    • Log Masuk
    Medeek Wall Plugin
    Scheduled Pinned Kunci Moved Plugins
    1.5k Kiriman 27 Posters 1.1m Lihat 26 Watching
    Memuatkan lagi kiriman
    • Lama ke Baru
    • Baru ke Lama
    Balas
    Log masuk untuk balas
    Topik ini telah dipadam. Hanya pengguna dengan kuasa pengurusan boleh melihatnya.
    • medeekM Luar talian
      medeek
      Version 0.7.6b - 06.05.2018
      • Auto-Corner Configuration algorithm revised to handle "stepped" walls.
      • Wall "Draw Tool" configured to retain most recent inputs from user. Parameters not shown in UI default to global settings.
      This sub. revision is actually fairly significant and worth upgrading to since it addresses a major flaw in the UI.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      1 Reply Last reply Balas Petikan 0
        medeek
        Version 0.7.6c - 06.05.2018
        • Added the option to toggle between standard stud sizes and custom (user defined width x depth) sizes with the "Walls" tab of the global settings.
        http://design.medeek.com/resources/images/wall_su95_800.jpg
        Note that within the wall edit menu the stud width and depth can be adjusted independently regardless of the standard stud size option being enabled.
        design.medeek.com
          medeek
          Updated the vendor page to reflect all of the products listed within the plugin:
          Medeek Design Inc. - Medeek Wall Plugin Vendors
          (design.medeek.com)
          design.medeek.com
            medeek
            Version 0.7.6d - 06.05.2018
            • Fixed a bug with the wall sheathing and cladding so that door openings are properly cut out even when the vertical offset parameter is negative.
            http://design.medeek.com/resources/images/wall_su96_800.jpg
            design.medeek.com
              medeek
              This morning I am spending a little extra time on the auto-corner config module and the related module that checks for tee intersections. It has been brought to my attention that this area of the plugin is not as robust as it needs to be. I've already made a number of minor corrections and augmentations but if anyone has a particular case that is throwing an error or unexpected result please send that information along.
              design.medeek.com
                medeek
                I need some feedback on another marketing strategy for the plugin. I'm thinking about creating a lite version Medeek Wall Plugin LT, this version would only have the 2D and 3D (no framing) mode available to it. The interior of the wall (framing, studs, headers etc...) would not be included in the LT version, nor would holdowns and any engineering or estimating features.
                The LT version may be more suitable for some designers who do not want to be bothered with the details of the construction and are only interested in the layout.
                The ability to insert windows and doors as well as all of the trim and casing options would still be available in the LT version.
                What would you suggest as the regular price for an LT version? Is there any interest in this direction?
                design.medeek.com
                  medeek
                  I am providing a few links for the plugin below:
                  Main Plugin Page:
                  (design.medeek.com)
                  Changlog:
                  Medeek Design Inc. - Medeek Wall Plugin Changelog
                  (design.medeek.com)
                  Vendors:
                  (design.medeek.com)
                  design.medeek.com
                    medeek
                    I've added the two beam icons to the columns toolbar:
                    http://design.medeek.com/resources/images/wall_beamscolumns_su_menu_active.jpg
                    The following beam types will be available:
                    • Glulam
                    • Sawn Lumber
                    • Timber (5"x5" and larger)
                    • SCL (LVL, PSL, LSL)
                    • Steel (W, C, L, HSS)
                    A placement parameter will allow one to specify Top Center or Bottom Center.
                    A ply (qty.) parameter will allow for multi-ply beams, this is typical for LVL beams and sawn lumber.
                    My idea on this draw tool is to have the HTML menu stay open allowing the user to draw as many beams as desired with the ability to change any of the settings within the HTML menu and then being able to resume drawing beams.
                    If this type of menu/tool system works well I will probably adopt something similar for the Wall Draw Tools.
                    design.medeek.com
                      medeek
                      Had an interesting email today on the complexity of the plugin. I agree that the menus are a bit daunting even for myself, and I even know what each parameter is and does.
                      I've discussed this previously in the thread with an idea to go to an HTML menu that hopefully might be less "scary".
                      The problem really is that to fully define a wall with all of the flexibility needed the number of parameters quickly goes through the roof. Case in point, look at the edit window menu here:
                      404 - File or directory not found.
                      (design.medeek.com)
                      People like the simplicity of SketchUp, that is what has drawn many of us to it. Then I turn around a throw a bunch of menus at you with 15-20 parameters each, I can understand how this can be a bit much for many people.
                      As I've been contemplating this problem and trying to find a solution (compromise) I've come up with the following idea.
                      Essentially have the draw wall tool present an HTML menu not to dissimilar from the current HTML edit menu. However organize the options that turn off the various advanced options into highlighted headers with all of the sub-details hidden unless those particular header items are enabled. It may take a few iterations to get this right but I think it would be better than the current system of multiple menus that pop up one after the other.
