    šŸ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    [Plugin] GKWare Cabinet Maker
    627 Posts 69 Posters 458.4k Views 70 Watching
    • N Offline
      NBG
      Hello,
      I don't find any "how to update" on your site or here.
      In the extension manager the "update" button is greyed.
      I I click on "install extension" and select the file I downloaded on your site nothing happen. MAybe I have ton uninstall the former version first?
      I guess i'm missing something...
        Garry K
        Martin,
        Email me directly and we'll figure out your problem.
        Problem was solved fairly quickly.
        Garry
        • mpoole32M Offline
          mpoole32
          As I was processing a job this morning using CabMaker and Cutmaster I couldn’t help but think about how I was using one of the best kept secret tools available to cabinetmakers. Garry has been adding features at a pace I’ve never witnessed in my 30 years of using software in my cabinet making business. What he has developed over the past few years is way too powerful of a tool to be kept secret.
          In this order I’m working on today I’ve got a kitchen with a cherry island and hutch in a kitchen where all of the other units are painted. All boxes cut out of prefinished maple plywood. Having to break this job up into two batches so that the edgebanding color is handled properly by the banding operator causes yield issues.
          Creating optimized patterns and g-code for this job as single batch while handling different banding colors through notes and other manual methods for making sure the banding color per cabinet is accurate requires extra time and is error prone.
          With CabMaker and Cutmaster it is easy to route the cabinet number on each part and then provide banding instructions per each part including using different symbols to denote different banding colors.
          In this example you can see how the arc facing the front edge of this side panel tells the operator to band that edge with matching cherry pvc while the straight line aligned with the top edger tells the banding operator to band that edge with another color.
          This is just one example of power Garry is providing with his CabMaker plugin and CutMaster program.2018-05-07 08_35_14-Sonnenberg.skp - SketchUp Pro 2018.png
            Garry K
            Version 3.0.120 – May 7, 2018
            1. Added 2 parameters in Edit Config for dimensioning. Users can now choose Number
              or Model for dimensioning. Users can now set the dimensioning offset.
            2. Modified dimensioning so information is now on 2 lines.
            3. Added Side by Side Pullouts.
            4. Modified Shaker Doors. You can now set panel thickness in Materials to 0 and
              cabmaker will omit the center panel.
            5. Fixed glass panels in doors. You can again set drawer and door panels to glass or
              mirror.
            6. You can now specify Top Rail Width and Bottom Rail Width independently from Stile
              Width.
              Version 3.0.119 – Apr 29, 2018
            7. Modified cabinet insertion points. Face frame construction insertion for front of cabinet
              uses the edge of the face frame and insertion for back of the cabinet now adds a
              construction point.
            8. CabMaker now allows Fixed Shelves and or Adjustable Shelves without room for
              doors.
              Version 3.0.118 – Apr 24, 2018
            9. Added cabinet labeling for plan view and for front elevation view. Uses number field
            10. Added 2 parameters in Edit Config for label height and label font.
            11. Added a parameter in PROJECT tab for label color.
              Version 3.0.117 – Apr 21, 2018
            12. Tall cabinet Mid Doors now use the handle height for horizontal handles placed at the
              bottom.
            13. Fixed Door Profiles - it now uses the alternate location
            14. PROJECT tab settings are now saving when you batch edit
            15. Fixed the bug splat if you tried to undo an edit.
            16. CabMaker now uses groups or components for cabinet. It uses groups when you
              create a new cabinet - but will use components for editing if you change the group to a
              component.
            17. Door parts weren't getting the correct material name in CutMaster. Fixed
              Version 3.0.116 – Apr 19, 2018
            18. Fixed bug where shelves would show up in Cutmaster with quantity of 1.
              Garry K
              Here is the new Cabinet Labeling. You can turn it off in Edit Config by setting the label height to 0. You can also turn it off in the model using layers.
              This also shows a shaker door where you can set the rail heights independently.
                Garry K
                Here I've set the panel thickness to 0 and CabMaker omits the panel.
                I turned on side by side pullouts. I've set the partition height to 75 mm. You could have multiple pullouts if you wanted.
                Also I've set the left pullout depth to 0 (means cabmaker will figure out the deepest pullout that will fit. I've set the right pullout depth to 300. This can help for a sink where there is plumbing on one side of the sink cabinet.
                • N Offline
                  NBG
                  HEllo Garry,
                  I was trying to quickly draw several alternative of door templates for a client, and I figured out that my usual way of doing it (copy the whole 3D, make some component unique, modify) won't work with cabinet made with your plugin.
                  How would be the right way to do this?
                  In this case I'd like to male 3 versions of the same set of cabinet, with different doors template (embossed square with mid rail in the middle, or on another height for example).
                  thanks in advance,
                    Garry K
                    One way to make cabinets unique is to:
                    1. Copy and paste the set of cabinets for Version 2
                    2. Paste a second time for Version 3
                    3. Select all the cabinets and perform a batch edit. This will break the connection between all the cabinets.
                    You can then make door changes to individual cabinets.
