    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.4m Views 28 Watching
    • C
      Charlie__V
      @medeek said:
      @charlie__v said:
      PS
      When using polyline it seems the draw wall tool is self aware enough it doesn't require the need to pre-select "start" and "end" type........so maybe that is not necessary on initial "draw window" either
      You are correct. When the auto-corner configuration global setting is enabled the plugin will correctly sense the corner angles and configurations and take care of that automatically. If this global setting is enabled I should probably just gray out the appropriate parameters (at least in the draw tool GUI). One can always edit a wall and manually change these value which will override the auto behaviour.
      I like how you term it "self aware", I'm a huge fan of AI and a bit of an AI programmer myself but I wouldn't go quite so far as to call this AI or even self aware. Just a fairly complicated algorithm that tries to check for specific wall corner and tee intersections. As time goes on the algorithm will probably be revisited a few more times making it more robust and flexible, but it has no capacity to learn (ie. memory). Just a static set of instructions which it follows without variation.
      To sort of state the obvious, the “smarter” the draw wall feature gets, the better the plug-in will be. (little to no post draw edits req’d)
      In version (0.7.7d) I notice the draw wall ....Justification: Front seems to be the most mature/predictable and less so for Center and Back.......I assume the Center and Back will catch up at some point?
      Thanks,
      Charlie
      • medeekM
        medeek
        Thanks,
        Charlie
        Correct, the FRONT justification is really the only option that is working as it should right now, do not use the other two options. I am still sorting out the details on those other two, and yes, they will work in future releases.
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • Bob JamesB
          Bob James
          released the LT version of the plugin a couple days ago and I am surprised that no one has shown any interest in this lesser version of the plugin.
          I'm surprised too. I'd buy it in a heartbeat because of its usefulness, but I've already spent $100 on the full version. 😎
          I would think that the lite version would outsell the full version by a wide margin since I'd suppose there are a lot more people needing a way to just draw houses than those needing a full design package.
          • Bob JamesB
            Bob James
            I don't know if it would be of any use to you, but here's a thread about icons on 4K monitors:
            404 Not Found
            (sketchucation.com)
            • medeekM
              medeek
              The SVG icons have been added to the todo list, right now they are way down on the bottom of the list but as time goes on I will give them some attention.
              design.medeek.com
              • medeekM
                medeek
                Unfortunately, I was up in Seattle for most of day for some testing so I was not able to get any real programming done but I've been reading emails via my cellphone and some interesting ideas have surfaced:
                1.) When the wall edit menu is open being able to click a different wall and then this wall is loaded up in the already open edit menu window, instead of having to open a new window to edit the wall.
                2.) Use the CTRL key to toggle window and door placement (ie. Left, Middle, Right)
                3.) Similar to presets for walls also provide presets for windows and doors.
                design.medeek.com
                • medeekM
                  medeek
                  Your typical entries in the wall presets file:
                  Medeek Wall Preset File
                  1|2x4 Exterior Wall|20180613235029|Int-Ext|Front|97.125|80.0|5.5|1.5|16.0|Left|2|1.5|1|1.5|NO|YES|End|90.0|1.5|1|California|5.5|Inset Outside Corner|90.0|1.5|1|California|5.5|YES|0.4375|FLUSH|YES|0.25|0.0|MITER|YES|0.5|YES|NO|0.0|0.0|0.0|0.0|OSB|HARDI_CM_HM|#f9f9fe|PFG|YES|YES|DTT2Z|0.0|NONE|0.0|BOTH|FRAMING|Center|YES|ON SHEATHING|0.75|YES|3.5|YES|2.5|#ffffff
                  2|2x4 Interior Wall|20180613220050|Int-Int|Front|97.125|80.0|5.5|1.5|16.0|Left|2|1.5|1|1.5|NO|YES|End|90.0|1.5|1|California|5.5|Inset Outside Corner|90.0|1.5|1|California|5.5|YES|0.4375|FLUSH|YES|0.25|0.0|MITER|YES|0.5|YES|NO|0.0|0.0|0.0|0.0|OSB|HARDI_CM_HM|#f9f9fe|PFG|YES|YES|DTT2Z|0.0|NONE|0.0|BOTH|FRAMING|Center|YES|ON SHEATHING|0.75|YES|3.5|YES|2.5|#ffffff
                  3|2x4 Interior Wall w/ Insul|20180614000047|Int-Ext|Front|97.125|80.0|5.5|1.5|16.0|Left|2|1.5|1|1.5|NO|YES|End|90.0|1.5|1|California|5.5|Inset Outside Corner|90.0|1.5|1|California|5.5|YES|0.4375|FLUSH|YES|0.25|0.0|MITER|YES|0.5|YES|NO|0.0|0.0|0.0|0.0|OSB|HARDI_CM_HM|#f9f9fe|PFG|YES|YES|DTT2Z|0.0|NONE|0.0|BOTH|FRAMING|Center|YES|ON SHEATHING|0.75|YES|3.5|YES|2.5|#ffffff
                  Notice the time stamp field, I may also add in a notes field later on that can be viewed and edited with the global settings.
