    Medeek Wall Plugin
    1.5k Posts 27 Posters 1.1m Views 26 Watching
    • medeekM Offline
      medeek
      I also really like the idea of having a user material library where you can just dump your pre-configured SKM files and the plugin then has the ability to pick and choose from these materials.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
        alpro
        Ok nevermind on #1, didn't realize that I had to "save settings" on each page of the global settings, thought I could make all my changes and save settings just once.
          alpro
          Had an error running 2 45° bays, totally reproducible, happens every time.
          • medeekM Offline
            medeek
            Can you send me your model or at least the wall panel in question and the walls adjacent to this panel. I need to examine this further, and review my stud spacing algorithm especially how it is handling non-orthogonal walls.
            My email is nathan@medeek.com
            Don't erase this wall panel from your model, once I address the bug you can simply rebuild the wall with the updated plugin and will be resolved.
            design.medeek.com
            • medeekM Offline
              medeek
              Does anyone have a good Tyvek house wrap material or texture that I can incorporate into the plugin?
              design.medeek.com
              • medeekM Offline
                medeek
                Version 0.7.7b - 06.09.2018
                • Horizontal and Vertical plywood sheathing materials added to the pre-installed plugin materials.
                http://design.medeek.com/resources/images/wall_su98_800.jpg
                http://design.medeek.com/resources/images/wall_su99_800.jpg
                I realize this a fairly insignificant item, but it was user requested and one of those things I could knock out in about 10 minutes or less.
                design.medeek.com
                • medeekM Offline
                  medeek
                  I'm actually not a big fan of Tyvek, at least not in our marine environment on the beach out here in western Washington but I do know it gets used a lot. This is the OSB + TYVEK option:
                  http://design.medeek.com/resources/images/wall_su100_800.jpg
                  Only the outside face of the sheathing gets the Tyvek material and the sheathing group gets the generic OSB material.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    The updated main toolbar:
                    http://design.medeek.com/resources/images/wall_su_menu_active.jpg
                    I'm adding one extra icon for estimating, this will allow the user to create a bill of materials for one or more (multiple) wall panels.
                    At this point I am not interested in developing a sophisticated estimating program with the ability to associate costs to various materials etc... Basically I just want the estimating feature to be able to spit out a CSV file with a comprehensive parts list that can then be dropped into any spreadsheet software (ie. Excel) and the user can take it from there.
                    As an engineer I use Excel for a number of things including very complicated calculators. Spreadsheets are pretty much the bread and butter of any design professional, or someone working in the construction industry. With that being said a CSV file makes the most sense to me.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 0.7.7c - 06.09.2018
                      • Tyvek + OSB material added to the pre-installed plugin materials.
                      • Added 2D construction line options for sheathing, cladding and gypsum within the global settings.
                      http://design.medeek.com/resources/images/wall_su101_800.jpg
                      Taking it a bit slow today, just a few minor items and some small fires to put out, catching a bit of a breather.
                      design.medeek.com
                        Charlie__V
                        Nice! Thanks Nathaniel
                        Charlie
                          alpro
                          Still testing out to get a good feel for this plugin as I have a project that I would like to use it on along with the foundation and truss plugins. There definitely is an issue with the stud spacing algorithm, this time the bays worked but as you can see the outside corner didn't.
                            Charlie__V
                            Edit the connecting walls in question and make sure the corner settings are correct.
                            I am on iPad now so no access to correct terminology from within plug-in.......but it should be corner of course and not T
                            Edit:
                            Also double ck walls as to their respective elevations & ht’s. (same/same)
                            Charlie
                            • medeekM Offline
                              medeek
                              The latest release has not yet addressed the stud spacing algorithm issue. The reason being is that I have to test it in numerous states to verify all possible situations are calculating correctly, and even though I have made some critical changes to the algorithm I am not yet ready to push it out. I am looking at this right now and hopefully should have the fix out later this afternoon.
                              design.medeek.com
                                alpro
                                Charlie pointed me in the right direction, end corner was set to inside corner though I was sure I had set it to outside corner, once I did that and updated all was good.
                                • medeekM Offline
                                  medeek
                                  Version 0.7.7d - 06.10.2018
                                  • Added 2D (construction or solid) line options for sheathing, cladding and gypsum within the global settings.
                                  • Fixed a bug within the corner trim module (trim width).
                                  • Added additional standard metric stud sizes: 36x68, 36x98, 36x148, 36x198, 48x72, 48x98, 48x148, 48x198
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    This is the direction I am going with the Wall Edit Menu UI and Draw wall Tool:
                                    http://design.medeek.com/resources/images/wall_su102_800.jpg
                                    Notice the wall presets section at the top of the UI, here you can delete, load or save a preset wall template.
                                    The actual templates will be stored in a simple text file within a sub-folder called "presets", that way the user can also manually edit the wall preset file and even cut and paste presets from other users into their preset file. This solution offers the most flexibility and user control in my opinion.
                                    Loading a preset will re-populate all of the parameters in the form below except for the excluded items.
                                    The save function will create a new preset (with user entered name/description) based on the currently listed parameters in the form.
                                    Does this make sense? and the better question, am I missing anything here?
                                    Hopefully this new addition of presets will speed up the wall creation process and spare the user from having to recreate a specific wall type from scratch each time they start a new model or session.
                                    I still have not fully arrived at what the excluded parameters should be in the wall preset functions so please provide any feedback in this regard.
                                    design.medeek.com
                                      Charlie__V
                                      1.) Since we can enter wall lengths as feet and inches while drawing can we please have the wall length editable in same format? TIA
                                      Wall length request in ft. & inch
                                      2.)Are there any unforeseen/adverse effects of moving a wall using the native SU move tool?
                                      (Realizing using the Medeek wall move tool will auto-heal/move existing walls if attached in a way they will follow/heal.)
                                      But for other circumstances where this is not the case.
                                      Charlie
                                      • medeekM Offline
                                        medeek
                                        Charlie
                                        Funny as I have not really noticed that with the wall length until you pointed it out. Yes, we can switch it to feet-inches for imperial units.
                                        Yes, you can move the walls with the SU move tool without any adverse issues (at least none to my knowledge currently). But as you have already stated manually moving a wall will disconnect it from any previously attached walls.
                                        design.medeek.com
                                          Charlie__V
                                          I think the more information you can pre-set and leave out of initial "draw wall" window the better.
                                          IE:
                                          A 2x6 Ext.Wall_Horiz.Side_16_O.C. removes the need to specify stud width/depth/O.C./plates/etc. if wall name/definition states it.
                                          Or a 2x6 Ext.Wall_Horiz.Side_16_O.C.Trtd.plate has treated bottom plate only.
                                          An edit button for the active wall definition would be great to have too.(within initial "draw wall" window)
                                            Charlie__V
                                            PS
                                            When using polyline it seems the draw wall tool is self aware enough it doesn't require the need to pre-select "start" and "end" type........so maybe that is not necessary on initial "draw window" either
                                            • 58
                                            • 59
                                            • 60
                                            • 61
                                            • 62
                                            • 75
                                            • 76
                                            • 60 / 76
