    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.0m Views 28 Watching
    • medeekM
      medeek
      Board and Batten Shutters:
      http://design.medeek.com/resources/images/wall_su156_800.jpg
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Arched window with flat panel shutters:
        http://design.medeek.com/resources/images/wall_su157_800.jpg
        These arched shutters are proving to be a bit more challenging. I will need to figure out a new algorithm for board and batten shutters and louver shutters.
        design.medeek.com
        • pbacotP
          No kidding. I can't even imagine!
          • medeekM
            medeek
            I think I've finally been bested by the complicated geometry and the limitations of SketchUp or perhaps my ability to model within SketchUp.
            Notice the raised panel shutters for an arched windows shown below:
            http://design.medeek.com/resources/images/wall_su158_800.jpg
            To create the raised panel effect I will draw the three outlines and then use the transform_entities method to move the edges into the plane. The problem is when I try this with a curved outline(s) as shown SketchUp does not know how to handle the curved planes/surfaces being created.
            design.medeek.com
            • medeekM
              medeek
              I guess I haven't been defeated after all. Using the follow-me method I was able to get it to work:
              http://design.medeek.com/resources/images/wall_su159_800.jpg
              I now have all the shutter types working for arched windows:
              http://design.medeek.com/resources/images/wall_su160_800.jpg
              View model here:
              3D Warehouse
              (3dwarehouse.sketchup.com)
              design.medeek.com
              • jujuJ
                juju
                  These are in your plans ?
                  https://encrypted-tbn0.gstatic.com/images?q=tbn;ANd9GcQV3o09rtmR7I5uwrD5SuXRSM0-vWZlKHcZaZCWE871s4zQFOuc
                  http://idata.over-blog.com/2/90/86/68/P1010937--800x600-.jpg
                  • medeekM
                    medeek
                    I have been contemplating them, but haven't put anything in the code as of yet.
                    design.medeek.com
                    • medeekM
                      medeek
                      I"m not sure why you would want to put a single shutter to one side of a window but here it is just in case you need it:
                      http://design.medeek.com/resources/images/wall_su161_800.jpg
                      I will have to wait until tomorrow to roll out all of the shutter updates its now 4:00AM and I'm done for now.
                      I think I've now beat this horse to death, shutters are available for rectangle and arched windows in all styles and geometry (Left, Right, Double).
                      After I add more window types I will probably need to revisit the shutter module but I don't think shutters are very common for more exotic window shapes (ie. ovals, triangles, trapezoids etc...)
                      design.medeek.com
                      • medeekM
                        medeek
                        Left, Right and Double:
                        http://design.medeek.com/resources/images/wall_su162_800.jpg
                        View model here:
                        3D Warehouse
                        I've also addressed a bug with arched geometry where the push-pull direction was giving unpredictable results (flipping flopping between in and out). Turns out that you need to clock your segments all in the same direction to get predictable results, which makes sense. For some reason this did not occur to me as I was coding some of these sections of the main window module.
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 0.8.6b - 07.16.2018
                          • Added shutters: Solid, Flat Panel, Raised Panel, Louver, Board & Batten to arched windows.
                          • Shutter geometry parameter allows for: Left, Right or Double.
                          • Fixed bug in arched window module that was causing unpredictable push-pull behavior.
                          design.medeek.com
                          • medeekM
                            medeek
                            Now that I'm on a window/shutter kick I'm wondering if I should jump back into the window module and enable round and oval windows. I will probably forego the shutters on these types of windows for now and just concentrate on the basics like the window itself and the trim and casing.
                            The grilles for these type of windows (round and ovals) can get quite elaborate and could easily soak up an entire week of my time just trying to put together some of the more common variants.
                            design.medeek.com
                            • C
                              Charlie__V
                              If you must.....but I would love to see an option for at least multiple DH or Casements (mulled units) implemented before round or oval since they are typically specialty/limited application.
                              My 2 pennies worth
                              Charlie
                              • medeekM
                                medeek
                                Can you give me some examples for mulled units.
                                design.medeek.com
                                • C
                                  Charlie__V
                                  Just grabbed a page from Andersen casement catalog.
                                  And an in plan image....although this unit is fixed glass.....
                                  • medeekM
                                    medeek
                                    For a triple casement window I am thinking a single frame with three sashes, does this seem reasonable?
                                    Also I was thinking about oval and round windows earlier today and they are really one in the same, the only difference being the aspect ratio (height/width). A round window is an oval window with an AR = 1.0:
                                    http://design.medeek.com/resources/images/wall_su163_800.jpg
                                    Hence the window height and width will drive the shape of the oval, really no different than a rectangular window.
                                    design.medeek.com
                                      πŸ˜‰
                                      • C
                                        Charlie__V
                                        Yes, especially for presentation purposes.
                                        My current cad software allows for specifying an over all unit size and option to display a user specified number of segments.
                                        IE: 8’-0”x4’-0” .....Display = 3 segments......... (3) 2’-8”x4’-0”
                                        • medeekM
                                          medeek
                                          Oval / Round windows are certainly something new and a bit more challenging but now that I've got the algorithms worked out the rest is just a matter of generating the code.
                                          http://design.medeek.com/resources/images/wall_su164_800.jpg
                                          http://design.medeek.com/resources/images/wall_su165_800.jpg
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            http://design.medeek.com/resources/images/wall_su166_800.jpg
                                            A video showing the Medeek Wall with Woody (French):
                                            design.medeek.com
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 80
                                            • 81
                                            • 21 / 81