                  The delete and save functions are now solid, I am currently testing the load function and then I need to implement the html menu for the Draw Wall Tool and we are then ready to put this update out there.
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 0.7.8 - 06.14.2018
                    • Added the ability to create, load and delete wall presets within the Edit Wall (HTML) Menu.
                    • Fixed a bug within the auto-corner configuration module which caused issues for walls less than 36" in height.
                    • The wall length in the Edit Wall Menu updated to ft-in from decimal feet (imperial templates), also fixed a bug in the wall length for metric templates.
                    Note that wall presets can only be currently loaded and applied after the fact (within the Wall Edit Menu). My intent is to also make this feature available within the reworked Draw Tool within the next few days but I first want to introduce this feature within the Edit Menu and work out any potential pitfalls before rolling it out further.
                    design.medeek.com
                    • medeekM
                      medeek
                      Just a reminder that tomorrow is the last day of the June promotion: Purchase the Wall Plugin and receive free licenses or license upgrades for both Truss and Foundation Plugin.
                      design.medeek.com
                      • medeekM
                        medeek
                        A selection of wall columns possible with the new Column Tool:
                        http://design.medeek.com/resources/images/wall_su103_800.jpg
                        I just need to add in the edit, move and delete tools to complete the Column Module, then I will release it.
                        design.medeek.com
                        • medeekM
                          medeek
                          Even in fully conventionally framed houses this type of "in wall column" situation is not uncommon. Sometimes the beam will run inside the floor and no beam pocket is required in the wall below, other times the beam will run below the floor or roof joists and in such cases a beam pocket is fairly standard practice.
                          The column tool will allow for a number of configurations including PSL columns (standard sizes). The designer can also specify independently the number of king studs (0,1, or 2) next to a column and their thickness.
                          The column can project above or below the wall, with the plates being cut out as needed. If the column height is specified as "FULL" then no cut out of the top plates is done and the column runs up to the bottom of the top plates just like the other studs.
                          If certain sizes of lumber are specified (ie. 4x2, 6x2, 6x4) then the plugin recognizes that these are "on the flat" and will multi-lam them as so when more than one ply is specified. So one can create multi-lam columns (ie. (3) 2x6) oriented parallel or perpendicular to the wall.
                          Similar to windows and doors the Column Edit Menu will allow you to edit any parameter of the column so that it is completely parametric.
                          design.medeek.com
                          • medeekM
                            medeek
                            Here is an example of a glulam beam resting in two beam pockets and supported by two 6x6 wall columns:
                            http://design.medeek.com/resources/images/wall_su104_800.jpg
                            design.medeek.com
                            • medeekM
                              medeek
                              With the column annotation option enabled:
                              http://design.medeek.com/resources/images/wall_su105_800.jpg
                              I've added another option into the global settings which will allow the user to toggle off the column annotations independently of the window and door annotations.
                              All of the parameters in the Draw Column tool also have default values that are being pulled from the global configs, I will eventually add these into the global settings so they can be customized I just haven't figure out where I should put them. The global settings is starting to get rather populated with tabs and parameters, I actually need to create a second row of tabs along the top, I will give this some more thought.
                              design.medeek.com
                              • pbacotP
                                Looking Good!
                                • medeekM
                                  medeek
                                  Version 0.7.9 - 06.18.2018
                                  • Added the ability to draw, move and delete wall columns with the Beams/Column Toolset.
                                  • Added a parameter in the global settings (General tab) in order to toggle beam and column annotations independent of window/door annotations.
                                  • Column annotations and representative geometry added to the 2D and 3D (no framing) modes.