                    I usually save the skp with a different name and then change the doors at the PROJECT level within a batch edit. This is very quick and means you don't have to edit each cabinet separately. Of course you would end up with 3 separate models.
                      Garry K
                      CabMaker 3.0.123 and CutMaster 3.0.1.73 are now available on my website.
                      Added scene automation. Start by setting your perspective and choose from Standard Scenes "Perspective / Plan"
                      Then I selected cabinets 1 through 8 and then I chose from Standard Scenes the appropriate View. In this case it is the "Front Elevation". I set Cabinets to Yes and this creates 2 images per cabinet - one with doors and one without.
                      Run the report and CutMaster imports the data. Then click on Assembly reports.
                        Garry K
                          Garry K
                          CabMaker 3.0.126 and CutMaster 3.0.1.76 are now available for download.
                          Now locking cabinets after a merge.
                          Cleaned up the workflow for automated scenes.
                          Slab doors have their own edging.
                          Added user control for CutMaster CNC labels.
                          Here are blue doors and yellow edging. The edge profile takes on the edging color. In this case the doors have a 3 mm radius.
                          You can achieve different effects with the embossed doors.
                            Garry K
                            I am now adding additional support for textures.
                            1. You will be able to add png or jpg files for textures.
                            2. In the Color.txt file you will now be able to add optional opacity for materials.
                            3. In the Color.txt file you will now be able to add your own color names providing you supply either RGB values or Hex value for the actual color.
                            4. You can now specify your own textures for glass, mirror, closet rods and raw edges.
                            5. I'm providing 2 textures for plywood edging for 3/4" (18 to 19 mm) panels.
                            I am now providing an Ikea.txt file that contains 200 IKEA colors along with RGB vales.
                            Here are the first 10 IKEA colors
                            IKEA 001=250,241,231
                            IKEA 002=240,232,225
                            IKEA 003=250,242,236
                            IKEA 004=248,242,235
                            IKEA 005=237,232,224
                            IKEA 006=239,231,221
                            IKEA 007=245,240,229
                            IKEA 008=241,228,211
                            IKEA 009=249,243,233
                            IKEA 010=244,236,222
                            Here is an example of named colors with and without opacity:
                            my_color_1=255,0,16=0.4
                            glass=0.3
                            my_color_2=#FF000F
                            my_color_3=#DD000F=0.2
                            • N Offline
                              NBG
                              Hello,
                              IS there a way to choose between horizontal or vertical texture for wood texture? That would be nice.
                              br,
                                Garry K
                                What some users have done is create their own horizontal texture.
                                • N Offline
                                  NBG
                                  [quote="Garry K"]One way to make cabinets unique is to:
                                  /quote]
                                  HEllo,
                                  I tried this for the second time since a asked the question but i cannot make it happen.
                                  In the 2 different projects I tried, the behavior is the same. When I copy the cabinets and try to bbatch edit the new ones, nothing happen to them... but the first ones moves a little bit!
                                  In the first project I had 6 tall cabinet and some of them were moving sideways for 60cm or more. In this project one of the cabinet move along the green axis (it goes behind , just on cabinet depth).
                                  I tried to change materials set, door type, handle type, sizes, it's always the same behavior. No changes happen. There is just those move of the cabinet I'm not editing.
                                  br,
                                    Garry K
                                    Please email me directly and we can set up a time to Skype and solve your problem.
                                      Garry K
                                      Cabmaker 3.0.130 is now available for download. CutMaster 3.0.1.78 is also available.
                                      You can now extend an overlay top and adjust the top gap.
                                      CutMaster now has additional drilling and grooving operations to facilitate drawer systems.
                                        Garry K
                                        CabMaker 3.0.131 and CutMaster 3.0.1.79 now available from my website.
                                        CabMaker
                                        1. Added Mitered Corners for Standard Cabinets.
                                        2. Added switch in Report Configuration so CabMaker parts report will produce 1 line per part instead of combining all like parts.
                                        CutMaster
                                        1. Added Reference from Drawer Box for configuring Drawer Fronts Hole Sets and Pilot holes.
                                        2. Fixed bug where spaces in Purpose breaks the configuration.
                                          Garry K
                                          CabMaker 3.0.132 and CutMaster 3.0.1.80 are now available from my website.
                                          1. Added Hinge positions for Tall, Mid and Standard doors. You can now have up to 5 hinges on a door. Please note that this information is sent over to CutMaster CNC for machining of the side panels and 1 piece doors.
                                          These CabMaker GIF's (from context help) give examples of what can be accomplished with hinge positions. The GIF's have a 2 second delay between frames.
                                          Box 1
                                          Box 2
                                          Box 3
                                          Box 4
                                          Box 5
                                          • N Offline
                                            NBG
                                            Hello,
                                            Am I blind, or there is no way to force handle height for the lower part of a tall cabinet? So not the mid section, not the top one, the "default one".
                                            thanks in advance,
                                            • 31
                                            • 32
                                            • 7 / 32
