    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.2m Views 28 Watching
    • C
      Charlie__V
      @medeek said:
      Version 0.7.7c - 06.09.2018
      • Added 2D construction line options for sheathing, cladding and gypsum within the global settings.
      Nice! Thanks Nathaniel
      Charlie
        alpro
        Still testing out to get a good feel for this plugin as I have a project that I would like to use it on along with the foundation and truss plugins. There definitely is an issue with the stud spacing algorithm, this time the bays worked but as you can see the outside corner didn't.
        • C
          Charlie__V
          Edit the connecting walls in question and make sure the corner settings are correct.
          I am on iPad now so no access to correct terminology from within plug-in.......but it should be corner of course and not T
          Edit:
          Also double ck walls as to their respective elevations & ht’s. (same/same)
          Charlie
          • medeekM
            medeek
            The latest release has not yet addressed the stud spacing algorithm issue. The reason being is that I have to test it in numerous states to verify all possible situations are calculating correctly, and even though I have made some critical changes to the algorithm I am not yet ready to push it out. I am looking at this right now and hopefully should have the fix out later this afternoon.
            Nathaniel P. Wilkerson PE
            Medeek Engineering Inc
            design.medeek.com
              alpro
              Charlie pointed me in the right direction, end corner was set to inside corner though I was sure I had set it to outside corner, once I did that and updated all was good.
              • medeekM
                medeek
                Version 0.7.7d - 06.10.2018
                • Added 2D (construction or solid) line options for sheathing, cladding and gypsum within the global settings.
                • Fixed a bug within the corner trim module (trim width).
                • Added additional standard metric stud sizes: 36x68, 36x98, 36x148, 36x198, 48x72, 48x98, 48x148, 48x198
                design.medeek.com
                • medeekM
                  medeek
                  This is the direction I am going with the Wall Edit Menu UI and Draw wall Tool:
                  http://design.medeek.com/resources/images/wall_su102_800.jpg
                  Notice the wall presets section at the top of the UI, here you can delete, load or save a preset wall template.
                  The actual templates will be stored in a simple text file within a sub-folder called "presets", that way the user can also manually edit the wall preset file and even cut and paste presets from other users into their preset file. This solution offers the most flexibility and user control in my opinion.
                  Loading a preset will re-populate all of the parameters in the form below except for the excluded items.
                  The save function will create a new preset (with user entered name/description) based on the currently listed parameters in the form.
                  Does this make sense? and the better question, am I missing anything here?
                  Hopefully this new addition of presets will speed up the wall creation process and spare the user from having to recreate a specific wall type from scratch each time they start a new model or session.
                  I still have not fully arrived at what the excluded parameters should be in the wall preset functions so please provide any feedback in this regard.
                  design.medeek.com
                  • C
                    Charlie__V
                    1.) Since we can enter wall lengths as feet and inches while drawing can we please have the wall length editable in same format? TIA
                    Wall length request in ft. & inch
                    2.)Are there any unforeseen/adverse effects of moving a wall using the native SU move tool?
                    (Realizing using the Medeek wall move tool will auto-heal/move existing walls if attached in a way they will follow/heal.)
                    But for other circumstances where this is not the case.
                    Charlie
                    • medeekM
                      medeek
                      Charlie
                      Funny as I have not really noticed that with the wall length until you pointed it out. Yes, we can switch it to feet-inches for imperial units.
                      Yes, you can move the walls with the SU move tool without any adverse issues (at least none to my knowledge currently). But as you have already stated manually moving a wall will disconnect it from any previously attached walls.
                      design.medeek.com
                      • C
                        Charlie__V
                        I think the more information you can pre-set and leave out of initial "draw wall" window the better.
                        IE:
                        A 2x6 Ext.Wall_Horiz.Side_16_O.C. removes the need to specify stud width/depth/O.C./plates/etc. if wall name/definition states it.
                        Or a 2x6 Ext.Wall_Horiz.Side_16_O.C.Trtd.plate has treated bottom plate only.