                                  The three images below show the exact same wall (with columns) rendered in the three framing modes:
                                  http://design.medeek.com/resources/images/wall_su106_800.jpg
                                  http://design.medeek.com/resources/images/wall_su107_800.jpg
                                  http://design.medeek.com/resources/images/wall_su108_800.jpg
                                  Note that I've turned off additional layers for clarity (ie. insulation, cladding, sheathing, trim, gypsum)
                                  View model here:
                                  3D Warehouse
                                  (3dwarehouse.sketchup.com)
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Now that I've got a couple larger items out the door, so to speak I'm able to clear my head and think about some other items that have been percolating for a few days.
                                    One of those items (technically it is not on my todo list) it how to preserve and maintain custom edits or geometry to a wall panel while still allowing for the full parametric ability of the plugin. In all honesty I probably have not given this enough thought but the subject has come up multiple times in the last few weeks with a number of designers so I think it is important enough to fully consider.
                                    As far as respecting manual edits to the geometry that the plugin creates I still do not see a rational way of doing this however if a user were to insert some additional geometry into the wall panel main group I think there may be an easy way to place this geometry into a sub-group(s) within the main group and then name that sub-group in such as fashion so that the plugin knows to maintain that sub-group and hence it will persist even with multiple edits or other operations to a wall panel group.
                                    Would such a feature be useful to you the designer?
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Version 0.7.9b - 06.18.2018
                                      • Sub-groups within wall panels can be made persistent by naming these groups or component instances to (custom1, custom2, custom3, etc...), also all other user defined geometry (ie. faces, text, lines and dimensions) are also retained when the wall panel is regenerated by the plugin.
                                      The naming of these persistent groups does not need to be in any order or even follow any particular naming convention, the key thing is that the instance name contains the word "custom" in it. The name is also not case sensitive.
                                      All other geometry and annotations do not require anything special to be retained, only groups and components.
                                      I've tested this out a bit this afternoon but it is quite new so I'm hoping everyone can work it over and see if they can break it or at least find any flaws in it.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Does anyone have a preference on what 2D symbol you would like to use to represent Simpson Strong-Walls.
                                        There are two types: Wood and Steel
                                        I can represent each type with a different symbol or use the same symbol for both.
                                        Catalog for both types is here for those interested:
                                        Strong-Wall Shearwalls Catalog
                                        Download our Strong-Wall® Shearwalls catalog that includes product data, engineering design information, and installation and anchorage details.
                                        (www.strongtie.com)
                                        I can also include other pre-fab shearwall panels from other manufacturers if requested, I'm only familiar with Simpson's products.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 0.8.0 - 06.21.2018
                                          • Added the ability to draw, move and delete pre-fab shear wall panels with the SSW Toolset.
                                          • Added a parameter in the global settings (General tab) in order to toggle SSW annotations independent of window, door and column annotations.
                                          • SSW annotations and representative geometry added to the 2D and 3D (no framing) modes.
                                          http://design.medeek.com/resources/images/wall_su109_800.jpg
                                          http://design.medeek.com/resources/images/wall_su110_800.jpg
                                          View model here:
                                          3D Warehouse
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            The first thing you may notice with the SSW tool is that the current selection of sizes (widths and heights) of the pre-fab shearwalls is limited to 24" wide and between 8' and 12' in height. I also do not have any metric sizes or manufacturers other than these two (Hardy Frame HFX (Mitek) and Simpson Strong-Tie).
                                            I will roll out the full line of both manufacturers lines in the next few days however I have a few more smaller but hotter items that I would like to address first.
                                            The first item is to allow the user the ability to toggle the placement of windows/doors/columns/SSWs from their center to left or right. I'm considering using the SHIFT key to make this toggle unless there are any specific objections.
                                            Once I have this feature up and running I would like to make a tutorial video for both columns and SSW's since both of these items are fairly mature as they currently stand and a video would go along way in explaining some of the the parameters for each of these items.
                                            For the WSW (wood) series of Simpson Strong-Walls I have the trim feature now enabled and it seems fairly robust. This particular trim module is now primed for shed and gable wall situations where a WSW panel might be trimmed at some arbitrary incline rather than 90 degrees.
                                            The next major item is the external wainscoting or dual cladding configuration for exterior walls. Now that I have a firm handle on a decent trim method I will employ this same technique in dealing with ext. wainscoting which will alleviate the need for a complex algorithm in dealing with openings bisected by a change in cladding or sheathing. I should be able to wrap this one up in the next 24 hours.
                                            design.medeek.com
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 80
                                            • 81
                                            • 15 / 81