                      I'm not a software developer or a GUI expert but when I hit upon the right solution I will know when it is right.
                      As far as decreasing the depth of the plugin, that cannot be done. What can be improved upon is the ability to better manage that data and organize and present it in a more concise and clear fashion.
                      This is the reason for the extensive global settings, the user can enable or disable the default behavior for a number of parameters and options allowing the user to precisely determine to what level of granularity they wish to take their model.
                      For instance many people probably don't want to model the cavity insulation (personally I don't find it that useful) but if that level of detail is needed it can be turned on in the insulation tab of the global settings.
                      Please continue to send me your feedback. I have lots of ideas on how this plugin should go together but I've changed gears a few times already when shown a different way.
                      design.medeek.com
                      • C Luar talian
                        Charlie__V
                        Nathaniel,
                        I had some time today to try your wall plug-in.
                        It appears to install just fine,(as admin/restart SU) but I have been unable to get it to function.
                        All of the menus appear, and when I select the draw wall icon.....set wall parameters....click OK......attempt to draw wall....nothing happens....no indication from cursor....no snap point highlight or wireframe of wall appear.
                        Perhaps this is a MS Windows 7 Pro limitation and/or an IE V11 thing? (see my machine spec's in sig.)
                        Sorry to trouble you with this as I know you are incredibly busy......but figured if this is an MS/OS limitation maybe it should be posted here. (or further a compatibility note on download page)
                        Thanks for your time.
                        Edit:
                        I have what I believe is the latest version. (June 6th)
                        & License type is TRIAL and the text is green.
                        Charlie
                          medeek
                          @charlie__v said:
                          Nathaniel,
                          Edit:
                          Charlie
                          Let me guess, the advanced wall options are turned off?
                          design.medeek.com
                          • C Luar talian
                            Charlie__V
                            Advanced wall options are set to YES (in wall parameters window & global settings)
                            C
                              medeek
                              C
                              Open the Ruby Console, then duplicate the error and send me the error code nathan@medeek.com
                              I made a number of improvements yesterday and I may have inadvertently broke the plugin with the latest release (0.7.6e).
                              design.medeek.com
                                medeek
                                Version 0.7.6f - 06.07.2018
                                • Added the ability to lock the cursor to the X or Y axis for the "Draw Wall Tool" (line and polyline) by pressing the SHIFT key.
                                • Added the ability to lock the cursor to the 45 deg. and 135 deg. axis for the "Draw Wall Tool" (line and polyline) by pressing the CTRL key.
                                Also note that I fixed a couple of bugs I accidentally created when making the code adjustments for version 0.7.6e, I managed to break the plugin for all TRIAL users.
                                Therefore this is a critical update, please remove the prior version and install this version which will fix the error introduced last night. This is what happens when I try to get too much done in one day.
                                Click on the image to view animation:
                                design.medeek.com
                                • A Luar talian
                                  alpro
                                  Any chance to be able to add our own textures to the walls ? Would it be possible to just have a library that we could add too......would like to see that also in the roof textures with the truss tool.
                                    medeek
                                    When you say walls, are you talking about texturing the framing, cladding, sheathing or gypsum?
                                    design.medeek.com
                                      medeek
                                      Version 0.7.7 - 06.08.2018
                                      • Created the Medeek Wall Plugin LT, a lighter version of the plugin with internal wall framing, estimating and engineering removed.
                                      • Horizontal and Vertical OSB sheathing materials added to the pre-installed plugin materials.
                                      http://design.medeek.com/resources/images/wall_su97_800.jpg
                                      Note that the June promo does not apply to the LT version of the plugin
                                      design.medeek.com
                                      • A Luar talian
                                        alpro
                                        As far as texturing I'm talking about cladding and gypsum so that I can show client specified materials and that I don't lose those materials when a client makes changes and the walls need rebuilt.
                                        • A Luar talian
                                          alpro
                                          So finally had some time to really try this out and have run into 3 issues,
                                          1)My global settings don't stick
                                          2)No matter what settings I use or which direction that I draw the wall in the cladding always is inside.
                                          3)Would be nice if last settings were remembered when drawing a new wall
                                            medeek
                                            What version are you using?
                                            Also only use the FRONT justification, the other two are currently flawed and I am working on them.
                                            I will need more details on which global settings are taking and also your operating system.
                                            The previous settings should be recalled when starting a new wall, however this issue was only recently addressed in 0.7.6f, be sure to install the latest version.
                                            design.medeek.com
                                            • 59
                                            • 60
                                            • 61
                                            • 62
                                            • 63
                                            • 75
                                            • 76
                                            • 61 / 76
