    Medeek Wall Plugin
    1.5k Posts 27 Posters 1.1m Views 26 Watching
    • medeekM Offline
      medeek
      @charlie__v said:
      PS
      When using polyline it seems the draw wall tool is self aware enough it doesn't require the need to pre-select "start" and "end" type........so maybe that is not necessary on initial "draw window" either
      You are correct. When the auto-corner configuration global setting is enabled the plugin will correctly sense the corner angles and configurations and take care of that automatically. If this global setting is enabled I should probably just gray out the appropriate parameters (at least in the draw tool GUI). One can always edit a wall and manually change these value which will override the auto behaviour.
      I like how you term it "self aware", I'm a huge fan of AI and a bit of an AI programmer myself but I wouldn't go quite so far as to call this AI or even self aware. Just a fairly complicated algorithm that tries to check for specific wall corner and tee intersections. As time goes on the algorithm will probably be revisited a few more times making it more robust and flexible, but it has no capacity to learn (ie. memory). Just a static set of instructions which it follows without variation.
      However, with that being said I have considered using some sort of adaptive behavior for the plugin that would slowly adapt to the users most commonly used values for certain parameters and try to predict what those values should be in the future. A good example of this would be header selection for interior walls. Over time it would begin to rank which header sizes/types are used the most and then within the drop down menus it could sort them so that the most commonly used sizes appear at the top of the list with the most commonly used one being selected as default.
      Again I don't know if I would call this AI but it would certainly be adaptive software and would tailor itself to the users habits.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • Bob JamesB Offline
        Bob James
        Where are the updated versions located for downloading?
        Do just go to http://design.medeek.com/resources/medeekwallplugin.html and download the Trial?
        • medeekM Offline
          medeek
          Login to the Account Manager and the download link will appear under the license listing.
          Medeek Design Inc. - Login
          (design.medeek.com)
          design.medeek.com
            Bob James
            Toolbar icons do not scale for 4K monitor.
              Bob James
              (design.medeek.com)
              Thank you!
              • medeekM Offline
                medeek
                [attachment=0:2u1yiq42]<!-- ia0 -->MedeekIcons-1.png<!-- ia0 -->[/attachment:2u1yiq42]
                Does anyone know how to address that?
                Here is my typical toolbar/icon ruby:
                cmd7.small_icon = "images/mdkplg_tool_icon16_8.png"
                cmd7.large_icon = "images/mdkplg_tool_icon24_8.png"
                cmd7.tooltip = "Medeek Wall"
                cmd7.status_bar_text = @Trs['Change Global Settings']
                cmd7.menu_text = @Trs['Global Settings']
                toolbar = toolbar.add_item cmd7
                toolbar.show
                Do I need an extra large icon?
                design.medeek.com
                  Bob James
                  The icons have to be .svg format. This is a scalable vector format that is the new SU standard.
                  • medeekM Offline
                    medeek
                    There are really three functions in one here: Loading, Saving and Deleting.
                    Quite a bit of new code to implement the new presets system. I'm still testing it out to make sure it is solid, but so far it is looking pretty good.
                    Note, that it is possible to give a preset the exact same name as another preset, this is by design and they will both appear in the drop down list. What you are not seeing in the drop down is the hidden number assigned to each preset which is stored in the presets file. This number is really the identifier of the preset and allows one to correctly specify which preset you are wanting to load or delete.
                    Once this system is in place for the walls and fully tested and verified I will implement a similar system for windows and doors.
                    I have a number of minor fixes and bugs that are quite hot items right now that have been delayed due to my attention to this latest upgrade, I apologize for the delay in getting the fixes out, but I really feel that this UI upgrade is top priority right now.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      I've messed around with a few PNG to SVG converters and the result are not spectacular. I've actually used SVG quite extensively in some of the menus for the Truss Plugin so I have a pretty good understanding of how SVG works. Unfortunately, SVG does not lend itself well to shaded or rendered images or to gradients. Line drawings is where it excels, I'll have to give this some more thought.
                      If I can somehow detect that the user is running a 4K monitor or some other high resolution monitor that the current icons are not well suited to then I could substitute the regular icon set with a lesser quality SVG set.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        I released the LT version of the plugin a couple days ago and I am surprised that no one has shown any interest in this lesser version of the plugin.
                        Just to clarify, it is a full featured version of the plugin without the internal wall framing, estimating and engineering components. The ability to creating openings, windows, doors, exterior and interior cladding etc... is all there.
                        The intended audience of the LT version is architects and designers who do not need all of the nut and bolts of the design (how it goes together) and are concentrating more on the big picture.
                        Please let me know what would make the LT version more attractive to you the designer or architect.
                        design.medeek.com
                          Charlie__V
                          @medeek said:
                          @charlie__v said:
                          PS
                          To sort of state the obvious, the “smarter” the draw wall feature gets, the better the plug-in will be. (little to no post draw edits req’d)
                          In version (0.7.7d) I notice the draw wall ....Justification: Front seems to be the most mature/predictable and less so for Center and Back.......I assume the Center and Back will catch up at some point?