                        An edit button for the active wall definition would be great to have too.(within initial "draw wall" window)
                        • C
                          Charlie__V
                          PS
                          When using polyline it seems the draw wall tool is self aware enough it doesn't require the need to pre-select "start" and "end" type........so maybe that is not necessary on initial "draw window" either
                          • medeekM
                            medeek
                            @charlie__v said:
                            PS
                            You are correct. When the auto-corner configuration global setting is enabled the plugin will correctly sense the corner angles and configurations and take care of that automatically. If this global setting is enabled I should probably just gray out the appropriate parameters (at least in the draw tool GUI). One can always edit a wall and manually change these value which will override the auto behaviour.
                            I like how you term it "self aware", I'm a huge fan of AI and a bit of an AI programmer myself but I wouldn't go quite so far as to call this AI or even self aware. Just a fairly complicated algorithm that tries to check for specific wall corner and tee intersections. As time goes on the algorithm will probably be revisited a few more times making it more robust and flexible, but it has no capacity to learn (ie. memory). Just a static set of instructions which it follows without variation.
                            However, with that being said I have considered using some sort of adaptive behavior for the plugin that would slowly adapt to the users most commonly used values for certain parameters and try to predict what those values should be in the future. A good example of this would be header selection for interior walls. Over time it would begin to rank which header sizes/types are used the most and then within the drop down menus it could sort them so that the most commonly used sizes appear at the top of the list with the most commonly used one being selected as default.
                            Again I don't know if I would call this AI but it would certainly be adaptive software and would tailor itself to the users habits.
                            design.medeek.com
                            • Bob JamesB
                              Bob James
                              Where are the updated versions located for downloading?
                              Do just go to http://design.medeek.com/resources/medeekwallplugin.html and download the Trial?
                              • medeekM
                                medeek
                                Login to the Account Manager and the download link will appear under the license listing.
                                401 - Unauthorized: Access is denied due to invalid credentials.
                                (design.medeek.com)
                                design.medeek.com
                                • Bob JamesB
                                  Bob James
                                  Toolbar icons do not scale for 4K monitor.
                                  • Bob JamesB
                                    Bob James
                                    (design.medeek.com)
                                    Thank you!
                                    • medeekM
                                      medeek
                                      [attachment=0:2u1yiq42]<!-- ia0 -->MedeekIcons-1.png<!-- ia0 -->[/attachment:2u1yiq42]
                                      Does anyone know how to address that?
                                      Here is my typical toolbar/icon ruby:
                                      cmd7.small_icon = "images/mdkplg_tool_icon16_8.png"
                                      cmd7.large_icon = "images/mdkplg_tool_icon24_8.png"
                                      cmd7.tooltip = "Medeek Wall"
                                      cmd7.status_bar_text = @Trs['Change Global Settings']
                                      cmd7.menu_text = @Trs['Global Settings']
                                      toolbar = toolbar.add_item cmd7
                                      toolbar.show
                                      Do I need an extra large icon?
                                      design.medeek.com
                                      • Bob JamesB
                                        Bob James
                                        The icons have to be .svg format. This is a scalable vector format that is the new SU standard.
                                        • medeekM
                                          medeek
                                          There are really three functions in one here: Loading, Saving and Deleting.
                                          Quite a bit of new code to implement the new presets system. I'm still testing it out to make sure it is solid, but so far it is looking pretty good.
                                          Note, that it is possible to give a preset the exact same name as another preset, this is by design and they will both appear in the drop down list. What you are not seeing in the drop down is the hidden number assigned to each preset which is stored in the presets file. This number is really the identifier of the preset and allows one to correctly specify which preset you are wanting to load or delete.
                                          Once this system is in place for the walls and fully tested and verified I will implement a similar system for windows and doors.
                                          I have a number of minor fixes and bugs that are quite hot items right now that have been delayed due to my attention to this latest upgrade, I apologize for the delay in getting the fixes out, but I really feel that this UI upgrade is top priority right now.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            I've messed around with a few PNG to SVG converters and the result are not spectacular. I've actually used SVG quite extensively in some of the menus for the Truss Plugin so I have a pretty good understanding of how SVG works. Unfortunately, SVG does not lend itself well to shaded or rendered images or to gradients. Line drawings is where it excels, I'll have to give this some more thought.
                                            If I can somehow detect that the user is running a 4K monitor or some other high resolution monitor that the current icons are not well suited to then I could substitute the regular icon set with a lesser quality SVG set.
                                            design.medeek.com
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 80
                                            • 81
                                            • 14 / 81
