mode" parameter for exterior wainscoting, which allows for multiple configurations of partial wainscoting.
                                        http://design.medeek.com/resources/images/wall_su174_800.jpg
                                        http://design.medeek.com/resources/images/wall_su175_800.jpg
                                        There are now four modes however there are other modes possible but I think I have spent enough time on this for now until further requests propel this to the top of the list again.
                                        View models here:
                                        3D Warehouse
                                        3D Warehouse
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 0.8.9 - 07.25.2018
                                          • Added the CMU framing mode for concrete block wall construction.
                                          http://design.medeek.com/resources/images/wall_su176_800.jpg
                                          http://design.medeek.com/resources/images/wall_su177_800.jpg
                                          Currently the CMU mode is mostly the same as the "No Framing" mode with a few subtle differences:
                                          1.) Concrete block texture is applied to vertical and horizontal faces of the wall solid to simulate a block wall.
                                          2.) Round openings in the wall are cut out to follow the curve of the window or door.
                                          3.) Description of the group (solid) has CMU in the text. This will be important in later releases as the estimating and engineering modules are developed and implemented.
                                          As I receive further input on this new wall type I'm sure additional features will need to be added to fully bring the CMU wall framing mode up to speed.
                                          View model here:
                                          3D Warehouse
                                          design.medeek.com
                                          • pbacotP
                                            The CMU module should be interesting as there are whole new set of standards and details. Looks good! Rarely get the chance to work with this.