                          Thanks,
                          Charlie
                          • medeekM Offline
                            medeek
                            Thanks,
                            Charlie
                            Correct, the FRONT justification is really the only option that is working as it should right now, do not use the other two options. I am still sorting out the details on those other two, and yes, they will work in future releases.
                            design.medeek.com
                              Bob James
                              I'm surprised too. I'd buy it in a heartbeat because of its usefulness, but I've already spent $100 on the full version. 😎
                              I would think that the lite version would outsell the full version by a wide margin since I'd suppose there are a lot more people needing a way to just draw houses than those needing a full design package.
                                Bob James
                                I don't know if it would be of any use to you, but here's a thread about icons on 4K monitors:
                                http://sketchucation.com/forums/viewtopic.php?f=15&t=69030
                                • medeekM Offline
                                  medeek
                                  The SVG icons have been added to the todo list, right now they are way down on the bottom of the list but as time goes on I will give them some attention.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Unfortunately, I was up in Seattle for most of day for some testing so I was not able to get any real programming done but I've been reading emails via my cellphone and some interesting ideas have surfaced:
                                    1.) When the wall edit menu is open being able to click a different wall and then this wall is loaded up in the already open edit menu window, instead of having to open a new window to edit the wall.
                                    2.) Use the CTRL key to toggle window and door placement (ie. Left, Middle, Right)
                                    3.) Similar to presets for walls also provide presets for windows and doors.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Your typical entries in the wall presets file:
                                      Medeek Wall Preset File
                                      1|2x4 Exterior Wall|20180613235029|Int-Ext|Front|97.125|80.0|5.5|1.5|16.0|Left|2|1.5|1|1.5|NO|YES|End|90.0|1.5|1|California|5.5|Inset Outside Corner|90.0|1.5|1|California|5.5|YES|0.4375|FLUSH|YES|0.25|0.0|MITER|YES|0.5|YES|NO|0.0|0.0|0.0|0.0|OSB|HARDI_CM_HM|#f9f9fe|PFG|YES|YES|DTT2Z|0.0|NONE|0.0|BOTH|FRAMING|Center|YES|ON SHEATHING|0.75|YES|3.5|YES|2.5|#ffffff
                                      2|2x4 Interior Wall|20180613220050|Int-Int|Front|97.125|80.0|5.5|1.5|16.0|Left|2|1.5|1|1.5|NO|YES|End|90.0|1.5|1|California|5.5|Inset Outside Corner|90.0|1.5|1|California|5.5|YES|0.4375|FLUSH|YES|0.25|0.0|MITER|YES|0.5|YES|NO|0.0|0.0|0.0|0.0|OSB|HARDI_CM_HM|#f9f9fe|PFG|YES|YES|DTT2Z|0.0|NONE|0.0|BOTH|FRAMING|Center|YES|ON SHEATHING|0.75|YES|3.5|YES|2.5|#ffffff
                                      3|2x4 Interior Wall w/ Insul|20180614000047|Int-Ext|Front|97.125|80.0|5.5|1.5|16.0|Left|2|1.5|1|1.5|NO|YES|End|90.0|1.5|1|California|5.5|Inset Outside Corner|90.0|1.5|1|California|5.5|YES|0.4375|FLUSH|YES|0.25|0.0|MITER|YES|0.5|YES|NO|0.0|0.0|0.0|0.0|OSB|HARDI_CM_HM|#f9f9fe|PFG|YES|YES|DTT2Z|0.0|NONE|0.0|BOTH|FRAMING|Center|YES|ON SHEATHING|0.75|YES|3.5|YES|2.5|#ffffff
                                      Notice the time stamp field, I may also add in a notes field later on that can be viewed and edited with the global settings.
                                      The delete and save functions are now solid, I am currently testing the load function and then I need to implement the html menu for the Draw Wall Tool and we are then ready to put this update out there.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 0.7.8 - 06.14.2018
                                        • Added the ability to create, load and delete wall presets within the Edit Wall (HTML) Menu.
                                        • Fixed a bug within the auto-corner configuration module which caused issues for walls less than 36" in height.
                                        • The wall length in the Edit Wall Menu updated to ft-in from decimal feet (imperial templates), also fixed a bug in the wall length for metric templates.
                                        Note that wall presets can only be currently loaded and applied after the fact (within the Wall Edit Menu). My intent is to also make this feature available within the reworked Draw Tool within the next few days but I first want to introduce this feature within the Edit Menu and work out any potential pitfalls before rolling it out further.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Just a reminder that tomorrow is the last day of the June promotion: Purchase the Wall Plugin and receive free licenses or license upgrades for both Truss and Foundation Plugin.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            A selection of wall columns possible with the new Column Tool:
                                            http://design.medeek.com/resources/images/wall_su103_800.jpg
                                            I just need to add in the edit, move and delete tools to complete the Column Module, then I will release it.
                                            design.medeek.com
                                            • 74
                                            • 75
                                            • 3 / 75
